Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 07-23-2006, 02:48 PM   #1
kn0bby8
Member#: 97644
2006 WRX
Default Kit install
I am gonna be gettin my kit installed this week. How long can I drive injecting without a tune. I plan on getting a tune as soon as possible but it is a pain in the ass to get an appointment with my tuner.
kn0bby8 is offline   Reply With Quote
Old 07-23-2006, 04:18 PM   #2
KJR
Member#: 16879
Depends on what and how much you are injecting????
Motor can last from 2 seconds to 2 decades.....
need more info
KJR is offline   Reply With Quote
Old 07-23-2006, 04:44 PM   #3
kn0bby8
Member#: 97644
2006 WRX
I think I am gonna go with a 50/50 mix of water and method
Old 07-23-2006, 05:40 PM   #4
KJR
Member#: 16879
What kit are you using? I would recommend keeping the system "inactive" until you tune.
Old 07-23-2006, 05:56 PM   #5
kn0bby8
Member#: 97644
2006 WRX
Cooling mist stage 2
How would I keep it inactive?
Old 07-23-2006, 07:23 PM   #6
KJR
Member#: 16879
same kit as I have
Put your "max" knob setting LOWER than your "start" knob and the system will not activate, or simply put both knobs on the lowest settings. To make sure it's not spraying you can look at the spray light, or pull the nozzle out of the pipe and make a quick pull to see if it sprays.
Old 07-23-2006, 07:41 PM   #7
Coolingmist
Vendor
Member#: 67024
2009 BMW 135 I
space grey
It will not hurt your vehicle to run it un-tuned. The best case scenerio would be you may gain a few HP, the worst case scenerio you can lose a few HP. it all depends on your current tuning and mixture. so to answer your question, it will not harm anything to run it un-tuned.
KJR,
Putting both knobs on the lowest settings would make the system come on at 1 psi, if you have the tuning button on 10, it would hit 100% duty cycle at 1 psi , if you have the tuning button on 5, it may only hit 50% or so.
David
Coolingmist is offline   Reply With Quote
Old 07-23-2006, 07:56 PM   #8
hippy
Member#: 36528
2002 Impreza Wrx
The engine could misfire, and/or the cylinders could end up gettin washed(bad). People have also noted upto a 30whp loss from running water injection(from what I've heard). Imo it would be wise to tune the car with injection b4 you start using it on a normal basis. Course this is just my opinion, and I'm no expert.
peace
Old 07-23-2006, 08:01 PM   #9
KJR
Member#: 16879
KJR,
David
Ok, sorry for the mis-information. Then the max knob must be LOWER than the start knob.
FYI: I was spraying 50/50 for about a week before I was tuned. I am not 100% sure if it was the spray, but when I went back for my alky tune, my baseline numbers were down by 10whp. My tuner thought it was weird, and my ST trims were over 10% and my timing down 2 degrees.
Old 07-25-2006, 11:00 AM   #10
GottaREX
Member#: 43963
2014 Subaru Impreza
Gun Metallic Gray
I've got my alky kit for a week now untuned. Still having a hard time finding methanol but when I do, I'm gonna run w/o tune and see how she runs. I'll let you guys know
GottaREX is offline   Reply With Quote
Old 07-25-2006, 06:17 PM   #11
turbo tecnica
Member#: 74470
2013 Accord Sport
72 LS1 Vette
GottaRex- if you go up to New England Dragway at all, they sell meth by the gallon I believe. I am going up there tomorrow night, and I am buying a fair amount of it. I was also told they sell 5-gal containers you can put it in, so I might buy 5 or 10 gal of it, not positive yet. I'll be running a 50/50 mix so 10 gal of it should last me a good while.
turbo tecnica is offline   Reply With Quote
SMC underhood kit install instructions - anyone got them or can explain the install? anthonyrb98 Water/Methanol Injection, Nitrous & Intercooler Cooling 2 03-25-2007 04:53 PM
B-Spec Yellow WRX w/full C-West kit installed -- Back in Bay Area! B-SpecUSA Bay Area Impreza Club Forum -- BAIC 0 04-21-2001 08:49 PM
Legacy Turbo Kit Install Woes stimpy Normally Aspirated Powertrain 24 03-23-2001 01:06 AM
had eibach pro kit installed herzy2.5RS New England Impreza Club Forum -- NESIC 9 03-22-2001 09:12 AM
ASR Turbo Kit Installed tom@kartboy Normally Aspirated Powertrain 44 02-28-2001 11:50 PM
