Old 07-23-2006, 03:47 PM   #1
jameslippert
Member#: 46271
Default Need help identifying springs and tophats
Hey Y'all,
I need some help identifying some parts I bought. First of all, my car is an 02' WRX sedan with Koni inserts. I bought a set of 05' STi springs before I found out they aren't a direct fit. After reading through many threads I learned that I could use 04'-06' top hats with a washer/spacer in the rear to make the springs fit my 02'.
Today I bought a set of top hats from a 04' WRX Wagon. I tried to test fit the springs w/ top hats and the rear don't seem to match. We did minimal research regarding wagon/sedan fitament and the result was positive.
So here's what I see. The rear 04' wagon top hats have a smaller imprint pattern (from the spring) than the rear 05' STi spring (spring coil is larger than the imprint from previous spring)...
Rear top hat = Smaller (coil print)
Rear spring = Larger (coil)
Are these parts supposed to mate and I have been sold something other then what I thought? Or are WRX wagon and STi rear top hats different?
Thanks for any help!
James
jameslippert is offline   Reply With Quote
Old 07-23-2006, 03:53 PM   #2
BIGSKYWRX
Member#: 7958
09 GH B+
James the wrx 04+ rear tops (wagon or sedan) = the rear 04+ STi tops- same part #'s.
The 04+ springs have a distinctive taper (smaller at the top) vs the previous generation springs. The 04+ style top simply sits a top this tapered spring (actually a portion of the top slides into the upper coils).
If you have a large coil rear spring that doesn't taper it isn't a 04+ spring.
Pics would help.
Old 07-23-2006, 04:40 PM   #3
jameslippert
Member#: 46271
Sounds like I've got the wrong springs... argh! Would you mind looking at some pictures to confirm your thoughts?
Thanks a lot for the help!
http://filetransfer.wavefront.cx/download/IMG_2922.jpg
http://filetransfer.wavefront.cx/download/IMG_2923.jpg
Old 07-23-2006, 05:52 PM   #4
BIGSKYWRX
Member#: 7958
09 GH B+
Can you take a side view of the top- just want to be sire it's a 04+ style?
The spring looks like it has some taper, can't tell if it's enough though.
The top should slide down into the spring and be fairly snug.
Old 07-23-2006, 06:17 PM   #5
jameslippert
Member#: 46271
Here's what I believe to be the rear springs and top hat
http://filetransfer.wavefront.cx/download/IMG_2925.jpg
and the front spring and top hat
http://filetransfer.wavefront.cx/download/IMG_2926.jpg
Old 07-23-2006, 06:21 PM   #6
lookitsawagon
Member#: 51450
2000 GC8
James,
BigSky will confirm this, but the 'front' spring in your picture is actually the rear, and vice versa-- can you see how it's tapered?
So, do you have two 'wide' tophats and two 'narrow' tophats? If so you should be set-- just remember the tapered springs go in the back.
lookitsawagon is offline   Reply With Quote
Old 07-23-2006, 06:22 PM   #7
BIGSKYWRX
Member#: 7958
09 GH B+
turn the springs around the longer spring w/ the taper is the rear sprng- you have the correct rear top and front tops- just have your springs flipflopped
Old 07-23-2006, 06:26 PM   #8
jameslippert
Member#: 46271
Okay, so maybe I'm a dumbass
If I switch the hats, the rear fit very well with the tapered spring (as you've suggested). However, the front are way off. Is there a spring pertch in the front???
Now that I think of it, isn't this setup a MacPherson type. So there has to be some type of bearing/plate for the spring to sit on???
Old 07-23-2006, 06:45 PM   #9
BIGSKYWRX
Member#: 7958
09 GH B+
your not the first to switch up springs
The fronts need a upper spring perch- has three holes (beside the one hte strut goes through)- the middle of the three holes needs to face directly outward- centered on the strut. Underneath it is a rubber spring seat. On top of it nees to be a domed shaped washer- the taper goes / \
Do you have your old struts to go off of? The fronts will be assembled exactly the same.
Old 07-23-2006, 06:53 PM   #10
jameslippert
Member#: 46271
Yeah, I have the assembled struts in the car now as a template.
COOL! You deserve a gold star my friend and have been a big help.
I thought I had them backwards (front springs are normally bigger), but the hats seemed way off. Guess I forgot that the front set MOVES and needs provisions to do so
Again, thanks so much.
James
Old 07-23-2006, 07:07 PM   #11
BIGSKYWRX
Member#: 7958
09 GH B+
Jame no problem- glad I could help. Have got (still get) lots of help myself from this forum
Exhaust I need help identifying this and its for sale. robsta1 SCIC Private Classifieds 6 01-15-2008 01:55 PM
need help with spring and endlinks subaru222 Brakes, Steering & Suspension 5 03-07-2006 06:30 PM
Need help identifying these struts/springs Equilibrium Tuning Brakes, Steering & Suspension 9 08-30-2004 03:29 PM
Need Help Installing Springs and Struts??? Rubasu Brakes, Steering & Suspension 23 01-29-2001 06:35 AM
