Old 07-23-2006, 08:55 PM   #26
flyboymike
Member#: 83765
2005 WRX wagon
WR Blue
Originally Posted by 04_wagon
even when i was parked after cooling the intercooler off with ice and leaving the hood open?
That can help reduce heat soak, which will help you with thermodynamic efficiency of the engine because you cool the air down after it gets compressed. However, the higher heat outside still means you'll have lower density air coming in, translating to fewer air molecules, even when you put it through the compressor. Less air molecules = less power.
flyboymike is offline   Reply With Quote
Old 07-23-2006, 08:55 PM   #27
ElementalFiend
Member#: 113775
2006 Impreza 2.5i
Originally Posted by 575rider
extremely common in all cars, especially 4 cylinders, be happy there's a turbo there in a normally aspirated 2.0 4 cylinder you'd REALLY feel it. You don't have a thing to worry about.
I'm driving an '06 2.5i and there isn't much of a difference.
ElementalFiend is offline   Reply With Quote
Old 07-23-2006, 08:59 PM   #28
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Originally Posted by DrD
while that is indeed true, in daily driving most of us don't drive with the pedal to the floor all the time...
oh sorry that would be me....
Old 07-23-2006, 09:12 PM   #29
rkramer
Member#: 118209
2015 WRX Limitec
yes, the AC shuts off at WOT... but unless you leave ever stoplight at WOT, it WILL make a fairly large difference. btw, most belt/pulley systems are rated at around 10hp max, so you could lose up to 10hp at the crank.
Old 07-23-2006, 09:20 PM   #30
ChgoJay
Member#: 71722
Originally Posted by Subie Gal
we're not talking about GAS MILEAGE
we're talking about POWER
and...
subaru's AC system shut off under WOT ... period.
so if you need power, you get it....
this has been covered a 100gazillion times...
Jamie
We are not talking about either anymore. We're talking about nothing. Thread should have died long ago.
ChgoJay is offline   Reply With Quote
Old 07-23-2006, 10:13 PM   #31
M8
Member#: 949
06 F2000
Speed Triple
Unless he runs full throttle from red light to red light, the AC will be affecting performance: Or rather, affecting FEEL. My daily driver feels like a it's powered by a hair dryer at partial throttle (such as in traffic). I sometimes turn the A/C off when starting from a stop in the 92x, recycling the cool air until I'm into about 3rd gear.... just a thought.
P.S. Real race cars have no doors or windows... let alone AC
M8 is offline   Reply With Quote
Old 07-23-2006, 10:16 PM   #32
REX8
Member#: 24038
what a load of crap
my car dyno's at 205hp at the WHEELS
my car is GT aka STOCK class
and those of you who say AC kills power, dont know much about the Subaru AC system....
Jamie
It kills a lot of power in part-throttle driving. I also thought it was RPM dependent too. So WOT at 2k wouldn't shut it off...
Could be wrong...in daily driving though, its a huge difference...actually have to shift faster the revs fall off so quick....
Sometimes I even make the joke with the A/C on, youu have to Double clutch your upshifts...
Old 07-23-2006, 10:31 PM   #33
Nismo
Member#: 120763
AC compressor is not that heavy to turn. In fact, during freeway driving. You'll lose more power having the windows down then AC on.
Few condition will force ECU to shut down AC. when your TPS reading higher then 4 volts, your speed under 15 MPH and your engine coolant temp reachs over 215 F. There is also a valve and sensors for the R134A and outside temp to pervent AC freeze up, or blow up due to high pressure.
Nismo is offline   Reply With Quote
Old 07-23-2006, 10:32 PM   #34
FreNetiC WRX
Member#: 109763
2006 aw TR
[ GO PETTER GO! ]
Subaru Banner
yes, and the myth that you lose gas, is in fact a myth. the only thing you lose (as you have found out) is power...
FreNetiC WRX is offline   Reply With Quote
Old 07-23-2006, 10:35 PM   #35
REX8
Member#: 24038
Thats certainly not a myth.
Surely you are not saying that your gas mileage doesn't fall with your A/C on. Of course it does...the compressor isn't turning itself....
Old 07-23-2006, 10:36 PM   #36
REX8
Member#: 24038
You don't loss power with the windows down, you gain drag.
Old 07-23-2006, 10:37 PM   #37
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Originally Posted by aerostar
Actually they did a test on Mythbusters, one of my favorite shows. What was interesting was that at 50 MPH the truck with the windows down went around 20-25 more miles than the truck that had the windows up with the A/C on. oO
I think you need to rewatch that episode because you have that backwards.
Smoby is offline   Reply With Quote
Old 07-23-2006, 10:38 PM   #38
REX8
Member#: 24038
No, he got it right.
The truck with the windows DOWN got better mileage (traveled further) than the one with the A/C on...
Old 07-23-2006, 10:43 PM   #39
IDAFC21
Member#: 60471
2004 GTO
QSM
that is correct.
http://kwc.org/mythbusters/2004/11/m..._catapult.html
"Urban puzzle": it is more efficient, on a hot day, to run with the A/C on and windows up than to run with windows down (b/c of increasing car's drag).
Computer-based mpg measurements:
11.7/11.8 with A/C on and windows up
11.7/11.8 with A/C off and windows up
11.3 with A/C off and windows down
So, according to the computer, it's better to use A/C with windows up.
This was too quick and easy for TV, so they decided to stage a seven hour marathon, race-til-you're-empty duel, with Jamie driving an SUV with A/C on and Adam driving an SUV with windows down. Though, once the safety inspector intervened, it was no longer a seven-hour marathon, it was a bit slower (45mph instead of 55mph), and a lot shorter (only 5 gallons each).
Jamie's A/C car ran out of gas first -- Adam's windows down SUV ran for another 30 laps -- completely contradicting the computer mpg estimate. Computer estimate based on air flow into the engine, so it would appear that it is unable to properly model the difference between A/C and windows down.
IDAFC21 is offline   Reply With Quote
Old 07-23-2006, 11:39 PM   #40
STi-JDM
Top Scoob 023
Member#: 90373
05' STi. 89' GT-R
00' GT-R ; LCM x WFC
what a load of crap
Jamie
that's true... I always laugh when people turned their AC off when their pushing the car... LOL...
STi-JDM is offline   Reply With Quote
Old 07-23-2006, 11:48 PM   #41
cowapult
Member#: 25324
2016 WRX
Dark Gray Metallic
Consumer Reports independently confirmed the same thing as Mythbusters. Windows down is better for gas mileage than using AC
cowapult is offline   Reply With Quote
Old 07-24-2006, 12:38 AM   #42
Nismo
Member#: 120763
It all depends what your talking about. If they didn't use cruse control then that means it's all base on STFT instead of LTFT. Which is base on driver really. I had to go to Ont from Irvine which is about 100 miles round trip. FOR ME, I get more mileage with windows up AC on, then windows down. Looks like more testing need to be done. LOL
Old 07-24-2006, 12:48 AM   #43
04_wagon
Member#: 105929
2004 wagon
shiny
ok need to close this cause people are getting away from the point. it was why was their power loss during acceleration. not will i get better gas milage
04_wagon is offline   Reply With Quote
Old 07-24-2006, 12:58 AM   #44
BajaGreg
Member#: 80956
2005 Baja Turbo 5spd
Garnet Red
Default hit the road b*tch!
I once had a girl in my car who said it was too cold with the A/C on.
She rolled her window all the way down. It was 111 degrees outside.
She wouldn't close her window. So I pulled over and kicked her *ss out of the car!
BajaGreg is offline   Reply With Quote
Old 07-24-2006, 01:01 AM   #45
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
The standard impreza A/C system is rated 17,400BTU/hr (5.1kW) cooling at full load. That is roughly 6.8hp. So you know that it consumes quite a lot more than that just because of efficiency losses of the compressor, etc.
nhluhr is offline   Reply With Quote
Old 07-24-2006, 01:01 AM   #46
Nismo
Member#: 120763
oh sorry!!
It is a fact you'll lose power when you turn the AC on since it's DRIVEN by the belt which is turned by crankshaft. There for, YES AC = less power
Old 07-24-2006, 01:10 AM   #47
Ghosthound
Member#: 110979
2010 FJ Cruiser
1999 Miata
with temps at an average of 100+ these past couple days here in sac, id gladly lose some mileage for a lot more comfortable driving.
Ghosthound is offline   Reply With Quote
Old 07-24-2006, 01:10 AM   #48
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Having AC on in my car makes it go faster. True story.
Old 07-24-2006, 01:19 AM   #49
bolderer
Member#: 115633
06 protuned vf-34
wagon
Nice response...
bolderer is offline   Reply With Quote
Old 07-24-2006, 01:21 AM   #50
CynicX
Member#: 48199
06 WRX
Its ashame Mythbusters didnt use an areodynamic vehicle. Instead they used SUV's, at least the episode I saw.
Of course the vehicle with the windows down got better MPG at high speeds. The thing didnt have areodymanics to begin with. Generally the difference in city/highway MPG is alot less of a difference on larger none areodymanic vehicles. Like a Jeep may get 16/19 while a car will get 22/30.
The Maryland State Police posted a report that the highway pratrol man get better MPG using the A/C vs having the windows down (anything to save a dime I guess).
/end off-topic rant....
CynicX is offline   Reply With Quote
WTT Power for Less Power JohnST2k6k Tri-State Area Private Classifieds 0 01-11-2010 02:11 PM
The vain? search for safe, CEL-less power Hedonic Treadmill Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 12-31-2001 12:15 PM
Less power? Skunkeye Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 07-30-2001 08:20 PM
less power WRXGAL Newbies & FAQs 11 06-22-2001 12:30 AM
