Old 07-23-2006, 08:45 PM   #1
Alan l.
Member#: 90085
Default Redline, Royal Purple or Castrol 4eat oil??
Yes i know what the manual says to use but what do most people here with the 4eat use with proven results? Seems like i've read just as much postive reviews as I have negative with going Redline or royalpurple synthetic oils on the auto tranny. I suspect that most of the negative reviews/problems were due to issues that existed on the tranny already but became more noticable when they flushed the system.
I want the best fluid for my 4eat for longevity and smooth shifts but i'm not sure what to run.
Whats tried and tested to simply work on these trannys?? I came from the bmw world and Redline was pretty much THE oil thats proven to do wonders for their transmissions.
Redline?
Royal Purple syncromesh?
Regular castrol?
Another brand?
Also, how many quarts usually drains out of the pan? Is there any cons to using an oil extractor from the transmission dip stick to suck out the oil as opposed to getting under the car draining it the old fashion way?
BTW, I have about 12K miles on my stage 2 4eat.
Thanks!
Alan
Alan l. is offline   Reply With Quote
Old 07-23-2006, 09:44 PM   #2
stitrueblue
Member#: 83371
04 STI
my guess is your gonna get opinions all over the place on this one (at least thats what my research has shown), but here is my 2 cents.
about 4 weeks ago i switched out the oem tranny oil for royal purple. todate, the shifts are smoother with no side affects. overall - very pleased.
i went with royal purple for a couple of reasons 1) they are a supporter in subiesport and i like the mag 2) i've tried just about every other syn oil out but not royal purple 3) at 1k miles i switched in mobil 1 into the engine, at 5k i switched to royal purple (reasons 1 & 2), having consistantly averaged around 18.5 mpg per tank (i check every fill up), my mileage jumped to just over 20 mpg and has never dropped below that ( i basically just drive it back and forth to work so the route is very consistant).
even more controversial is the rear diff, i almost certain (not 100% yet) that at my next oil chg royal purple is going back there too (man i know i'm gonna get it for that one)
stitrueblue is offline   Reply With Quote
Old 07-23-2006, 09:56 PM   #3
Alan l.
Member#: 90085
^^ Thanks for the info.
This is the type of responses that i'm looking for. I too ran RP on my sc'ed bmw as well as redline and both worked wonders on the 5spd. Butter smooth shifts.
I'm new to the suby scene so i'm not sure how this stuff works with it. I've read posts where people love going synthetic in their 4eats as well as posts where they claimed the transmission slipped like hell after the change causing catastrophic failure.
Alan
Old 07-24-2006, 12:05 AM   #4
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I personaly think any synthetic trany fluid will be better or as good as stock. I use AmsOil and think it's great. Changed to AmsOil rear diff too and it's also seems better than with the stock oils.
wrxdrvr is offline   Reply With Quote
Old 07-24-2006, 12:25 AM   #5
Alan l.
Member#: 90085
Did you notice any difference when you switched?
Old 07-24-2006, 09:05 AM   #6
kheff46
Member#: 66739
2002 WRX wagon
i use amsoil high pressure in my rear diff. and royal purple in my 5spd. feels better than the mystery stuff in it before(thick red stuff). no problems with grinding, slipping etc., but it's not an auto either.
--keith
kheff46 is offline   Reply With Quote
Old 07-24-2006, 09:15 AM   #7
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
I'll bet the thick red stuff was Redline heavyWt Shock proof...
But I dont know why you would put gear oil in an automatic transmission.
LyveWRX is offline   Reply With Quote
Old 07-24-2006, 10:37 AM   #8
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Yes I did, espessialy when it got cold... My car rolls out of my driveway all the way to the end now instead of just 1/2 way like it used to with the stock oils in the diffs.
Old 07-25-2006, 04:28 PM   #9
Alan l.
Member#: 90085
bump for more info...
Old 07-25-2006, 04:31 PM   #10
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
i am using the new subaru syn and haven't had any problems with it.
distorto is offline   Reply With Quote
FS NNJ: 4 Quarts Royal Purple 5w-30 Motor Oil bmw50021 Tri-State Area Private Classifieds 0 07-18-2008 03:42 AM
where can i get torco/redline/royal purple wht07sti22 Southern California Impreza Club Forum -- SCIC 17 03-08-2008 01:47 AM
Royal purple for my next oil change? gtasti Service & Maintenance 15 10-19-2007 03:04 AM
Mag. Article - Royal Purple vs Other Synthetic Oils? skimobile Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-14-2005 06:56 AM
('93-'01) Vendors who resell Royal Purple or Redline North Ursalia Impreza Forum 1 04-13-2001 07:06 PM
