Old 07-23-2006, 08:48 PM   #1
anzu
Member#: 42154
2008 WRX STI
Question Pulled P2089 & P2093 CEL Codes
I recently pulled the following codes that is causing CEL and flashing cruise light:
P2089: OCV Solenoid Valve Signal A Circuit Short (Bank 1)
P2093: OCV Solenoid Valve Signal A Circuit Short (Bank 2)
I used the search here to find 2-3 posts that were very limited of information about this problem. There was one case of a loose ground (around the intake manifold) that caused the the code to be thrown and the 2-3 threads decided that was the problem based on the single post about these CEL's. I checked the grounding of my car and everything seems normal. Any suggestions besides bringing it to the dealer?
Thanks,
Andrew
anzu is offline   Reply With Quote
Old 03-30-2009, 05:53 PM   #2
metcalf164
Member#: 186969
2006 sti
osb
any updates on this I pulled the same codes today car runs fine but does not idle well and stalled once
metcalf164 is offline   Reply With Quote
Old 04-03-2009, 07:34 PM   #3
metcalf164
Member#: 186969
2006 sti
osb
fixed bad ground
Old 05-08-2009, 11:46 PM   #4
fzturbo
Member#: 43482
2004 JDM 2 litre STI
sorry to bring up an old thread, but i'm getting the same codes mentioned in the first post.
Which ground wires should be checked in the intake manifold?
Thanks.
fzturbo is offline   Reply With Quote
Old 05-09-2009, 10:36 AM   #5
metcalf164
Member#: 186969
2006 sti
osb
On the top to each side they are large grounds
Old 11-04-2009, 02:00 PM   #6
wangan_x
Member#: 63604
06 Subaru
STi
thanks alot this took care of my codes
wangan_x is offline   Reply With Quote
Old 06-16-2011, 11:31 AM   #7
cha86
Member#: 111048
I <3 debt
bump! had this issues. thanks for the quick fix.
cha86 is offline   Reply With Quote
Old 07-15-2011, 01:23 AM   #8
withaz
Member#: 272112
2006 STI
World Rally Blue Pearl
thanks. had the same problem.
withaz is offline   Reply With Quote
Old 09-06-2014, 08:54 AM   #9
roadtrip1098
Member#: 185688
2006 STi
WR Blue
NASIOC strikes again. Just changed injectors, did my scaling and all that but was having a nasty stumble on idle. I would lean all the way out, idle would drop to about 300, then it would catch itself (sometimes) and go very rich before leveling out and starting the process all over again. I was going nuts reading through data logs, checking and double checking my maps. Finally threw this code and low and behold, I had forgotten to tighten one of the ground wires.
The car is absolutely nuts now, logs look peachy, no crappy idle issues, rock solid AFR's.
This forum is a life saver. Even though I now feel like a n00b for missing tightening a friggin ground wire, thank you guys so much.
Also apologies if I just resurrected an ancient thread - answers are answers no matter how old.
roadtrip1098 is offline   Reply With Quote
Old 12-29-2014, 04:28 PM   #10
Luc
Member#: 276589
2004 WRX STI
This didnt work for me damn
Luc is offline   Reply With Quote
check Engine Light !!! Need Help!!! P2089 & P2093 roccrew585 Service & Maintenance 2 01-20-2007 09:57 AM
HELP: where can I borrow a CEL code reader or get the code pulled for free? anonymous_wolf Vancouver Impreza Club Forum -- VIC 5 08-11-2005 01:40 AM
Anyone help in getting a CEL code pulled ? ZMANNH25rs New England Impreza Club Forum -- NESIC 5 02-27-2002 03:13 PM
Who can pull CEL codes? Concillian Bay Area Impreza Club Forum -- BAIC 31 01-21-2002 12:33 AM
pulling CEL code hp12c Bay Area Impreza Club Forum -- BAIC 4 12-10-2001 02:48 PM
