Old 07-23-2006, 07:14 PM   #1
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
Default stage two and bad shelf map
Hey looking for suggestions here, and maybe someone with a protuner licence for feedback/ helo. Had Jarrad from PDX pull some logs while we are up a Dyno Day and Basline runs. We did a base line in my 2006 WRX Stage 2
- HKS Stamped Flange DP
- Magnaflow Catback (Catless)
- K&N with gutted stock intake
- AP with Shelf Stage 2 Reflash
2200 ft elevation on standard 91oct pump gas
Numbers were 226hp and 270tq
so the numbers were good and seemed right but the problem came in the datalogs you can see for yourself I am getting Knock and lean issues bad ones.
1. Should I reflash to stock? (Until i get this fixed)
2. Should I convince COBB that the map I got was crap and they should update for me?
3. Does someone have a Protuner software and wouldnt mind helping me retune this via email?
reasone I didnt get PDX to tune it at the time was it didnt fit in the schedual and I really didnt want a pro tune as I plan for a new turbo in the next 6-8 months as it is.
Thanks For any help
Kris
Chp_Stix is offline   Reply With Quote
Old 07-23-2006, 07:15 PM   #2
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
Data Log from Jarrad
Old 07-23-2006, 09:20 PM   #3
mxboy15u
Member#: 105115
Man those coolant temps are high! I have never seen 216, and I am on stock thermostat.
mxboy15u is offline   Reply With Quote
Old 07-23-2006, 10:56 PM   #4
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
31C on a dyno with only 1 fan
Old 07-23-2006, 10:56 PM   #5
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
oh and all temps are in (F)
Old 07-23-2006, 11:23 PM   #6
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
I was seeing lean values and negative KC values on my '06 with the cobb stage 2 91 octane map. I got a new map from TDC tuning and I'm seeing only positive KC values. I haven't logged A/F ratios since the new reflash though.
06rexwagon is offline   Reply With Quote
Old 07-24-2006, 12:08 AM   #7
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
so im not the only one then..... I guess COBB is just giving out retarded base maps then..... man its all money money money, 800 for the ap 150 for a good base map man had i seen this before the down sides to owning a new design engine i guess
Old 07-24-2006, 12:34 AM   #8
sperry7
Member#: 110079
06 WRX
Black on Black
Dang... Maybe your car just didn't respond to the map well at all. Every car is different. I highly doubt Cobb messed up your map, however I think it would be worth a call to see what the deal is, and if it is that bad then maybe a potential refund or help getting your car back to normal.
sperry7 is offline   Reply With Quote
Old 07-24-2006, 12:57 AM   #9
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
^^^ I just would like an updated map is all something that isnt screwing up my car..... I email Christian on saturday guess i should hear back on monday with an answer he has the other two logs we pulled the other day also
Old 07-24-2006, 10:43 AM   #10
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
jeez, it flows no air, makes no power, knocks like hell... wtf?
overdose is offline   Reply With Quote
Old 07-24-2006, 11:01 AM   #11
06rexwagon
Member#: 114730
[email protected]
Last time I talked to Christian at Cobb about the '06 he said they would be coming out with a newly revised map for the '06
Old 07-24-2006, 11:07 AM   #12
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
Well it is making power 226awhp and 270wtq but it could make way more, knocks like hell though...... i dont understand
Old 07-24-2006, 11:42 AM   #13
06rexwagon
Member#: 114730
[email protected]
Default TDC map logs
These are my logs after I got an e tune from TDC
[IMG][/IMG]
Old 07-24-2006, 12:11 PM   #14
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
Just got off the phone with COBB and they suggested to me that I should run the California Map and that it may be a fuel issue and I will need a custom map done to work with this furel we have here in Calgary
Old 07-24-2006, 03:34 PM   #15
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Is that the one with the backing plate similar to stock?
Cobb made the map on a bellmouth, FYI.
parker/slc/gc8fan is offline   Reply With Quote
Old 07-24-2006, 03:43 PM   #16
06rexwagon
Member#: 114730
[email protected]
good point parker. That DP doesn't have any bigger opening than the stocker.
Old 07-24-2006, 03:49 PM   #17
06rexwagon
Member#: 114730
[email protected]
Is this the DP you have? Look at the flange. [IMG][/IMG]
Now look at cobb's
[IMG][/IMG]
Old 07-24-2006, 04:40 PM   #18
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
Yes mine is the top one with the stamped flange but I have been told by various tuners that it is fine the difference between the bellmouth and the stamped flange is very little on our stock turbos, the outlet is the same size the difference if the bellmouth expands over the wastegate to allow mroe flow when your wastegate is open. That being said performance on a bellmouth is so-so because when your waste gate opens on both the bellmouth and stamped flange you get turbulance in the DP, the only way around this is to get one with a divorced wastegate side. I also know that this is not the cause of my problem because Jarrad knew what kind of DP i was running and he said that wont make a difference like what i am seeing. thaks for the thought though
Old 07-24-2006, 04:51 PM   #19
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
So your running a TDC map and not Cobb's?
That changes things.
Have you mailed him the logs?
Old 07-24-2006, 04:51 PM   #20
06rexwagon
Member#: 114730
[email protected]
I am, not the OP
edit, or are you asking me if I sent my logs to the OP?
Old 07-24-2006, 05:45 PM   #21
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
I was asking the OP. It hasnt been made very clear just what kind of map this is.
Custom maps are exactly that, custom.
Old 07-24-2006, 06:24 PM   #22
06rexwagon
Member#: 114730
[email protected]
He's complaining about cobb's map.
"2. Should I convince COBB that the map I got was crap and they should update for me?"
Old 07-24-2006, 07:34 PM   #23
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
I am running the stock Stage2 Base 91oct map
Old 07-25-2006, 08:31 AM   #24
mxboy15u
Member#: 105115
I don't know if wastegate interference could cause knock like that though. Looks like a fuel issue.
IL: LF Stage Two map Tyrael Mid West Subaru Owners Club Forum -- MWSOC 5 06-01-2007 08:31 PM
UTEC: Off the shelf Stage 1 and 2 maps... bpwatts UTEC 2 10-11-2006 05:54 PM
Stage Two and lovin it SubiePilot Canada Region Forum 7 01-22-2006 12:08 PM
stage 4 setup, off the shelf map, how fast am i? datdudedennis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-14-2003 12:54 AM
utec with stage two map is giving me knock. codean Engine Management & Tuning 14 10-31-2002 03:00 AM
