Old 07-24-2006, 02:14 AM   #1
Carlito2002WGN
Member#: 18914
2006 WRX
Black with some stuff
Default Installed AccessPort four days ago, car dead now
What the hell happened!?! Right before my boss arrived to go fishing, I dissconnected the battery in my car for a few minutes. I Started the car up (no problems at this point) and drove about a quarter mile and parked the car. After fishing for about 4 hours, I packed up and started to drive home. I noticed a little noise (thought it was a loose heatshield or something), and also noticed that the car hesitated and was low on power. As I drove on, the noise got louder and louder, and became apparent that it was not a loose heatshield. There was a horrible knocking from the engine. I've never heard anything like this before...I know there has to be some serious damage internally.
I am so drained from freaking out about what just occourred with my car, that I am falling asleep now, but I was hoping to get some feed back from some of you. What do you all think happened to my car?
By the way, I Have a Vishnu Up pipe, Vishnu Crank Pulley, Vishnu intercooler hoses, Bosal Downpipe, and third cat eliminator, along with AccessPort. I just got the AP, and flashed to stage II four days ago. Oh yeah, and my car is a 2005 Saabaru.
Please help with ideas! Am I going to need a rebuild? Maybe a new engine? What's the worst case scenario? What is the worst case scenario (cost) for a rebuild? Are there any Subaru Gurus around the Raleigh, NC area that I could convince to take a look at my car?
Feeling sick to my stomach...
Carlito
The next morning: I just wanted to add that I am not blaming the AP, or Cobb for what happened to my car. My car was however performing fine until I installed the AP, and then continued to perform fine until last night when I cleared the ECU's memory by disconnecting the battery.
Carlito2002WGN is offline   Reply With Quote
Old 07-24-2006, 09:25 AM   #2
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
AP Maps seem to run lean, did you get a check engine light? how hard were you driving your car? under or over 5000rpm? because it could have been that you were getting knock with the already lean map and then possibly a bad batch of gas.... did you just fill up your gas at a new station or with a different grade then what your map was designed? is this the 91 or 93 map? I can answer you further once I know these things. but basically you could have had a knock issue witch would cause a knock issue, it may or may not have messed up your engine depending on how long and how bad the condition was, reflash to stock and claim warrenty work?!?! worst case AFAIK bent valves is caused buy knock.
Chp_Stix is offline   Reply With Quote
Old 07-24-2006, 09:56 AM   #3
Carlito2002WGN
Member#: 18914
2006 WRX
Hi this is Carlos' wife...he wanted me to say thank you for the reply. I read your reply to him and he says he had jus put gas and within 10 miles after putting gas this problem happened. It was grade 93 at a bp station which he has used many times. The map he has is Stage 2, 93 octane.
Oh, he also said he probably did go over 5000rpm after he put the gas. It is a pretty safe assumption.
Thanks!
Liliana
Old 07-24-2006, 10:22 AM   #4
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
Ok with a knock issue it wont be apparent until over a higher RPM or wont do much damage because it wont be a big issue until a Higher RPM, it could have been a bad batch of gas, it wouldnt be the first time. I dont know what are good gas stations in the US though. I would suggest a reflash back to stock base map, and return it for warrenty work at your local dealer they cant say it was caused by your exhuast but they could blame the AP so unmarry your AP and limp your car back to the dealership at under 3000rpm to be safe and not cause any more damage either that or have it towed there. depends on how bad the knock is. have them check it out and fix it..... best/cheapest solution. I bet you had a detonation problem with bad gas and then when you punched it it caused knock damaging your engine.... just a thought
Old 07-24-2006, 10:40 AM   #5
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
warranty ftw
overdose is offline   Reply With Quote
Old 07-24-2006, 10:53 AM   #6
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
IMO, you probably damaged the engine by running all those other mods without putting on EM first. The 04-05s are known to run stoic under boost before onset of Open Loop, after putting on an Uppipe and downpipe+the third cat eliminator, you were probably running lean for far longer than what was programmed by subaru.
The problem didn't show up until you flashed stage 2 which upped the boost on an already damaged engine.
Old 07-24-2006, 12:03 PM   #7
Carlito2002WGN
Member#: 18914
2006 WRX
Thanks for the info but actually all mods were done at once.
Old 07-24-2006, 01:06 PM   #8
NoCalSubie
Member#: 94301
How hard did you punch it and did you get it tune?
NoCalSubie is offline   Reply With Quote
Old 07-24-2006, 01:30 PM   #9
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
I am gonna vote crank pulley on this one
scoobdude is offline   Reply With Quote
Old 07-24-2006, 02:59 PM   #10
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
No check engine lights?
You can try un-installing the AP, see if that changes anything.
It sounds like there has been alot changed in your car recently, that means alot to check out.
parker/slc/gc8fan is offline   Reply With Quote
Old 07-24-2006, 03:02 PM   #11
sperry7
Member#: 110079
06 WRX
Black on Black
^ because it is underdriven? I doubt electrical issues from a pulley would cause that severe knock. Maybe not though, who knows.
sperry7 is offline   Reply With Quote
Old 07-24-2006, 03:06 PM   #12
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
crank pully can come loose and cause a knocking noise. Trust me i have experienced it first hand (on a small block 350 though).
Check that first as its easy to. But, if the bolt snapped, gooooood luck
Old 07-24-2006, 10:27 PM   #13
sjs0433
Member#: 86061
usually the AP maps are really rich not lean. I know too many people that have had problems with pulleys....that is something I will never put on my car....I don't care if it adds 20whp. Unless subaru makes it, it won't be going on. Those things usually have to be so perfectly balanced. I know a guy that had one....not a subaru, but still.....well it through off the oil pump and after about two minutes of driving without a working oil pump the engine was about as dead as they get.
sjs0433 is offline   Reply With Quote
Old 07-24-2006, 10:44 PM   #14
sperry7
Member#: 110079
06 WRX
Black on Black
Wow I haven't heard that before thanks for the tip. I thought it was pretty much a bullet-proof mod if you didn't opt for the underdriven variety...
Sorry for your problems man, it always sucks to have problems with your car especially when you have to explain why your $2,000 "upgrade" messed up your car to your wife.
Old 07-25-2006, 12:50 AM   #15
Carlito2002WGN
Member#: 18914
2006 WRX
Default Underdrive Pulley
I'm not saying that it is impossible that the pulley had something to with my problems, but:
I installed the pulley at about 2000 miles (car has 56,000 now), and now all the sudden when I add the AP to the mix, I have a problem. Also, I had this exact same pulley on my 2002 WRX for about 40,000 miles with no problems. I just don't get it.
The Pulley and the intercooler hoses are the only mods that I did to my car before installing the AP. Once I got the AP, I installed all of the exhaust parts and then the AP and flashed to Stg2 93.
The thing that keeps bugging me is that all of my problems occured immediatly after reseting the ECU via battery disconect. This should not have caused any problems, right?
Carlito
Old 07-25-2006, 12:55 AM   #16
Carlito2002WGN
Member#: 18914
2006 WRX
Default Timing belt
Guys, what would be the symptoms of a bad timing belt? Not one that broke, but rather one that slipped a little or something. Like I said, I am at 55k miles...isn't it about time for me to replace it?
Carlito
Old 07-25-2006, 09:04 AM   #17
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
If you timing belt jumped you car would run like crap. Why don't you try to turn it on to see where the noise is coming from (oil pan, front, heads, tranny, exhaust). It could be that your crank broke. could be your exhaust hitting something. Could be a thrown rod.
But, don't debate waht it could/could not be until you go check stuff. Its hard enough to diagnose a noise over the interweb, go get us soem more info so we can help you.
Old 07-25-2006, 12:46 PM   #18
NoCalSubie
Member#: 94301
Carlito
Your car is working a lot harder now with AP. Your getting a lot more horses then before so that could of losses the pully or something. Doesn't hurt to check it's your car.
Old 07-25-2006, 02:31 PM   #19
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
Could be bad gas, not sure how loud this noise is but you never know.
Agkelos is offline   Reply With Quote
Old 07-25-2006, 02:39 PM   #20
Carlito2002WGN
Member#: 18914
2006 WRX
Hi guys,
Thanks for all the info. As far as checking to see where the noise is comming from, I have tried. I was not looking for you all to do a complete diagnosis of my vehicle over this message board. Just looking for a little help and some ideas.
This might sound rediculous, but I can't tell where the noise is coming from.........because of the NOISE. It is so loud, and sounds like it is coming from the heads one moment, and then the block the next. It is definitely not the exhaust, and the pulley is on nice and tight.
I may use this as an excuse to step up to a 2.5 Any ideas of the cost of such a venture (excluding the cost of the engine it's self)?
Thanks,
Carlito
Old 07-25-2006, 02:55 PM   #21
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
So just to verify you checked the bolt on the pulley or did you just check it with your hands?
did you try to wiggle the exhaust? I know mine makes a kncking sound by the rear end.
Also, turn it on and push in the clutch. See if the noise goes away. If it does you know its AFTER the tranny. If its automatic, you can unbolt the TC from the flywheel to see if its still the motor.
Next step is a compression check! <eek!>
Old 07-25-2006, 05:55 PM   #22
Damon
Member#: 2902
i think you are jumping to conclusions there. the engine may be messed up, but are you sure of it yet? at the least take it to a trusted mechanic or something and have it professionally diagnosed. it may be fixable. for an engine swap you are looking at $3k easy.
i woke up and cranked my 01 RS one morning and the engine was running HORRIBLY. i just knew somehow my block was cracked or i had a major problem because it was running so ragged.
it took a while, but finally diagnosed i had a plug wire go bad. a plug wire.
good luck to you.
Damon is offline   Reply With Quote
Old 07-26-2006, 12:22 AM   #23
SQB SNX
Member#: 74500
Take a look at your oil. Drain it and look for copper looking bites. If no big chunks are visable, shine a light on it and see if it has a sparkle to it. That will let you know on the spot if you spun a berring. I went through 2 engines using my AP with off the shelf maps. I got it dyno tunned last week and my AFR was in the 12s. If you have not killed your engine, I would take off the AP and get maps make by a tunner. Just my 2cp
SQB SNX is offline   Reply With Quote
Old 07-26-2006, 08:37 AM   #24
Carlito2002WGN
Member#: 18914
2006 WRX
I think I've come to that same conclusion. When I get the car back on the road, which ever engine resides in the bay, I will get it Protuned! I know that some guys can probably go 100k miles with an off the shelf map and have no problems, but I also know that is not something that one can count on. Definitely woth the $$.
Old 07-26-2006, 09:45 AM   #25
subieworx
Member#: 47769
Definitely get tuned. I recently was tuned, but mine was running way rich with the OTS map. Mid 10's at higher RPM's.
subieworx is offline   Reply With Quote
Just installed new pads and rotors 2 days ago..... kris84 Mid Atlantic Impreza Club -- MAIC 17 12-24-2007 08:15 AM
Snowing 3 days ago. Now it's 80 degrees TheSilverFox Texas Impreza Club Forum -- TXIC 8 04-11-2007 03:28 PM
Omori EGT installed two days ago and already gone!!!! BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-11-2005 06:11 AM
ok... two days ago it was almost 70.... now its snowing KevinHeist Texas Impreza Club Forum -- TXIC 19 12-23-2004 12:33 PM
It's a four-day work week followed by a four-day weekend. gongzero Off-Topic 26 08-31-2004 01:44 PM
