Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 07-26-2006, 02:13 PM   #26
Assassin4457
Member#: 96773
04 WRX, RIP GC8
Since this is kinda the theme here I'll throw in a Q in this thread.
Im planning to get an AP when I buy my WRX (few weeks now) and I want to go to Stage II. I understand that this is a DP and Catback system, plus the AP correct ?
I was wondering, should I install the exhaust system THEN instal the AP ? Or vice versa ? Is it safe to instal the exhaust before the AP ? What if I wanted to add an up-pipe into the mix ? would the OTS Stage II map be no good at this point ?
Any info is appreciated. To sum it up im just asking which parts can I add safely while using the OTS Stage II map ? Also Ive read the Stage II map is designed for a CATLESS DP and catback exhaust. If I use Cobb's DP WITH their high flow cat, am I going to run into issues ?
BTW my WRX will be an '04 if this makes a difference.
Assassin4457 is offline   Reply With Quote
Old 07-26-2006, 02:20 PM   #27
NoCalSubie
Member#: 94301
Install the exhaust first then flash stage 2 if it's 1-2 weeks difference. After installing the exhaust take it easy. Why not just wait and do it all at once just to be safe. But you can flash to stage 1 first and after the exhaust install flash to stage 2.
NoCalSubie is offline   Reply With Quote
Old 07-26-2006, 02:55 PM   #28
Assassin4457
Member#: 96773
04 WRX, RIP GC8
I was going to instal the exhaust then flash with the AP immediately. But what do u mean take it easy after I install it ? Is there a certain amount of time i should drive conservatively after doing so ?
How about up-pipes ? If I install that will my stage II OTS map be doing me no good ?
And also I'll re-ask, they say the Stage II is designed for catless DP. If I get the high flow catted DP from Cobb will this still be ok with the stage II OTS map ?
Old 07-26-2006, 03:17 PM   #29
NoCalSubie
Member#: 94301
Oh...I thought you only can get one or the other. In that case it don't matter which is installed first. Catted dp is fine with stage 2. You could install a up pipe or not don't matter but you do benefit from it. Change out the up pipe or get a gutted one since you replacing dp anyways. Half the work is alright done from the dp.
Old 07-26-2006, 03:25 PM   #30
Assassin4457
Member#: 96773
04 WRX, RIP GC8
ok so final word, changing the DP to a catless perrin is ok using the provided stage II maps correct ?
Old 07-26-2006, 03:39 PM   #31
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
yes. <stupid character limit>
scoobdude is offline   Reply With Quote
Old 07-26-2006, 03:44 PM   #32
Assassin4457
Member#: 96773
04 WRX, RIP GC8
S*** im sorry, I meant to say its ok to switch for a Catless UP PIPE with no ill effects using the OTS Stage II Map ?
Old 07-27-2006, 09:51 AM   #33
Assassin4457
Member#: 96773
04 WRX, RIP GC8
Anyone ?
Old 07-27-2006, 10:35 AM   #34
Nemesis Digital
Member#: 119579
2004 WRX Wagon
San Remo Red
You should be fine, Cobb even says there shouldnt be an ill effects. Im getting my up pipe installed today, I already have a catless turbo back installed, plus my AP should be in this afternoon. Im flashing it tonight.
Nemesis Digital is offline   Reply With Quote
Old 07-27-2006, 01:00 PM   #35
Christian.
Member#: 87604
Assassin4457, the AccessPORT has not been engineered to be compatible with any other vehicle than a Subaru...I just wanted to make sure you were aware of that. I truly hope all is well with your vehicle, but I highly suggest you make sure the parts you use are engineered to work well with your vehicle. I am not trying to piss you off or insult you, but we have never tested the AccessPORT on a Saab so we have no idea if it even works.
Take care,
Christian.
Christian. is offline   Reply With Quote
Old 07-27-2006, 01:53 PM   #36
Assassin4457
Member#: 96773
04 WRX, RIP GC8
^^^^^ ??? Saab ? I dont drive a Saab, nor do I plan to. I dont remember mentioning anything about a Saab lol.
Old 07-27-2006, 02:47 PM   #37
socalwrxf4#15
Member#: 113116
2003 WRX
white
Originally Posted by overdose
warranty ftw
exactly, put back on all ur stock parts then tow it in and kick the ground and say idunno...
socalwrxf4#15 is offline   Reply With Quote
Just installed new pads and rotors 2 days ago..... kris84 Mid Atlantic Impreza Club -- MAIC 17 12-24-2007 09:15 AM
Snowing 3 days ago. Now it's 80 degrees TheSilverFox Texas Impreza Club Forum -- TXIC 8 04-11-2007 04:28 PM
Omori EGT installed two days ago and already gone!!!! BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-11-2005 07:11 AM
ok... two days ago it was almost 70.... now its snowing KevinHeist Texas Impreza Club Forum -- TXIC 19 12-23-2004 01:33 PM
It's a four-day work week followed by a four-day weekend. gongzero Off-Topic 26 08-31-2004 02:44 PM
