Old 07-24-2006, 02:16 AM   #1
mars636
Member#: 74547
2005 WRX
WR Blue
Default STi Pinks injector scale
I am trying to scale my injectors for my car I have a 05 wrx with a VF34 and STi pinks, I am just wondering what number is everyone using for Sti pinks in the injector scale
mars636 is offline   Reply With Quote
Old 07-27-2006, 03:44 AM   #2
dElKwOn
Member#: 71184
Chapter/Region: HIIC
2002 ewg'd vf-34'd
GDA AMS Tuned !
don't know if this is gonna help you at all , but my injectors are scaled @ 4820.of course this my not work @ all for your car.it takes awhile to get the scaling dailed in.just try to get the A/F correction & A/F learned as close to +/- 5% as possible.it doesn't have to be exact,just a close as possible.for example if your A/F correct. is -4% & your A/F learned is +3% it falls withnin the +/-5% range.also your gonna need to reset the ECU a few times to get the A/F learned back to 0.BTW do you have an intake on the car? if so put the stock air box back on.get the injectors scaled than you can tune for the intake.
dElKwOn is offline   Reply With Quote
Old 07-27-2006, 12:04 PM   #3
mars636
Member#: 74547
2005 WRX
WR Blue
I do have the stock intake. I did get the a/f within the +/- 5% but my a/f ratios were off from what i was aking for. Then i checked the A/F imediate and learned again and they were way off. Just seems like my a/f is closer with a larger scale number. I though that my number should be closer to what you have considering how much these are suopposed to flow.
Old 07-29-2006, 10:31 PM   #4
dElKwOn
Member#: 71184
2002 ewg'd vf-34'd
GDA AMS Tuned !
i almost forgot , but are you running a walboro 255?i'm currently running the 255.or i could just be that each batch of injectors flow different from each other.
Old 07-29-2006, 10:52 PM   #5
mars636
Member#: 74547
2005 WRX
WR Blue
I do not have a fuel pump. still running the stock one. I just cant believe that they change that much fir the same injectors
Old 07-30-2006, 12:44 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....try 4920
Old 07-30-2006, 09:57 AM   #7
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
also try and readjust your tip in values. Bigger injectors requires smaller numbers there too.
Here is a link to another discussion: http://www.wrxforum.com/cgi-bin/ulti...;f=15;t=000102
Here is the formula i gave in that thread:
em injector value:W
Tip in cell value: Y
Hacked injector value: Z
Z X Y
----- = approximate value
W
This is based on the theory that injector scaling and tip in numbers are based on lowering open time.
Example Using crazymike's number on an 04 WRX:
4200 x 151
----------- = 98.45
6442
6442 = oem value
4200 = crazy mike's value for correct idling
151 = oem number for top cell in tip in adjustment
98.45= new value for that cell.
You might wanna add a little bit on top of this just to play it safe. But if the relationaship between open time for constant fuel and tip in the same this formula should get you pretty close to teh ball park.
scoobdude is offline   Reply With Quote
WTB: STi pink injectors/ 07 STI injectors/ 06 WRX injectors bwco VIC Private Classifieds 8 06-19-2013 10:40 PM
FS: Sti Pink Injectors 565cc (Topfeed) & Sti Pink Lateral link set for Wrx's wrxwagon253 NWIC Private Classifieds 17 10-04-2008 05:31 PM
SoCal:STi injectors, JDM STi pink injectors and 05 WRX injectors BlueFish Engine/Power/Exhaust 19 11-24-2007 10:30 PM
SoCal:STi injectors, JDM STi pink injectors and 05 WRX injectors BlueFish Engine/Power/Exhaust 25 11-12-2007 04:36 PM
STi Pink Injectors/06 Stock WRX injectors + walbro fuel pump + sti grille + Ebay TMIC KitchenerWRX Private 'Wanted' Classifieds 4 11-21-2006 12:51 PM
