Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 07-24-2006, 02:57 AM   #1
slitherJonesDM
Member#: 99612
Default need help
im running rich and have low boost. i was "tuned" at harmanmotive for 18lbs , they didnt calibrate my o2 sensor. im was thinking of getting my base map from phil and doing an autotune any suggestions? im lost any help will be appreciated thank you
slitherJonesDM is offline   Reply With Quote
Old 07-24-2006, 02:11 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
Phil has lots of maps at this point. He can get you pretty close with one of those maps, and yes autotuning will get you fine tuned in the off-boost and low-boost regions.
Old 07-24-2006, 02:22 PM   #3
slitherJonesDM
Member#: 99612
thanks for the help any other suggestions?
NEED help! 2.5RS in Central Jersey pMak26 Tri-State Area Forum 9 06-04-2010 08:50 PM
Anyone need help with an install? RubbleDTD Mid Atlantic Impreza Club -- MAIC 0 06-03-2010 05:23 AM
Hard Drive Recover Help much needed... ATA RAID 0 knowledge needed HELP PLEASE!!! 2k2 Off-Topic 63 12-24-2003 10:35 PM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 12:11 PM
Need help!Need flywheel bulletin from SOA.Please help. RallyeX General Forum Archive 3 06-01-2000 07:57 AM
