Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 07-24-2006, 12:49 PM   #1
macman2.0
Member#: 103443
2004 WRX Wagon
RED
Smile Used the high efficiency map
I had a 210mi round trip this weekend.
with the help of the cobb HE map, I accomplished it with 1/2 tank of gas.
(from 8 gallons to the "empty light")
It felt like i lost about 80-100hp while in-use. a very n/a feeling ride.
when in the upper rpms, it felt like an adequate street car. but in 5th gear at 60mph..It hardly builds revs. Though I only had a couple of moments that i wished for my power. Of course the difference in acceleration was startling when i reset my ecu back to the 93oct base map.
The site warns that it's not for agressive driving, though with 93oct i had no ping during "hard" acceleration. It was smooth, stock-like feeling, Just Slower.
If you KNOW you're not going to "drive it like you stole it" it's a GREAT way to
save some $$ on long trips. I'll be using it again.
macman2.0 is offline   Reply With Quote
Old 07-24-2006, 03:06 PM   #2
sperry7
Member#: 110079
06 WRX
Black on Black
I experimented with it as well and I liked it! However, I don't like to drive around with it lest I get shown up by some ricer. Not good.
sperry7 is offline   Reply With Quote
Old 07-24-2006, 05:55 PM   #3
Damon
Member#: 2902
just lean out the window and tell him you have to pull over real quick and flash to your protuned performance map.
Damon is offline   Reply With Quote
Old 07-24-2006, 05:59 PM   #4
sperry7
Member#: 110079
06 WRX
Black on Black
^^ goooooddd call
Old 07-24-2006, 06:37 PM   #5
k mier
Member#: 98000
05 sti [email protected]
The economy map made a whopping .2 mpg difference for me. For those that can not keep their foot out of it, it may be worth while. For those that drive easy and rarely hit boost, it amounts to basically nothing.
k mier is offline   Reply With Quote
Old 07-25-2006, 07:55 AM   #6
macman2.0
Member#: 103443
2004 WRX Wagon
RED
getting 210mi out of 6-7 gallons of fuel amounts to quite a lot, in my book.
Old 07-25-2006, 05:24 PM   #7
rjacobs
Member#: 80127
Ive gotten 250 out of half a tank of highway driving, cruise set at 75, windows down with my cobb stage 2 93oct. Like was already said, in cruise or if you keep your foot out of it the economy map does nothing, since all it really does is keep you from building much boost, only a few PSI, I think it is what ever the WG spring holds.
rjacobs is offline   Reply With Quote
Old 07-25-2006, 09:48 PM   #8
nate49509
Member#: 22452
2016 WRX
Pretty good. I think I might give it a try on the way up to LSPR this year. A 10hr drive should put it to the test. And if I don't like it I'll flash back to stage 2 before I head home.
nate49509 is offline   Reply With Quote
Old 07-26-2006, 09:55 AM   #9
subieworx
Member#: 47769
1/2 tank as based on what the fuel gauge indicates is not = to using half a tank of fuel by any means. 1/2 on the gauge for me from top down is about 9 gallons. 210 miles on 9 gallons is about 23.3 mpg which is lower than I get in my protned vf34 equipped car on the highway.
I used the econ map for three tanks to see what it would do. I saw an increase of .8mpg over those three tanks. Not enough to warrant having no power and not being able to enjoy my car. You only live once.
subieworx is offline   Reply With Quote
Old 07-26-2006, 10:35 AM   #10
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
The economy map is really only for long highway trips IMO. I put it on for a trip to eastern washington, and going over the mountains it kept the cruise control from going over wastegate boost. Almost 28mpg with the A/C on and the cruise set at the speed limit.
If you try to use it in the city to get slightly better mileage, then you bought the wrong car.
I have stage 2, can I use the fuel economy map? down_for_the_scooby AccessPort 9 08-20-2009 08:41 PM
Using the Cobb VF39 map with a VF43 DragginFrame Newbies & FAQs 3 06-22-2009 12:47 AM
High altitude users; how many use the HWG map? SonicYeller AccessPort 13 05-15-2007 09:32 PM
Wanted: VF39 compressor efficiency map ScoobyAficionado Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-04-2006 06:25 PM
Should i be using the stage 1 realtime map or just use the base map ? wrxhunter Engine Management & Tuning 2 06-10-2005 12:38 PM
