Old 07-24-2006, 07:35 PM   #1
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Default GM 3 BAR map sensor
Here's an interesting one.
Trying to adapt a 3 BAR map sensor using the ProTuner.
There's a Multiplier value and an offset values. Common sense dictates that if I do a simple proportional calculation that I should be able to use a value that will at least work properly with the vehicle.
Upon trying it, and verifying about half a dozen times that the wiring is correct, something stupid like the factory MAP sensor isn't plugged in, etc.; we still get a MAP sensor low input code and a MAP sensor range code. We know the sensor is actually doing it's thing because it's actually dropping based on the load it's seeing, etc.
One interesting thing is that a GM wiring diagram reports that the reference voltage bus is actually running 6 volts. vs our 5 volts.
Regardless, this is the same MAP sensor I remember reading about on these forums, I think it's the one TMS has posted in the past. So, the question is, what's the big voodoo?
The sensor is GM part number 12223861.
Thoughts? Or do any of the street tuners out there have a setting they've used in this app yet?
Thanks!
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 07-24-2006, 10:57 PM   #2
crazymikie
Member#: 56321
2006 Honda El Camino
Green
I'm pretty interested in this-
I don't think they give you the maps you need to adapt it in StreetTuner, so I've not tried it as of yet.
Here's another question- I can't seem to set boost targets higher than ~24psi for an 04 wrx. How do you get around this issue?
Thanks!
Mike
crazymikie is offline   Reply With Quote
Old 07-24-2006, 11:07 PM   #3
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Thanks!
Mike
A 3bar or 3.5bar map sensor.
04-06 sti Utec w/ map switch, gm 3 bar map sensor for speed density & tatrix cable methaddict Engine/Power/Exhaust 26 07-12-2008 12:47 AM
04-06 sti Utec includes map switch, gm 3 bar map sensor spd density & tatrix cable methaddict SCIC Private Classifieds 19 07-12-2008 12:47 AM
GM 3-bar map sensor with utec deluxsti Engine Management & Tuning 7 11-01-2005 03:17 PM
gm 3 bar map sensor White 2.5rs Private 'For Sale' Classifieds 9 10-09-2005 11:45 AM
GM 3-Bar Map Sensor EVOBOXR Engine Management & Tuning 2 04-02-2005 09:35 PM
