Old 07-25-2006, 03:50 PM   #1
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
Default spool and w/g maps
On the 04 wrx the w/g duty maps start at 2380rpms. Has anyone tried lowering this number (2200 maybe) with the same value to see if it has an effect on spool up?
scoobdude is offline   Reply With Quote
Old 07-25-2006, 07:40 PM   #2
Yoo Shin
Member#: 87327
2010 12 parsec Evo X
I still kill threads
bump for a good question. I'd do a VF39 swap if this could be done.
Yoo Shin is offline   Reply With Quote
Old 07-26-2006, 07:35 AM   #3
TJRCS
Member#: 59199
2008 STI
I guess you have ST, right??
2200rpm for stock turbo is still pretty starting point since it can spool fast from lower rpm. I have 18g turbo, so i set up my WDC's rpm column to (2400,3100,3500,3800,4200,5400,6300,6800). In this way, i have more control when turbo hits full boost.
TJRCS is offline   Reply With Quote
Old 07-26-2006, 10:40 AM   #4
Yoo Shin
Member#: 87327
Awesome. So when do you hit full boost?
Old 07-26-2006, 11:40 AM   #5
Tea cups
Member#: 103136
I don't think lowering the rpm will change the wastegate duties at all. Once you go above or below the rpm range, the ecu uses the values from the last row before you go over or under the range. Values in-between the range are interpolated, though. Tuners will modify the y-axis of the boost map if they want more resolution in a certain rpm area.
Tea cups is offline   Reply With Quote
Old 07-26-2006, 12:10 PM   #6
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
boost map starts at 1600 rpms.
WGDC map starts at 2380.
While interpolate values should work, what is the value for rpm and WGDC below these cells?
Old 07-26-2006, 12:41 PM   #7
Tea cups
Member#: 103136
Like I said, interpolation is used between the ranges. Outside of the ranges, the values in the last row (or column depending on what you are looking at) are used. So, for example, WGD% values at 2380 rpm are used for everything under 2380.
slow spool and vibration!! newgensti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-04-2006 03:28 PM
is turbo spool and stock intake louder in cold weather? jojotherider Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 02-20-2006 01:16 AM
High Det map and Low Det map darksands Engine Management & Tuning 7 06-04-2005 01:04 AM
Ok so what will a FMIC do to my spool and what effect on power output? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-01-2004 06:46 PM
regarding anti thef maps and real time maps for the accessport bubba03wrx Engine Management & Tuning 2 05-24-2004 11:01 PM
