Old 07-25-2006, 06:48 PM   #1
bannerd
Member#: 110771
2006 WRX
black
Default 2006 Wrx 5/mt
Hello,
I have about 1087 miles on my car and I notice my car shaking. Bascially what happens is I will be driving along in third and when I go to make the shift from 4,000rpms to 4th...as soon as I let off the gas the car shakes. It does this in 2nd gear as well...I'm thinking the pressure plate is sticking...my friend thought the same when he drove it. I took it to the dealer and I drove around with him and he said it was fine...even when I was with him I could feel the car shake.
So there is nothing wrong with my car? What do you guys think..
For more detail, I let off the gas and I fell the car shake maybe 2-3 times and it stops. Doesn't matter if I downshift or upshift still does it.
I might pull it this weekend and look at the clutch and plate as well as the springs to see if there is somthing wrong.
blah
bannerd is offline   Reply With Quote
Old 07-25-2006, 07:21 PM   #2
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
.....don't go "pulling" things if there's a problem. Let the dealer/SOA handle it under warranty. If your current dealer is unwilling to recognize there is a problem, then try another dealer. .....if that's not possible or inconvinient, try contacting SOA directly. You may also consider hooking up with a local member (with an '06) so you have something to compare against (to see if it's an actual problem). ....you shouldn't have to diagnose issues on your own especially with only 1087 on the clock.
Kean is offline   Reply With Quote
Old 07-26-2006, 05:06 PM   #3
bannerd
Member#: 110771
2006 WRX
black
Yeah, I was thinking last night...if it breaks then it breaks and I can get it fixed. Dealer already knows I had issues so it is marked.
Thanks Kean
Old 07-26-2006, 05:13 PM   #4
Kean
Member#: 25187
'08 Foz Prem TGM
Thanks Kean
...good luck. I hope it turns out o.k.
WTB 2006 wrx 5spd mt ecu octaYne Private 'Wanted' Classifieds 4 03-07-2009 12:57 PM
WTB: 2006 Accessport WRX 5/mt sduceatt MAIC Private Classifieds 3 02-18-2007 04:15 PM
WTB: 2006 Accessport WRX 5/mt sduceatt MAIC Private Classifieds 0 02-17-2007 11:14 PM
FS: Accessport for 2006 WRX w/MT BNastyer Engine/Power/Exhaust 6 08-24-2006 02:55 PM
WRX 5 MT Transmission With STi RA Gears MisterX Private 'For Sale' Classifieds 12 07-02-2004 11:34 PM
Message Board Statistics All times are GMT -4. The time now is 12:29 AM.
