Old 07-25-2006, 11:21 PM   #1
sketron13
Member#: 116158
2005 Legacy GT wagon
Default Silk thread in between crankcase halves...
So I'm in school to work on airplanes, and tonight we tore apart some 540 cid 6-cylinder Lycoming reciprocating engines. These engines use a thin layer of adhesive in combination with a single silk thread on the mating surfaces. Here's my question, does anyone know what Subaru uses to join the crankcase halves?
sketron13 is offline   Reply With Quote
Old 07-26-2006, 12:18 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Fujibond....
Old 07-26-2006, 11:11 AM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Originally Posted by Storm
Fujibond....
Hai!
Old 07-26-2006, 11:37 AM   #4
sketron13
Member#: 116158
Fujibond? I reckon they just use glue then...
Old 07-26-2006, 11:39 AM   #5
Hawk296
Member#: 14555
1995 Impreza L
Baja
At least it was a lycoming and not continental....
Hawk296 is offline   Reply With Quote
Old 07-26-2006, 07:37 PM   #6
shaggie
Member#: 36022
2000 08 OBS
Silverthorn Metallic
My shop is hiring if your near CT. I work for Bombardier Aerospace.
shaggie is offline   Reply With Quote
Old 07-26-2006, 11:17 PM   #7
sketron13
Member#: 116158
That would be awesome but I'm in ATL right now. Really want to go to Alaska and work... Bombardier, so you work on Learjets or do you manufacture them?
Oh, and it was an IO-470 D, not a 540.
Old 07-26-2006, 11:35 PM   #8
Hawk296
Member#: 14555
1995 Impreza L
Baja
so it was a conti? And to get back on topic, Yes, subaru uses a grey goo around the perimeter of the crankcase halves.
Old 07-26-2006, 11:37 PM   #9
wagman01
Member#: 3894
2002 WRX Wagon
Battlewagon Black
I was told by SOA that they use gorilla glue.
wagman01 is offline   Reply With Quote
Old 07-27-2006, 12:17 AM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
It's just a silicon sealant... Fujibond = Yamabond = Hondabond = Grey RTV pretty much. For the oil channels and whatnot, they use o-rings, though.
Old 07-27-2006, 12:30 AM   #11
sketron13
Member#: 116158
Alright, I'm glad I asked now.
Old 07-28-2006, 11:12 PM   #12
i2onin
Member#: 94807
'98 impreza RS
RBP
so how do you break the case halves apart?
screwdriver and hammer?
i2onin is offline   Reply With Quote
Old 07-29-2006, 12:51 AM   #13
sketron13
Member#: 116158
Can't do that on aluminum without messing it up. I just pulled real hard on the mag. holes and pulled her apart. You gotta have someone there to catch the cam and a gear.
Old 07-29-2006, 12:34 PM   #14
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
While I was splitting junk blocks, I found that using a small bottle jack across the backside of the motor worked pretty good. Very little, if any damage, too. I imagine with a few wooden blocks, you could do it without a sign of using force. I just used it to crack the rearside apart, the rest comes along pretty easy, but (again) I used force to pry it apart just to make it easy, but that usually marked up the two sections of case from prying.
Old 07-31-2006, 08:39 PM   #15
i2onin
Member#: 94807
'98 impreza RS
RBP
sweet! that is an awsome idea.
i'm off too the bat cave!
Why am I building so much pressure in my crankcase? bmxpunk Built Motor Discussion 45 08-28-2009 11:30 AM
possible to leak coolant between block halves? jasona Normally Aspirated Powertrain 1 05-16-2006 12:40 PM
Any silk screeners in the SCIC? Jimmy S. Southern California Impreza Club Forum -- SCIC 12 04-26-2006 10:29 PM
Trailer storage in Atlanta, Athens, or in between Penguinking South East Region Forum 0 07-07-2005 10:57 PM
thread in newbie-forum more off topic than thread in offtopic-forum Caddy Daddy Off-Topic 1 04-08-2005 01:15 AM
