Old 07-25-2006, 11:21 PM   #1
G.Subramaniam
Member#: 64528
Default Port-Polish heads vs Fuel efficiency
How does port polish heads affect fuel efficiency and emissions
G.Subramaniam is offline   Reply With Quote
Old 07-26-2006, 12:51 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
It make to better.
Old 07-26-2006, 11:10 AM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
When I installed my Pnp'd heads I saw about a 2mpg increase from my previous set up. With just the spicy cams, my car ran super duper rich above 4500rpm. With the addition of the heads and greater air flow, my AF's came down to what I would consider a marginally rich ratio, and thus the better gas mileage.
I passed emissions with no problems with the cams 2 years ago. I have to test again in about 6 weeks, and it will be with the heads installed. I will report back once I do, but I fully expect the car to still pass...
EJ18 - port/polish heads and intake manifold for MPG gains DoinkMobb Normally Aspirated Powertrain 15 08-14-2009 02:13 PM
port/polish wrx heads vs. stock on hybrid build ki11switch Built Motor Discussion 11 08-25-2008 09:30 PM
V7 big port heads vs. ported USDM 2.0L heads kellygnsd Built Motor Discussion 25 11-02-2007 10:44 PM
Porting, polishing head and throttle body? ratedvideowrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-24-2004 07:31 AM
Dual port EJ22 heads VS single port EJ22 heads FuJi K Normally Aspirated Powertrain 23 05-06-2004 12:39 AM
