Old 07-26-2006, 03:02 AM   #1
Hossamk
Member#: 95718
Default Heavy steering after changing the tyres
Dear All
i have an Impreza 1.6L it comes with 14" wheels, last week i changed the Wheels to 16" Alloy i bought the correct ET 55 as i got an original Subaru Alloys, i also got the correct tyres 205/50 Kumho
i am feeling heavy steering and the steeringwheel tend to turn left if i move slowly or pass by a pumpy road as if the left front tyre is heaver than the right front.
i adjusted everything in the wheels before i install it the car moves in a perfect straight line when i am driving.
should i adjust something or is that from a bad tyres?
Hossamk is offline   Reply With Quote
Old 07-26-2006, 03:41 AM   #2
nate49509
Member#: 22452
2016 WRX
It's normal. Not sure what width tires you had on before. 185 maybe? But now you've got more tire in contact with the road so there's going to me a little more heft. But you also might need an alignment.
I always notice a difference when I go to my winter tires from summer tires. 225 to 205 and vice versa.
Edit: Wrong forum too. Wheels and Tires next time.
nate49509 is offline   Reply With Quote
Old 07-26-2006, 06:47 AM   #3
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Also, steel to aluminum by material is weight reduction, but material from a 14" diameter to a 16" diameter increases your moment of inertia.
I definitely notice the difference between my 205 Blizzaks and my 225 Dunlops as well.
LetItSnow is offline   Reply With Quote
Old 07-26-2006, 11:33 AM   #4
Hossamk
Member#: 95718
Default does that means that it is normal
does that means that it is normal?
Old 07-26-2006, 02:10 PM   #5
wagonman
Member#: 971
it is perfectly normal. My winter tires are soft and easy to steer while my r-s2's feel really heavy.
I wouldn't worry about it, you will get used to it and like it after a while.
wagonman is offline   Reply With Quote
Old 07-26-2006, 03:16 PM   #6
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
2012 Tribeca Ltd.
This is exactly what happened to me when I went from stock 16" 205s to 18" 225s. The car developed a pull. Alignment cured that problem. I would just go and get it done. If your steering is off, your toe is probably wrong now and your camber is most like not correct either. Toe would account for sluggish steering. Report back after you get your alignment done and let us know if your problem is gone.
Ziggyrama is offline   Reply With Quote
Flashing lights after changing the battery? Jejunum Normally Aspirated Powertrain 5 11-27-2005 10:32 PM
Flashing lights after changing the battery? Jejunum Electrical & Lighting 1 11-27-2005 05:56 PM
"WOMEN have just 125,000 years to learn how to change a tyre and assemble furniture" TyrannoSullyRex Off-Topic 8 10-14-2003 04:31 PM
Changing the ATF in the power steering system 98kPa Service & Maintenance 4 08-06-2002 12:26 PM
