Old 07-26-2006, 07:18 AM   #1
BossGVR4
Member#: 1541
2001 Lexus GS430
Black Onyx
Default Freshening Up a Longblock before install
I bought another NASIOC members EJ2.5 SOHC longblock w/ 70K on it and will be swapping it into my 99 Forester.
I was planning to do the following to freshen up the block:
~ headgaskets
~ ARP headstuds
~ timing belt, pulleys, and tensioner
~ water pump
Would you guys suggest anything else ?
Thanks,
Dave
BossGVR4 is offline   Reply With Quote
Old 07-26-2006, 08:01 AM   #2
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Cam seals, valve cover gaskets, any seal that you can replace will be a good thing. Radiator hoses, thermostat, rubber vacuum and coolant hoses, top off the R-134a, fuel line hoses and any other rubber hose that might have degraded over time.
AJ711 is offline   Reply With Quote
Old 07-26-2006, 08:48 AM   #3
Jeromee
Member#: 88016
2004 Forester
Rear main seal. head gaskets, timing belt, cam seals, valve cover gaskets, spark plug gaskets, water pump... the ARP head studs aren't needed, its not like you're building a race car. You might want to spin all the rollers for the timing belt and listen for noise, if they're noisey, replace emm.
Jeromee is offline   Reply With Quote
Old 07-26-2006, 09:18 AM   #4
Skidd
Member#: 1853
GC6 Supercharged
STM
You might consider the oil-pump o-ring. It was the reason for the leak in my motor.
And if your looking for a few more ponies, while you've got it all apart, I'd send your cams to Delta Cam for a regrind. I just finished mine last weekend, and I don't regret it for a second. I'm planning to do a full writeup on my swap this comming weekened, but I'll give you the short short version... Pros: Smoother mid-top power, revs to redline easily, more HP no question. Cons: Rough idle. Not bad like it's going to stall rough, but a bit rough none-the-less. I also have a CEL but I"m 90% sure it's due to my OBX Header and missing Cat. The CEL comes and goes. I'll keep my eye on it.
Skidd is offline   Reply With Quote
Old 07-26-2006, 09:20 AM   #5
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
R&R the oil pump and retighten the machine screws on the back side. Replace the crank seal and o-ring (usually come together). Also, replace the rear main seal & R&R the the cover plate(s) at the rear. The oil pump and rear cover are sealed on with Fujibond.. might as well clean off the old stuff and slap on some new.
Also, adjust the valve lash while you've got the valve covers open.
Freshening up the RS RFoy91TSi Member's Car Gallery 15 01-08-2010 06:01 PM
So I freshened up my 4/2 pots... Jsun Member's Car Gallery 34 11-12-2009 08:31 AM
Need a block bored and freshened up. Where in Fort Worth? wcbjr Texas Impreza Club Forum -- TXIC 2 09-23-2006 12:08 PM
Clean a used up pipe before install? Super Nintendo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-10-2005 07:58 PM
Heat Shield Tape UP before install? KJY9 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-25-2004 10:43 AM
