Welcome to the North American Subaru Impreza Owners Club Wednesday July 30, 2014
Old 07-26-2006, 08:10 PM   #1
WildBlueWRX
Member#: 111164
2008 Legacy 2.5GT
Obsidian Black Pearl
Default whats the difference?
this is prolly a stupid question, but everyone has been really helpful to me, so i know ill get a straight answer. anyway....what is the difference between a COBB base map and a real time map? i know COBBs answers, but it didnt make much sense to me.
WildBlueWRX is offline   Reply With Quote
Old 07-26-2006, 11:01 PM   #2
csewrx
Member#: 85254
2005 Impreza WRX
Cobb Stage 2, Rally Blue
Well here is what I read from Trey Cobb on their forum. It was very helpful and gave me the answers I was looking for.
http://www.wrxforum.com/cgi-bin/ulti...;f=11;t=001121
Base Map: The permanent stored programming in the ECU for stuff like timing, boost control, etc based on the mods you have for the map you're loading. If you disconnect the battery, the base map is reverted back to. Only when you flash a base map or revert it to stock does it count towards the flash count on the ECU.
Realtime Map: A small portion of the base map can be altered with a realtime map but the variables are very small that can be changed. If you disconnect the battery, it will revert back to your base map and the realtime variables will be erased. This will not count towards a flash.
Read that long post and it will answer a lot more questions than the main website. Enjoy.
csewrx is offline   Reply With Quote
Old 07-27-2006, 11:56 AM   #3
WildBlueWRX
Member#: 111164
2008 Legacy 2.5GT
wow, what a long post. sorta confusing, but atleast it answered all my questions. thanks!
Whats the difference in the 02-05 vs the 06-07 transmissions fateo66 Transmission (AT/MT) & Driveline 11 05-27-2008 08:51 PM
Whats the difference? Whats the better choice? ShadowWRX77 Factory 2.0L Turbo Powertrain 3 07-15-2006 09:23 AM
Whats the difference between the TD04H and the TD04L? STi-Nismo Dood Normally Aspirated with bolt-on Forced Induction Powertrain 1 03-21-2004 08:42 PM
whats the difference in the 1990-94 turbo legacy block to the 22b block STEALTH-WRX Factory 2.0L Turbo Powertrain 3 09-08-2002 10:52 AM
WRX: whats the difference between the wagon and the sedan WRXDrew Interior & Exterior Modification 4 08-17-2002 11:21 PM
