Old 07-27-2006, 03:02 AM   #1
evil02wrx
Member#: 101260
04 WRX STi
Default Rubbing sound on right turns
When I make right turns, I get a rubbing sound almost like when you have no brake pads left and you tap the brakes lightly and get the rubbing but not the grinding. The rubbing isn't from the brakes though. It just happens on right turns though. I am thinking a bad wheel bearing?
evil02wrx is offline   Reply With Quote
Old 07-27-2006, 03:16 AM   #2
MarylandEcstasy
Member#: 103518
2011 Subaru WRX
Hm.....is your car lowered by any chance?
Nick
MarylandEcstasy is offline   Reply With Quote
Old 07-27-2006, 08:47 AM   #3
IIdiceII
Member#: 90438
oooo!!!
I just started to get the same sound lol.
im lowered. dont think its rubbing though. but if it is... thats just an excuse to roll my fenders.
when ever i make hard right turns I get a high pitched rubbing/squeeling sound from the front driver side wheel area.
i thought it was the brake dust shield or something but cant figure it out.
IIdiceII is offline   Reply With Quote
Old 07-27-2006, 04:26 PM   #4
IIdiceII
Member#: 90438
bump...anyone?
Old 07-27-2006, 07:00 PM   #5
dibblejr
Member#: 94070
05 LGT
OP not enough information for you to get a informed opinion. Give us a little more info, are you lowered ect.
dibblejr is offline   Reply With Quote
Old 07-27-2006, 07:09 PM   #6
Jeromee
Member#: 88016
2004 Forester
It could be the backing plates on the rear brakes, they tend do to it with age. rust builds up behind them and pushes them out into the rotor.
Jeromee is offline   Reply With Quote
Old 07-27-2006, 09:41 PM   #7
IIdiceII
Member#: 90438
well....it just started to happen to me and seems to be getting louder. my suspension mods are...
KYB AGX
tanabe gf210
helix front sway bar
steering rack bushings
thats all for the front of the car.
it seems like whenver most/some of the weight of the car is put on the front left wheel, it makes the sound.
like when going around a turn somewhat fast.
Old 07-27-2006, 11:07 PM   #8
DUBCSTi
Member#: 121299
2006 STI
I had and '02 WRX that endured some brutal winters and lapses in sanity.... made like a "womp womp womp" almost rubbing after I ignored it for a month, started out innocently enough. evil, my '02s bearings were done by 70k, don't know what's on yours but i'd bet the bearings for sure. get them all replaced at once, it'll be a little pricey but worth saving the headache 3 more times.
DUBCSTi is offline   Reply With Quote
Old 07-28-2006, 02:42 AM   #9
evil02wrx
Member#: 101260
04 WRX STi
Sorry for the late response. My car is not lowered. I have 17" prodrive rims on stock suspension. My car has 62,1xx miles. It will only make the sound on hard right turns but not on gradual ones. It sounds exactly like a bad brake pad when you apply a little pressure. Its like a metallic rubbing. I was under the car. All of the axles look good. No grease leaking from them. The car also wobbles a little and pulls very slightly to the right when you apply the brakes. I think I also have a warped rotor on the passenger side. This sound only started about 3 weeks ago and I've only put about 45 miles on it since then.
Old 07-28-2006, 06:26 AM   #10
IIdiceII
Member#: 90438
thats exactly the same thing for me^^ good descritption
doesnt sounds like a wheel bearing at all.
Old 07-28-2006, 06:35 PM   #11
Matt89
Member#: 121359
Did you put larger tires on you wheels? The rubbing noise could be comming from your tire rubbing on the wheel well. Naturally when you turn right the body roll will be pushing the left side of the car down. There is also more weight on the left side (your in the drives seat). Check your wheel well for rubbing. This happened to me when I put tires that were a hair to big.
Matt89 is offline   Reply With Quote
Old 07-28-2006, 06:41 PM   #12
IIdiceII
Member#: 90438
i doubt its rubbing...
225's on a sedan. if anything the rear would rub first.
plus the noise wouldnt get louder.
Old 07-28-2006, 06:54 PM   #13
Matt89
Member#: 121359
o, didn't read the 225's. haha ya, well thats what I get for skipping a few posts.
Old 07-28-2006, 07:03 PM   #14
97obw
Member#: 109426
97 OUTBACK
mud brown
torque bind....check your tire pressure
97obw is offline   Reply With Quote
Old 07-29-2006, 07:48 AM   #15
IIdiceII
Member#: 90438
maaaaybe...ill check later. power steering fluid maybe?
Im gonna flush as much of the power steering fluid out using a turkey baster and refill with some mobil ATF. ill see what that does.
Old 08-03-2006, 02:24 AM   #16
evil02wrx
Member#: 101260
04 WRX STi
Sorry for dredging up this post, but I drove my car around the block the other day and its not as loud. Need some more suggestions before I try to tackle this myself. I have the same tires on the car for a while so rubbing would have happened well before this. I've had tires rub on other cars and it sounds nothing like the sound I described in my earlier posts. It sounds almost like its coming from the rear passenger wheel, but I'm not certain.
Old 08-03-2006, 04:12 AM   #17
subymanny04
Member#: 114614
08 EVO X
Charcoal Gray
it may be rubbing on the splash guard, are u sure that ur splash guard is tucked in all the way?
subymanny04 is offline   Reply With Quote
Old 08-08-2006, 03:05 AM   #18
evil02wrx
Member#: 101260
04 WRX STi
SOrry again for the late response(computer trouble) THe sound is totally metallic.
Old 08-09-2006, 01:04 AM   #19
CE28
Member#: 42174
I have the same thing too and trying to figure out if it's a bad bearing. It sounds the a metal rubbing noise. Checked under the car twice and made sure nothing's rubbing. The sound just gets worse and worse. First is only on the full lock turns, and now it makes the noise when i am not even close to a full lock turn.
Anyone else knows if this could be caused by a bad bearing?
CE28 is offline   Reply With Quote
Old 08-09-2006, 03:34 AM   #20
evil02wrx
Member#: 101260
04 WRX STi
Thats what mine started out as. The noise would only happen on full lock turns and now it is doing it on normal turns. It is extremely annoying. It totally sounds like bad brakes, but it happens when the brakes aren't even applied. The rear rims aren't extra hot after driving like if you had a frozen caliper and my rear pads have plenty of meat left on them. Oh yeah, splashguards are not rubbing.
Old 08-09-2006, 03:49 AM   #21
SilverE2
Member#: 105796
2006 WRX
Pastelito Racing
I had the EXACT same problem. Read my post here:
http://forums.nasioc.com/forums/show....php?t=1046185
I finally took it to the dealership to have it checked out. What happened was that my downpipe had become loose and was rubbing against my transmission. I can almost guarantee that's what has happened with you as the symptoms are exactly the same. Only on a right turn.
SilverE2 is offline   Reply With Quote
Old 08-10-2006, 02:18 AM   #22
evil02wrx
Member#: 101260
04 WRX STi
GOing to check the dp right now. It sounds like its coming from the rear pass. wheel.
Old 08-10-2006, 04:08 PM   #23
z&cobb
Member#: 12344
2002 2JC
blue
Yeah, an independent Subaru mechanic, passed that along to me after I did my brakes myself. They always grind off a little of the corrosion back there, since the tolerances are pretty tight. After a bit of aggressive cornering I made the noise go away.
z&cobb is offline   Reply With Quote
Old 08-10-2006, 04:23 PM   #24
WRXTuan
Member#: 61294
04' WRX
4eAT San Remo Red
I had the exact same problem 2 days ago, a metal on metal sound when I make right turns. The sound was coming from my front left side and i lifted my car on jack stands and rotated each wheel. The front left side was metal on metal when i turned the tire and i saw the backing plate of the front left was rubbing against the back side of the rotor, I just bent it out of the way and the problem was fixed.
T.Vo
WRXTuan is offline   Reply With Quote
Old 08-10-2006, 05:03 PM   #25
CLR4ILS
Member#: 107320
2009 Legacy
Grey
I JUST HAD THIS PROBLEM 3 TIMES IN A ROW!! Both the mechanic and I thought it was the wheel bearing, but that was fine, then he rotated the cv axle and that was what it was! I got it replaced and the noise went away until something hit it and bent the seal ring. Now the noise is back!
Good luck!
CLR4ILS is offline   Reply With Quote
Loud Rubbing/Scraping on Left turns LickwidS0ap Newbies & FAQs 15 09-17-2008 11:38 AM
Rubbing noise only on right turns... WRX Shenanigans Newbies & FAQs 1 08-24-2006 07:18 PM
Rubbing Sound Making Left Turns InvertedB Mid Atlantic Impreza Club -- MAIC 7 08-24-2005 11:48 AM
Rubbing Sound Making Left Turns InvertedB Brakes, Steering & Suspension 1 08-23-2005 08:03 PM
grinding sound on right turns not CV joint MRF582 Brakes, Steering & Suspension 5 01-08-2005 10:20 PM
