Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 07-27-2006, 12:04 PM   #1
Innovative Tuning
Vendor Sales Rating: (43)
Member#: 67958
MY96 Time Attack
and 06 STI daily
Default We've moved!!! In stock blowout!!! Perrin, TurboXS, Pistons, Rods, Turbos and more!
Coolingmist Meth/Alcohol/Water Injection Systems:
These are designed to run straight water, alcohol, meth or any mix of the three safely. Water, alcohol and/or methanol injection provide detonation resistance, cools your intake charge, and with proper tuning it will increase horsepower and torque without any loss of margin of safety.
If you have any questions about this let me know, we're not just a parts store. We've tuned cars to over 30 psi on pump gas with these kits.
Coolingmist's progressive controller incorporates dials for quick adjustment AND a serial interface so you can totally custom tune the ramping of the injection system via a PC if you are so inclined. Remember, you do NOT need a computer to use this. It will plug and play with several pre-programmed maps similar to other controllers. The ability to custom tune it with a PC is in addition to this, not in place of it.
Stage 1 Progressive Kit - 405 Shipped!
2 quart tank
150 psi pump
tunable progressive controller
brass water filter
brass check valve
tapping kit
all the lines, fittings, etc. for a complete install.
Stage I kit options:
1 gallon tank instead of the 2 Quart - $20 upgrade
Float switch- $18.99 upgrade
Stage II Progressive kit - 449 shipped!
This kit is the same as stage I except it ships with a brass clog nozzle/water flow detector. It will blink when water/methanol flows and it will tell you if you have a clog.
Stage II kit options:
Stage III kit - 535 shipped!!
Stage III vs. Stage II:
Upgrades to a 1 gallon tank
Adds a low level float switch with LED
Upgrades to 12 Feet Of Stainless/Teflon Hose versus the standard hose. If you need more let us know. Remember you will need a cutting tool such as a dremel to size this braided hose to fit.
No clog nozzle detector
Sard WRX fitment 800cc injectors - 459 SHIPPED!!! (Compare this to the PEs folks!)
STi Pink WRX fitment 550cc Injectors (sometimes called 565cc) - Temporarily on backorder
PE 850cc injectors for US Spec STi - 599 shipped!
Walbro 255 lph high pressure fuel pump - 79 Shipped!
Before anyone asks, no you don't need the install kit so save your money!!! Buy a 3" long piece of 5/16" fuel line and two hose clamps to fit it at your local parts store instead.
Perrin High Flow Fuel Rail Kit (Specify WRX or STi) 349 Shipped!
We have tons of Perrin parts in stock and ready to ship including:
Perrin Front Mount Intercooler Kit for WRX/STi - 1049 Shipped!
Perrin Rotated Mount GT35R Turbo Kits - 2289 Shipped or 2635 shipped including Perrin rotated intake setup. The Perrin rotated intake is necessary for use with stock MAF if you aren't going to a blow through setup. Those going to speed density based tuning with an AEM EMS or other standalone may want to use a custom intake instead.
GT35R shown at top left vs. wimpy stock WRX turbo at bottom :
Perrin Intercooler Hose Kit - 129 shipped!
Perrin Standard (199 shipped) and Big Turbo Inlet Hoses (229 shipped)
not to be confused with Perrin Afta-Maf Intake Hoses (75 shipped):
Perrin big TMIC for WRX/STi - 685 shipped! (WRX requires Intercooler hose kit)
Perrin Uppipe - 182 shipped!
Perrin CEL Fix - 62 shipped!
Perrin EBCS - 85 shipped!
Perrin Downpipe - 325 shipped!
Perrin Single Tip Cat Back - 655 shipped!
and more!
All TurboXS parts now on sale. It's crazy deal time. PM for pricing!
WRX AEM EMS Kit - Call for special NASIOC only pricing!
Turbologic MBC (Manual Boost Controller). Comes with Subaru specific install instructions, silicone vacuum hose, tee fitting, zip ties, and more. This is the best MBC we've ever used. No spiking and easy/predictable adjustment. - 58 Shipped!
Tial 50mm Blow Off Valves (BOV) - Silver or Black in stock - 209 shipped!!!
Tial Wastegates - PM for pricing
Forced Performance Subaru bolt on Evo 3 16g Turbos - 875 shipped!!!
If you're looking to upgrade your turbo without taking a big hit in spoolup this is your turbo!
Garrett and Precision Turbos and other products are all on sale.
This universal front mount sports a Garrett bar and plate core with Precision cast end tanks.
2.75" Inlet/Outlet
31.5" Wide (from inlet to outlet). Core width 23.5"
10.625" Tall
3.5" Deep
This intercooler is rated for 750 HP on turbocharged applications.
It's an excellent piece for those getting their own piping made.
449 SHIPPED!!!!
Engine Build Corner
Greddy Extreme Timing Belt for EJ20 02-05 WRX - 165 shipped
This timing belt uses Kevlar technology for added strength/longevity and it's only slightly more expensive than an OEM belt. Frankly it's a no brainer.
CP Pistons - US STi - 20 over - 445 shipped! (Other options available at the same price!)
Cometic WRX, STi or legacy turbo head gaskets - 97 shipped for the set!
Eagle Rods - 335 shipped!
ARP Head Studs for WRX, STi, and more - 167 Shipped!
A great addition to any engine build!
Kelford Non AVCS Cams for WRX and STi:
Fast Street Cam Set:
Duration: 272/262 @.010" and 224/222 @ .050"
Lift: .377"/.377" @ 1 to 1
Street/Race Cam Set:
Duration: 274/262 @.010" and 232/222 @ .050"
Lift: .403"/.377" @ 1 to 1
Drag Cam Set:
Duration: 274/276 @.010" and 232/225 @ .050"
Lift: .403"/.403" @ 1 to 1
Cam sets are ONLY 899 shipped (set of 4)!!!
Supertech Valvetrain Set (compatible with Kelford, OEM, and other aftermarket cams) - 329 shipped!!!
Includes: Dual Springs, Titanium Retainers, and Spring Seats!
If you don't see what you're looking for here, PM/E-mail/Call us and we'll hook NASIOC members up even if your items aren't on sale!!!
NY state residents add 8.75% sales tax as usual. Shipped pricing applies to ground shipments within the lower 48 states.
There are two easy ways to order:
A) Call us at 716-873-7360
B) Paypal us at [email protected]
Mike McGinnis
Innovative Tuning
Voice/Fax: (716) 873-7360
[email protected]
http://www.InnovativeTuning.com
Innovative Tuning is offline
Old 07-28-2006, 10:48 AM   #2
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Thanks for all the orders from last night guys. Plenty more in stock!
-Mike
Old 07-28-2006, 01:43 PM   #3
v8killer2pt5
Member Sales Rating: (8)
Member#: 62275
2004 Sti
Mike where are you guys located??? Check your pms for my request.
v8killer2pt5 is offline
Old 07-28-2006, 02:00 PM   #4
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Buffalo, NY. I'll send you a PM with that price.
Old 07-31-2006, 11:08 PM   #5
subaruwrx420
Member Sales Rating: (16)
Member#: 80939
PM sent about fuel pump. Thanks.
subaruwrx420 is offline
Old 08-01-2006, 03:03 AM   #6
Garageless
Member#: 57263
2004 STi
pm me a price on a txs fmic please
thanks
Garageless is offline
Old 08-03-2006, 04:07 AM   #7
gc835
Member Sales Rating: (7)
Member#: 78080
2001 impreza
red biatch
got any supertech valves. id like the valves and valve train
gc835 is offline
Old 08-03-2006, 08:33 AM   #8
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
PMs sent to both of you.
gc825: yes we do. Stock size, .5mm over, or 1mm over?
Old 08-08-2006, 02:15 PM   #9
InfamousDX
Member Sales Rating: (184)
Member#: 25413
Mike... price for the kelford cams 274/262 and supertech valvetrain kit? Thanks.
InfamousDX is offline
Old 08-10-2006, 09:04 AM   #10
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
1228 shipped Mike
Old 08-18-2006, 12:09 PM   #11
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
RA Gearsets in stock!
Old 08-20-2006, 07:44 PM   #12
daveyboy
Member#: 35419
what is the price for the set of STI pink injectors?
daveyboy is offline
Old 08-21-2006, 10:53 AM   #13
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
1 set left. 419/set.
Closed Thread
FS: OEM Pistons, Rods, BPV and more. Imprezed04 AKIC Private Classifieds 12 06-15-2009 10:02 PM
Perrin/TurboXS/Cobb/Gimmick MS and more! Great prices! subaruwrxparts.com Engine/Power/Exhaust 22 02-18-2009 01:52 PM
FS/AL Injectors, Rods, Pistons, Fuel rails and more PICS!!!!!!!!! 03wrxtreme Engine/Power/Exhaust 11 12-10-2008 03:49 AM
OAKOS Automotive - Cobb, TurboXS, Perrin, DeatschWerks, Blouch Turbos, and More!!! OAKOS Automotive Engine/Power/Exhaust 61 08-15-2008 11:07 AM
GC Items in stock! Morettes, Springs, Sway Bars, Fog Covers and more... AllSubaru.com Vendor 'For Sale' Classifieds 24 08-20-2003 10:47 AM
