North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 10-23-2001, 12:14 AM   #1
Rags
Member#: 10478
1998 Impreza
Default Engines Engines Engines Engines
I heard that you can bolt any engine into any subaru body. Exp: 2000-2002 WRX Engine into a 95 impreza.
Rags is offline   Reply With Quote
Old 10-23-2001, 12:18 AM   #2
Austin
Member#: 7089
2016 STi
Very profound ... You gotta project in mind?
Austin is offline   Reply With Quote
Old 10-23-2001, 12:23 AM   #3
Rags
Member#: 10478
1998 Impreza
I doooooo but before i get all excited i was wondering if my dreams were possible?
Old 10-23-2001, 12:45 AM   #4
Rags
Member#: 10478
1998 Impreza
Thumbs up
i'm only bumbing cuz i may finally buy my project car tomorrow!!!!!!
Old 10-23-2001, 12:54 AM   #5
Austin
Member#: 7089
2016 STi
Where/who are you getting it from?
Old 10-23-2001, 01:40 AM   #6
Rags
Member#: 10478
1998 Impreza
A private seller from bothel. if anyone has any clue if most engines are compatible with a 95 impreza; please le me know.
Old 10-23-2001, 02:25 AM   #7
Rags
Member#: 10478
1998 Impreza
bump
Old 10-23-2001, 07:06 AM   #8
Marty S
Member#: 1968
2000 Outback Lmtd
Winestone
I understand you can put a 2.2 in if you use the 1.8 intake. I guess there is a sensor or something on the 2.2 intake that requires wiring so it is easier to just use the other manifold. not sure but thats what I read. Should bolt in otherwise and they are cheap and plentiful. 500-1000 depending on year and mileage. Good luck. Let us know how things go with it.
Marty S is offline   Reply With Quote
Old 10-23-2001, 09:47 AM   #9
Rags
Member#: 10478
1998 Impreza
Thanx
Old 10-23-2001, 10:05 AM   #10
Marty S
Member#: 1968
2000 Outback Lmtd
Winestone
Rags, what are you looking for? If you want power one thing alot of people do is put the 2.2 turbo motor in. That will cost more though and take alot more effort. Maybe you dont mind a lot of work to get what you really want out of your project? Speak to us.
Old 10-23-2001, 04:48 PM   #11
Rags
Member#: 10478
1998 Impreza
I have a 2.2L engine sittinging at my house, I havn't decided if i want to put that and a turbo or a wrx engine into my car. I they will both bolt straight into a 95 impreza then I will buy it. I'm not worried about the work involved in doing it i just don't want to worrie about trying to make new engine mounts anf having to change the allignment of the drive line and all that jaz. if all the work is in changing computers and maybe a trany then thats cool.
Old 10-23-2001, 09:10 PM   #12
Marty S
Member#: 1968
2000 Outback Lmtd
Winestone
If your going to turbo it and you dont mind spending a little more I recommend buying a turbo 2.2 out of a 91-94 legacy turbo.The block is solid and known as "bullit proof" And while your at it the 5 speed that came with that turbo is a heavy duty unit. Its been said the turbo motor will eat up a non turbo tranny fairly quickly. I found 70K turbo motors online with tranny for around 1500. You are best off getting the wiring harness too.Just my 2 cents worth. Check with the tech forum about the best motor choice. There are some Japanese motors that have more power than our 2.2 turbo. Also I read somewhere that 2.5 heads on a 2.2T will really open them up for more HP. As far as swapping Scube motors I believe they all bolt right in to the mounts and the trans my even be the same for the WRX but I dont know that for sure.
Old 10-24-2001, 01:40 AM   #13
Rags
Member#: 10478
1998 Impreza
Thanx for the info.
Old 10-24-2001, 02:52 AM   #14
ProRallyEric
Member#: 2204
99 Rally Impreza
team graphics
Default Engine swap advice
I'm sure I can help.
I've been to the edge and lived to tell : )
I'm in Tacoma
Eric - (253) 565-9050
The rally team site
http://www.franticfour.com/
ProRallyEric is offline   Reply With Quote
Old 10-24-2001, 06:06 PM   #15
nsotak
Member#: 3048
2008 OBS
Silver/Silver
This is making me feel like a 2.2 turbo might be up my alley. 1500 bucks, that's cheap. And it will work.
-nick
nsotak is offline   Reply With Quote
Old 12-22-2014, 12:38 AM   #16
Norm9560
Member#: 408913
OK, Here's my question I have a 2002 Outback that the 2.5 engine & transmission just went on (206K). I want to put a 2.2engine & trans mission from my 99 Impreza Outback Sport into 2002 outback will this work & would I have to swap out CPU & TCM as well,as far as I can see all engine & transmission plug ins are the same.
Norm9560 is offline   Reply With Quote
Old 12-22-2014, 01:57 AM   #17
MDBerryDGMWRX
Member#: 290746
2011 DGM WRX (his)
2011 DGM Forester (her's)
Holly ****!!! This thread is over 13 years old. Might want to look in the technical section.
Sent from my SM-G900V using NASIOC mobile app
MDBerryDGMWRX is offline   Reply With Quote
Old 12-24-2014, 11:11 AM   #18
northcoast74
Member#: 349398
1998 Rally Impreza
Wow... severe necro. Since you already resurrected it, might as well answer the question.
Yes I can be done. I'm doing a similar swap right now with a 98 OBS and a 00 Foz. Your's should be less of a pain in the ass because both your cars are MAF and you shouldn't have to mess with the harnesses.
northcoast74 is offline   Reply With Quote
whats the difference between the 2.5Rs engine and STI engine? MaxPower STi Forum Archive 6 01-07-2003 08:15 PM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 07:50 AM
engine hoist and engine stand mike00rose Mid West Subaru Owners Club Forum -- MWSOC 0 12-16-2000 04:57 AM
Engine help!! Getting engine back on mounts!! SFsube Technical Forum Archive 1 09-13-2000 12:17 AM
