Old 07-27-2006, 07:27 PM   #1
Brupp
Member#: 51703
1998 Legacy Outback
White/Grey
Default Can't exceed 42000 rpms.
I have a 98 outback manual transmission with 165k on it. For some reason now I can't get it to accelerate past 42000 rpms. When it hits 4200 rpms it just won't go anymore it sounds like it revs a little higher but my acceleration tops out, and I have to shift into the next gear to continue accelerating. Doesn't matter what gear I'm in as far as I have messed with it. I also have problems with my car occasionally dying although this happens very rarely. Any suggestions on what this would be would be so helpful. Thanks so much.
Bryan
Brupp is offline   Reply With Quote
Old 07-27-2006, 07:35 PM   #2
Sc00byD00d
Member#: 83590
2004 WRX STi
Platinum Silver
Sounds to me like either a ECU issue or perhaps the fact that you are trying to get the car to go about 36000 RPM's past the redline...
- Scooby
Sc00byD00d is offline   Reply With Quote
Old 07-27-2006, 07:46 PM   #3
al-gorithm
Member#: 85111
2005 LGT RBP
Sunday Driver
You are probably in limp mode. no cel's?
al-gorithm is offline   Reply With Quote
Old 07-27-2006, 07:52 PM   #4
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
Wow, 42000 rpms?
semaj is offline   Reply With Quote
Old 07-27-2006, 07:56 PM   #5
ScubaruImpreza05
Member#: 74041
2006 2012 Weee-strom
SV650 For sale
Limp mode, or maybe 02 sensor issues.
ScubaruImpreza05 is offline   Reply With Quote
Old 07-27-2006, 09:46 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I bet you could get a job with an F1 team right now if you could show them how to rev a car to 42,000rpm!
Old 07-27-2006, 09:51 PM   #7
ducmaan748
Member#: 86518
2004 WRX STi
Stage 2
42,000 RPM's HAHA!!!!
ducmaan748 is offline   Reply With Quote
Old 07-27-2006, 09:59 PM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Why havent you taken it somewhere to have it checked out yet?
Old 07-27-2006, 10:04 PM   #9
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Vehicle Speed Sensor is probably on its way out.
look at the speedo when it happens, if its fluctuating you found your problem.
Same thing happned to one of my 98 RSs.
Jay
Old 07-27-2006, 10:10 PM   #10
RexInit
Member#: 114703
2004 WRX
limp mode wouldn't let you even get up that high. Does sound ECU related though. How neat must your tach look like going up to what 45k rpm.....that would be like VRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM MMMM*shift*VRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRMMMMMMMMMMMMMMMMMMMM MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM BOOOOOOOOOM!!!!
RexInit is offline   Reply With Quote
Old 07-27-2006, 10:22 PM   #11
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
yeahhhhh man!! i've reached 42000 rpms before! on my 05' stage 2 wagon bitches!! yeah!!!!
gingertooth is offline   Reply With Quote
Old 07-27-2006, 11:06 PM   #12
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
check engine light?
if so, get the code pulled
sounds like a bad maf to me.. but you really need to have someone look at it.
Jamie
Old 07-29-2006, 10:21 AM   #13
Brupp
Member#: 51703
1998 Legacy Outback
White/Grey
ok so I'm glad one simple entry error could draw so much attention. hahaha. My speedometer doesn't work and hasn't worked for a long time I haven't had the codes checked, but the check engine light is on and when I had them last checked they were the P1507 Idle control system malfunction (fail-safe) and P1540 Vehicle speed sensor malfunction 2. I didn't know if either of these things would be related or not. I haven't got it checked out due to time and money but if I can't get this figured out I will. Thanks so much for all of your help. Sorry it takes me so long to get back but I don't have internet at home. Thanks again,
Bryan
Old 07-29-2006, 11:52 AM   #14
gd6subie
Member#: 114579
2006 STi
Crystal Grey Metallic
if the acceleration tops out and reaches its top point where the acceleration rate will not increase, one of the reasons maybe the transimission fluid.
gd6subie is offline   Reply With Quote
Old 07-31-2006, 12:49 AM   #15
Brupp
Member#: 51703
1998 Legacy Outback
White/Grey
How many quarts of transmission oil does my 98 outback 2.5 litre manual transmission hold? I bought three quarts already and have just been waiting to have a night to let it drain all the way out, I will try to do that tomorow. The guy at NAPA told me that 3 quarts would be fine, but then a friend with an 2.2 litre legacy said his tranny held 3.5. I just want to have everything I need. I also have a friend who has the same year of outback and said that I can switch out my speed sensor so I will try that also. My biggest setback is that I can't do any work on my car in the apartment complex that we live in. Thanks for your help I will report back once I do these two things and see the results. If anyone could give me any helpful hints with either of these actions it would be greatly appreciated. Thanks for your help.
Old 07-31-2006, 08:37 PM   #16
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
it holds around 3.5 - 4 depending on how much you drain out.
Jay
Old 08-01-2006, 11:53 AM   #17
problemcat13
Member#: 73398
04 11 VW GTI
APR Stage 1 (300ft/lbs)
If you have the manual, it should tell how many quarts you need (Haynes repair manuals are nice to have around to, for little break-fix projects). Have you done any of the recommended maintenance? (rear diff changes, timing belt, etc). Keeping that stuff up will keep your car running longer.
On my wife's previous 95 outback (2.2L), the first owner had let the timing belt go 30k miles past recommended change time. We didn't know that, but every so often, the car wouldn't start, just turn over and over. 5 minutes later it would start fine. CEL would always come on, we finally got it checked out, and it was the crankshaft position sensor because IT HAD TINY PIECES OF TIMING BELT ON IT!
So yeah, getting those CELs checked and/or resolved is always good.
[/lecture]
problemcat13 is offline   Reply With Quote
Problem! Can't rev past 2000 rpm. Idles perfect. jermany755 Normally Aspirated Powertrain 15 02-09-2008 09:46 PM
Car can't even hit 3k rpms icantdrive75 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-08-2005 05:44 PM
Exceeded RPM redline in 2nd gear...did i goof anything up? dingo dave General Community 11 05-07-2005 10:06 PM
FS:2002 wrx 42000 miles marvd00d Private Vehicle 'For Sale' Classifieds 2 11-07-2003 06:20 AM
Why can't I shift @5500 to 6k rpm without a grind into 2nd? opp Transmission (AT/MT) & Driveline 31 12-13-2002 08:23 PM
