#1 |
Member#: 48968
Vehicle:1999 impreza 2.5RS silver |
Has anyone tried either of these laptop interfaced obd2 readers:
proscan tekmate they are around the same price ~ 100$. are they any good? thanks
#2 |
Member#: 48968
or otherwise can anyone recommend a good obd2 system for a laptop that is reasonably priced?
thanks Nick |
#3 |
Member#: 66934
Vehicle:2004 JBP FXT 2002 cammed OBS - RIP |
the ELM system is well supported by several software packages - including palm and pocketpc......under $100
www.scantool.net |
#4 |
Member#: 27261
Vehicle:1999 www.prjct1.com I'm Ron Burgundy? |
If it can read emissions readiness codes, and all manufacturer specific and SAE specific codes then its worth it. If not don't buy it..
#5 |
Member#: 48968
forgot to add the links:
proscan: http://www.myscantool.com/ tekmate: http://www.tekmatetools.com/ let me know which one is better.. they seem to do the same things. proscan has a nicer setup in terms of the windows but the tekmate comes with the usb already which is a bonus. if anyone can see anything wrong with either or if this is worth it? nick |
#6 |
Member#: 66934
they both use the elm interface, so the only difference is the manufacturer's software (there is probably better versions available free). if the tekwhatever comes with usb, that's a plus for sure.
#7 |
Member#: 48968
where can i find this software for free?
cause you can get just the interface with usb and no software. are all the interfaces compatible with all software? thanks |
#8 |
Member#: 48968
... with the exception that the plug must be ISO for subaru can the interface be of any type and be compatible with all software?
thanks |
#9 |
Member#: 66934
as i said before, scantool.net has a bunhc of free softwa6re available for the elm interface. I don't know if it will work with a usb version, since pretty much all others are serial based. i think if you emulate a com port to the usb port, it could work.
#10 |
Member#: 24844
Vehicle:2000 2.5 RS MT Blue |
Hey Subenick. Did you end up getting on of these? If so, which one? I'm borrowing a Digimoto scanner, but it won't read the front O2 sensor (bank one sensor one). Does which ever you have give a reading for this ... and the rear O2 sensor (bank one sensor two)?
Thanks |
| Thread Tools | |
| Display Modes | |
| Central NJ help with OBD2 reader? | firecordz | Tri-State Area Forum | 10 | 06-04-2005 10:11 AM |
| MIL trouble code P0171 ? OBD2 Reader. | paul nieto | Engine Management & Tuning | 1 | 04-22-2003 05:52 PM |
| Anyone tried Innova 3100 OBD2 reader? | msun2000 | Factory 2.0L Turbo Powertrain | 0 | 08-26-2002 12:54 AM |
| does someone in Ventura county has obd2 reader to get rid of my CEL? | scoobypuff | Southern California Impreza Club Forum -- SCIC | 8 | 03-19-2002 05:02 PM |
| where to get those palmpilot obd2 readers? | scoobypuff | Southern California Impreza Club Forum -- SCIC | 5 | 03-17-2002 09:47 AM |
