Old 07-27-2006, 08:01 PM   #1
subeesteve25
Guest
Member#:
Default need urgent help on boost gauge install
Im instaling the subaru boost gauge on my 05 wrx. i cut the hose and am now trying to fit the 3 way joint on. Its a real pain. is there easier way to do this? thanks.
Old 07-27-2006, 08:22 PM   #2
subeesteve25
Guest
Member#:
step 2 says remove the blind grommet . what is this, do i just pull it out? These instructions are so confusin and its so hard to get to.
Old 07-27-2006, 08:44 PM   #3
subeesteve25
Guest
Member#:
anybody, please.
Old 07-28-2006, 09:52 AM   #4
05wrxblowths
Member#: 113682
2005 WRX UTEC stage3
perrin everything
did you lubricate the t joint so it would slide in? dont mean to sound stupid but sometimes little things get over looked. you can use spit or anything. then just push and twist. i may be off but it's what i've done. as for the other part i'm not sure. mine came already on the car.
05wrxblowths is offline   Reply With Quote
Old 07-28-2006, 03:40 PM   #5
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
If you could scan and post the instructions, it would help us to help you.
I'm guessing the blind grommet is a rubber plug in an unused hole in the firewall. Is this step for routing the tube back through the firewall so you can plug it into the gauge?
Need help on boost gauge. 03wrxowner Interior & Exterior Modification 3 10-14-2007 11:55 PM
need wiring help for boost gauge install switchn2aWRX Electrical & Lighting 0 08-31-2007 12:34 PM
need help - Electric Boost Gauge install shotoyan Electrical & Lighting 4 01-02-2006 08:40 AM
Electrically challanged needs help w/ boost gauge install BIGSKYWRX Electrical & Lighting 6 10-06-2002 02:21 PM
Help with boost gauge install please HonduhEater Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-18-2002 10:31 PM
