Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 07-27-2006, 10:07 PM   #1
Member#: 65623
2005 05 Varis WRX
95 LS400
Default When changing Realtime map - ECU Relearn?
when you switch around let's say from econ mode or anti-theif mode back to stage 2.
Does ur ecu need to relearn all the timing and knock correcting all over again?
Or does it retain all the learned information as long as you dont' do a hard reset?
Kenji815 is offline   Reply With Quote
Old 07-27-2006, 10:16 PM   #2
Member#: 34860
2005 Forester CGM
When you change realtime maps the boost targets, ignition timing, dynamic advance, waste gate, fueling tables etc get changed.
Knock Learning tables stay as long as you don't reset the ECU. But you want the knock learning tables to stay.
Zumble is offline   Reply With Quote
Accessport: unable to change realtime maps for 02 wrx sadd16 Engine Management & Tuning 12 09-30-2005 12:54 PM
Base map and Realtime map aakrusen Engine Management & Tuning 13 05-29-2005 11:43 AM
Base map, Realtime map CaptainMorgan Engine Management & Tuning 2 05-15-2005 12:45 PM
AP not sending realtime maps to ecu HELP! swrtwagon Engine Management & Tuning 4 02-24-2005 08:55 PM
Accessport: Necessary to connect green connectors when changing realtime maps? kochj23 Engine Management & Tuning 4 06-30-2004 09:43 PM
