Old 07-27-2006, 11:33 PM   #1
turbo tecnica
Member#: 74470
2013 Accord Sport
72 LS1 Vette
Default Quick realtime map question
Just had a quick question here regarding the AP and realtime maps. I've been using an AP for about a year now (for a while on my 02 WRX, and now on my 04 STi), but I have never encountered having to do this before. Right now, my base map is Stage 2 93 oct. for my STi. I am going to be getting Protuned with a regular 93 oct map, but also having a second map made for 93 + meth/alky injection. If I run out of meth/alky, I am going to switch back over to the regular 93 oct map so I won't have any problems. Now, I am wondering one thing. I will have the Protuned 93 oct map as my base map - flashed to the ECU. I am assuming I will have the meth/alky injection map as a realtime map, so I can switch it on and off when I'd like. After you put a realtime map on (so I am using protuned base map + meth/alky realtime map), how do you take it off, so you aren't running any realtime maps? Someone had mentioned "Reset the ECU". I didn't know if that got rid of the base map, or if it only cleared CEL's, or what. I just want to make sure so I don't end up doing something I shouldn't. I never really switched between realtime maps before, so I haven't encountered this issue. Thanks!
turbo tecnica is offline   Reply With Quote
Old 07-27-2006, 11:37 PM   #2
nate49509
Member#: 22452
2016 WRX
The Accessport has an option to reset the ECU. Or you can do a "hard" reset. Which is basicly disconnecting the battery. I just use the Accesport to clear realtime maps. Its just a lot easier.
nate49509 is offline   Reply With Quote
Old 07-27-2006, 11:47 PM   #3
turbo tecnica
Member#: 74470
2013 Accord Sport
72 LS1 Vette
So you do just use the "Reset ECU" function? That's what I thought, but I wasn't too sure
Old 07-27-2006, 11:50 PM   #4
nate49509
Member#: 22452
2016 WRX
Yup. After that your realtime map is gone, but the base remains.
Old 07-28-2006, 12:04 AM   #5
turbo tecnica
Member#: 74470
2013 Accord Sport
72 LS1 Vette
Excellent... just what I needed to know. Thanks
Old 07-28-2006, 12:37 PM   #6
pdippel
Member#: 20611
2003 WRX
World Rally Blue
Just have them create a RealTime map of your Protune base map . When you want to get rid of the alky rt map just apply your non-alky protune rt map. The Protuner and streettuner software allows you to make a realtime map from any base map.
If you do a reset you lose all your ecu learning parameters.
pdippel is offline   Reply With Quote
Old 07-28-2006, 03:34 PM   #7
Zumble
Member#: 34860
2005 Forester CGM
Technically you can't create a realtime map OF a basemap. You can capture the basemap boost, timing, fueling tables as a realtime map though.
So basically you want three things..
93 Oct Base Map
93 Oct Realtime Map
93+Meth Realtime Map
Zumble is offline   Reply With Quote
Old 07-31-2006, 10:56 PM   #8
pdippel
Member#: 20611
2003 WRX
World Rally Blue
Where's the technical part that's not possible? Looks like you just stated that it is possible.
How do you make a realtime map learn more quickly? chimchimm5 AccessPort 6 04-03-2009 03:19 PM
Realtime Map Question Paintballguy AccessPort 0 09-21-2006 10:31 PM
acessport realtime map question?? trbowrx AccessPort 3 04-23-2006 09:25 PM
Quick AP map question Boostfiend04STI Engine Management & Tuning 3 07-08-2005 02:08 AM
Quick UTEC map question. Pre-diddy Engine Management & Tuning 2 02-09-2005 06:19 PM
