Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 07-28-2006, 09:36 AM   #1
dfritz
Member#: 49069
03 obs
05 Baja turbo 5 spd
Default problem with Sport Activity Light installation
I'm having problems with my upgrade project, and I remember
several posts on this.
Here's the deal: I bought a set of genuine lights from EBAY ($109 delivered), and the manufacture date is '03. My baja is an 05 turbo, and there are some relays already in the position that the instructions say to install the one supplied with the kit, they seem to run the fuel pump, and something else, and both activate when the ignition is turned on.
Short of using a sawzall in the search under the dash, I can't find the
plug which is supposed to be taped up in there. I remember someone
saying that the relay is preinstalled on later models, but I've got
everything in, checked fuse 19, and no lights.
Any tips would be welcome.
Here’s the post from ajabobrut regarding the relay:
The main harness runs along the inside of the pass. side roof rail and plugs in behind the 3rd brake light.The 04 comes with the switch holder already installed,the 03 as to be installed.The relay is different from 03 & 04,i found this out since i bought a kit for an 03 and installed it on an 04.The 03 kit is different from the others.
dfritz is offline   Reply With Quote
Old 07-28-2006, 10:36 AM   #2
subeman90
Member#: 65681
13 XV Limited
gray
What does this connector look like? i was behind my radio last week to install the shock sensor (this is a very long and bad story) but anyhooo back behind the radio/climate control there is an unused plug that is grey and I believe it is a 6 pin. It is taped to the wire harness of the climate control. hopefully this is what you are looking for...it certainly wasn't what I was looking for.
Good luck.
subeman90 is offline   Reply With Quote
Old 07-28-2006, 05:34 PM   #3
yellowblaze
Member#: 76682
03 Baja
Yellow (of course)
We installed them on our 03 with no problems, but I did notice there are diff kits for the later ones. Sorry couldn't be of more help, I can tell you that what they say is true-you can pull the ebrake up a notch to have them come on and drive (had to do this once) in a very low visablity situation.
yellowblaze is offline   Reply With Quote
Old 07-28-2006, 11:46 PM   #4
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
Are you looking for the connector for the relay or the switch? your 05 should come prewired,i don't think the Sport does.
ajabobrut is offline   Reply With Quote
Old 07-29-2006, 09:25 AM   #5
dfritz
Member#: 49069
03 obs
05 Baja turbo 5 spd
Default looking for the plug for the relay
Thanks, all. I'm looking for the plug for the relay. subeman90, the plug you found is for the switch, and I have it installed.
if the thing is prewired, and I've got the switch installed, the fuse good, and the lights plugged in, it should work, but doesn't.
The switch plug is working, the panel light goes on when I turn on the headlights, and dim with the dimmer control. I checked the plug, and can't find a hot wire, but I may not have had the e brake pulled when looking.
Is there a relay already in there, or do I have to add it. I can't find the 04 instruction guide anywhere on the net, just the 03.
Old 07-29-2006, 09:29 AM   #6
dfritz
Member#: 49069
03 obs
05 Baja turbo 5 spd
So how did you get the 03 kit to work in your baja?
Old 07-29-2006, 11:36 AM   #7
WERM
Member#: 92169
Is the parking brake activated?
WERM is offline   Reply With Quote
Old 07-29-2006, 01:07 PM   #8
dfritz
Member#: 49069
03 obs
05 Baja turbo 5 spd
yes, it's activeated, and the e brake switch works
Old 07-29-2006, 06:49 PM   #9
yellowblaze
Member#: 76682
03 Baja
Yellow (of course)
Did you check the library at scoobytruck for the install guide?
Old 07-29-2006, 09:45 PM   #10
dfritz
Member#: 49069
03 obs
05 Baja turbo 5 spd
just checked scoobytruck ( a new site for me, thanks for the tip), and the instructions are for 2003 models.
Old 07-29-2006, 10:41 PM   #11
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
On my 04 the relay goes behind the lower dash panel driver side.Theres a row of relays off the lower right side of the fuse box.I don't remember which one it is but i think its the second one in from the left end.Their black square/rectangle looking relay your kit should have had the round silver relay which is for 03 only.Later models take the black ones.Hope this helps.
Old 07-30-2006, 09:19 AM   #12
dfritz
Member#: 49069
03 obs
05 Baja turbo 5 spd
okay, this is the info I needed. the 04 and later sets have a different relay, a square one that goes on fuse panel. I think I can work around it, or buy a relay. The best part is I don't have to hunt the plug when it's not there.
Thanks for the reply. I'll let you know how it works out.
Old 08-01-2006, 09:29 AM   #13
dfritz
Member#: 49069
03 obs
05 Baja turbo 5 spd
Okay, ajabobrut told me there was a spot for a relay on the fuse panel, so I looked, and there was 1 empty hole, I unplugged the black cube relay next to it, put it in the empty slot, and the lights worked. I put it back, and ordered the relay from my subie dealer ($11). Should be in today.
Thanks all. I think there are some good deals on the 03 model lights, my total cost is $120, and some pondering.
Old 08-02-2006, 12:13 AM   #14
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
Good job,glad to hear you got them working.
Old 02-19-2008, 08:02 PM   #15
cerebusatc
Member#: 147565
ignore edit
cerebusatc is offline   Reply With Quote
Install Baja Sport Activity Lights gifters Baja Forum 3 06-17-2016 07:56 PM
Baja sport activity lights bypass toolbox1234 Baja Forum 2 06-24-2009 12:11 AM
Baja sport activity lights (roof mounted) toolbox1234 Newbies & FAQs 2 06-03-2009 07:18 AM
Roofrack Crossbar for the Sport Activity light kit. Marc M Baja Forum 3 03-25-2009 09:18 AM
Sport activity lights? yellowblaze Baja Forum 22 01-19-2007 01:35 PM
