Old 07-28-2006, 02:10 PM   #1
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Default How many have run a vf22 with the cobb vf34 map?
I'm installing a pnp cc vf22, pnp cc manifolds, pinks, ebay tmic, inlet tube, walbro fp. Was wondering how many folks have run the cobb ofs map for the vf34 on a vf22? What kind of problems or did it run good/OK .I have an 02 wrx mt. I know a protune is better and will be getting one asap but I might not be able to get an appointment b4 I go to the beach.
breathinez is offline   Reply With Quote
Old 07-28-2006, 02:40 PM   #2
elsanto
Member#: 34832
1989 M3
they are pretty different in flow. I'd so it but stay waaaay the hell off boost till you get a proper tune.
you have a boost gauge right?
elsanto is offline   Reply With Quote
Old 07-28-2006, 03:19 PM   #3
WRX-ERROR
Member#: 83211
2002 WRX - stg4
Doesn't Cobb have a vf22 map? I thought they did..
WRX-ERROR is offline   Reply With Quote
Old 07-28-2006, 03:32 PM   #4
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
no they don't, I wish they did. There are alot of vf22 users out there and it would seem that they would but Cobb doesn't like the vf22. Says its old technology. I would try PDX but I think its takes a while for them to get you a map. Plus you need a laptop so you can log the car. And email them your logs so that they can tweak on it some more.
Old 07-28-2006, 03:39 PM   #5
Sausage
Member#: 104998
2007 vf39 SuperWagon
I haz teh bed gramers
I can sell you my PDX map if you want it... I got a protune and don't use it anymore
Sausage is offline   Reply With Quote
Old 07-28-2006, 07:41 PM   #6
Sypher
Member#: 106366
2006 WRX
^^ lol @ that, just give him the map if hes in need dude, not like your using it anymore why capitolize on it?
Sypher is offline   Reply With Quote
Old 07-28-2006, 07:45 PM   #7
dibblejr
Member#: 94070
05 LGT
Pm'd ya I can help you out with a vf34 91 octane tuned map that will get you around safely for free.
dibblejr is offline   Reply With Quote
Old 07-28-2006, 08:54 PM   #8
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
thanks man I sent you my addy.
Old 07-28-2006, 08:59 PM   #9
dibblejr
Member#: 94070
05 LGT
PM and Map sent u r welcome
Old 07-28-2006, 09:01 PM   #10
dibblejr
Member#: 94070
05 LGT
dude,
didnt I send you some o rings for your pinks? If so glad they worked out.
Old 07-28-2006, 09:10 PM   #11
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
I wouldn't use those vf34 maps.Maybe just to drive to get a Protune,and thats not to smart.
Needles is offline   Reply With Quote
Old 07-28-2006, 09:15 PM   #12
dibblejr
Member#: 94070
05 LGT
My VF34 map was made esp to get me around until my tuner gets his new Dyno, no worries here.
Old 07-28-2006, 09:21 PM   #13
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
Well it not the cobb OTS map.You have differnt map then COBB maps.Still need to get a Protune.Why can't your tuner do a roadtune?
Old 07-28-2006, 09:24 PM   #14
dibblejr
Member#: 94070
05 LGT
I am 3 hours from my tuner so I opted for the Dyno this time so I can see what im makin. We are much smarter than to run an OTS map.
Well it not the cobb OTS map.You have differnt map then COBB maps.Still need to get a Protune.Why can't your tuner to a roadtune?
Old 07-28-2006, 10:04 PM   #15
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
1. Posting in the wrong forum is bad.
2. Using a VF34 map on a VF22 is probably the worst idea since Hitler's invasion of the Poland.
Old 07-28-2006, 10:21 PM   #16
dibblejr
Member#: 94070
05 LGT
Uni-
I know your a moderator and all, but do you read before you reply?
It is a custom map with a safety net!
You can move the OP's thread now if you desire or must.
Thanks for trying to scare the OP from the map, as I stated in my pm to him I have ZERO (0) problems in running this map. My tuner has done what he needs to to get me around " safely" until he gets the new DYNO.
As long as we dont go into full boost we are ok for commuting. The OP will be fine as long as he does the same.
Jay-R
Old 07-29-2006, 08:44 AM   #17
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
1. Since I have a 2.0 and an access port I figured the 2.0 forum would get more hits for the thread. I thought that it might get moved but thats ok.
2. Dale at Boxer4 told me I could use the Cobb ofs map to scale my pinks and drive it up there to him. Just to stay out of boost till I got there. So I disagree about being the worst idea. I trust Dale.
Old 07-29-2006, 12:21 PM   #18
hondaeater69
Member#: 60324
I agree, running WG boost on the OTS vf34 map should be FINE. Just run a hose from the WG to the compressor housing bypassing the OEM BCS to achieve no more than WG boost, which most vf's are around 10-12 psi IIRC.
Hell, cobb's OTS maps are still so pig rich you'd probably be fine running regular boost, but to stay on the safe side just run WG til you get to the tooner.
DO I have to run stage 2 with the Cobb ap? Corpuz04 AccessPort 9 03-05-2010 11:41 AM
WILL A MHI TD05H-18G work with the cobb FP18G MAP dan1587wrx Newbies & FAQs 1 10-08-2007 03:30 PM
Anyone have experience with the COBB 16g map? nos AccessPort 2 05-13-2006 03:58 AM
Anyone run a P&P'd VF34 with the COBB VF34 base map & a TMI? The Modaholic Engine Management & Tuning 10 04-14-2004 07:19 PM
How many People run with cats and how many have 0 cats? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 04-04-2004 07:03 PM
