Old 10-23-2001, 10:33 AM   #1
ttg
Member#: 5852
Default I need your input on exhaust modification.
Hello,
I am to soon get my car back from a shop that has prototyped a 3inch catless mandrel bent exhaust from the turbo back. The company is not going to build an up-pipe at the present time so it has the original up-pipe with the cat.
1) With 1 stock cat ahead of the turbo do y'all think I'll be throwing the CEL?
2) With just the turbo back exhaust am I going to gain any power?
3) Will the original up-pipe cat suffice for emissions testing?
Any input appreciated.
Thanks
Travis
ttg is offline   Reply With Quote
Old 10-23-2001, 10:45 AM   #2
MJSpiers
Member#: 4915
2002 WRX Sedan
Unless you put some electronics into the o2 sensor, you will *definitely* throw a CEL without any cats after the turbo.
Mike.
MJSpiers is offline   Reply With Quote
Old 10-23-2001, 11:27 AM   #3
trboCIVIC&WRX
Member#: 6426
1- like mike said, you'll most likely throw a cel.
2- you will probably see some power gains, hard to tell how much tho.
3- no. at least i doubt it.
the reason you will throw a cel is, there are 2 o2 sensors in your exhaust, and they need to read a different value from eachother. for example, if there is a cat between them, which it sounds like you dont have...
trboCIVIC&WRX is offline   Reply With Quote
Need Your input on a certain issue. fastbluewrx07 Rocky Mountains Impreza Club Forum -- RMIC 7 11-19-2007 02:21 PM
I need your input on aftermarket gearsets dothespeedlimit Transmission (AT/MT) & Driveline 18 03-19-2004 12:04 PM
Need your input on what to do next...stuck on a few choices. jarelee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 02-25-2004 05:30 AM
Need your input on this website Silky Bay Area Impreza Club Forum -- BAIC 6 06-28-2003 02:13 PM
I need your input on this tire slowme Brakes, Steering & Suspension 4 10-04-2002 11:08 AM
