Old 10-23-2001, 09:40 AM   #1
Valien
Member#: 8584
2002 WRB WRX.
04 Honda Odyssey!
Default WRX Flywheel wobbly?
Anyone experience this?
My WRX has 1200 miles on it. On idle when you pop the hood it looks like the main flywheel (largest one) is kinda wobbly at idling.
Anyone else have this problem? Performance wise the car is great, I've not noticed anything abnormal, etc.
Car is bone stock with the exception of the Intake silencer removed.
thanks.
~allen
Valien is offline   Reply With Quote
Old 10-23-2001, 10:16 AM   #2
Julian
Member#: 1182
MY00 RS
BRP
Do you mean the crank pulley? You won't be able to see the flywheel with your car running.
Crank pulley - circular pulley with a belt running around it.
Julian is offline   Reply With Quote
Old 10-23-2001, 02:11 PM   #3
Valien
Member#: 8584
2002 WRB WRX.
04 Honda Odyssey!
ah..yes..that thing. Crank pulley. Thanks for the correction. It's the largest wheel where the belt is wound around.
Old 10-23-2001, 04:22 PM   #4
Julian
Member#: 1182
MY00 RS
BRP
Define wobbly. Can you wiggle it when the engine is off?
Old 10-23-2001, 04:45 PM   #5
Valien
Member#: 8584
2002 WRB WRX.
04 Honda Odyssey!
Not sure. Haven't tried wiggling it when the engine is off. I'll do that today. When the engine is idling you can look at the wheel and it looks like it's not spinning in a perfect balanced circle.
almost like it's not balanced properly.
Old 10-23-2001, 05:12 PM   #6
Valien
Member#: 8584
2002 WRB WRX.
04 Honda Odyssey!
WTB or Borrow 06+ WRX Flywheel or 07+ LGT Flywheel Kylar NESIC Private Classifieds 0 08-24-2009 10:54 PM
sti flywheel or wrx flywheel? F ur PONY Transmission (AT/MT) & Driveline 2 03-05-2009 11:23 AM
WTB: OEM WRX Flywheel - FS: ASP Lightweight flywheel b0dh1 Tri-State Area Private Classifieds 7 06-21-2007 01:23 AM
RS flywheel vs. WRX flywheel dpjef Transmission (AT/MT) & Driveline 1 12-13-2006 03:08 PM
is the ej22 legacy 90-94 flywheel the same as the 02 wrx flywheel STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-07-2002 01:49 AM
