Old 07-28-2006, 05:44 PM   #1
accord lover
Member#: 72767
Default warm ups and cool downs.
hi yall. I've been looking to get 2006 wrx TR. I test drove it and it was great, quick and nimble. Here's a question, the dealer guy said that this car doesn't require cool downs because of yadayada (cant remember what he said) even though it's a turbo car. I forgot to ask the guy this because i was too excited but do these cars require warm ups too? Thanks.
accord lover is offline   Reply With Quote
Old 07-28-2006, 06:02 PM   #2
WRXorcism
Member#: 111249
'06 WRX
I would imagine he was referring to the way the turbos are cooled now, so a turbo timer really isn't necessary and you should always warm-up your car before you go driving very hard.
WRXorcism is offline   Reply With Quote
Old 07-28-2006, 06:07 PM   #3
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
warm it up a little in winter.
give it time to cool a little after stomping on it.
no problemo...
DISCOPOPE is offline   Reply With Quote
Old 07-28-2006, 06:53 PM   #4
FreNetiC WRX
Member#: 109763
2006 aw TR
[ GO PETTER GO! ]
Subaru Banner
subaru sent me this magazine that said you should deffinately warm it up a lil, but i didn't hear that about the cooldowns. i always give atleast 3 mins regardless, b/c i love her so much and want her to be around for a long time. let it warm up even if im movin it in the driveway. take no chances, they're that good.
FreNetiC WRX is offline   Reply With Quote
Old 07-28-2006, 08:33 PM   #5
stiIV
Member#: 88698
'05 Best e.t. 11.8
Best Trap: 123 MPH
The factory turbos are both oil and water cooled. They're setup such that coolant will still drain through the turbo upon shutdown; the coolant will evaporate and do a perfectly adequate job of cooling the turbo.
The past issue with turbocharged cars is that they tended to be oil cooled only, and if they weren't allowed to cool properly by circulating oil (which is only accomplished with the motor running) the blades of the turbine would 'coke' and you end up with premature wear and eventually failure. The common solution is to either get a turbo timer or simply allow the car to idle for a minute or so before shut down.
You never want to beat on a car cold...any car, turbocharged or not. The issue is made more apparent with turbocharged cars as the compressed air can add significant stress to engine components that aren't at operating temperature. It's a good idea to let the car come to full operating temp before really getting happy with your right foot, and by full operating temp I mean with more accuracy than the stock water temp gauge can give. A good aftermarket oil pressure/temp gauge will tell you when your car is ready.
stiIV is offline   Reply With Quote
Old 07-28-2006, 08:39 PM   #6
flycaster
Member#: 60142
2011 WRX
Grey
I just thought that was worth emphasizing.
flycaster is offline   Reply With Quote
Old 07-29-2006, 10:31 AM   #7
WRB_in_my_veins
Member#: 66540
2004 WRX Sedan
2005 Legacy GT wagon
That is ridiculous. You're actually doing more harm than good letting the car warm up just to move it in the driveway. Are you going on boost in the driveway??? No. What you're doing is getting just enough heat in everything to cause condensation in your exhaust system without getting it hot enough to evaporate. That's why they say short drives, that don't allow the car a car to get hot are bad on parts.
The point is, don't flat foot it banging through the gears at 5000 rpm right out of the garage. Do I sit in the parking lot at work for 3 minutes waiting fo the car to warm up before I pull out? Hell no. That's just stupid. You have to remember....it's a PRODUCTION CAR. These things are built with the average idiot in mind. If you don't believe me, ask yourself why a turbocharged car has an intake silencer.
You're not going to break anything turning the key, and pulling down the street. Believe me.
WRB_in_my_veins is offline   Reply With Quote
Old 07-29-2006, 11:51 AM   #8
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
^^^ Dead on, you can start up and drive. I just try to stay out of boost until the coolant gauge moves over the C mark. After that, OMG BOOST!!!
It still not recommended to beat on the car, then just shut down. I make the last 1-2 minutes of my driving alot more normal. And I let the car idle for 10 seconds before shutting down. Thats all you really have to do, and the turbo will last for a long time as will the motor.
turbo timers and cool down Donzo Impreza Forum 14 12-11-2005 12:40 PM
proper turbo warmup and cool down routine? asceleon Newbies & FAQs 8 11-17-2003 06:33 PM
S-AFC ups and downs y2k02scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-16-2003 05:21 PM
What are the ups and downs of a dog box- any brand? GT2WRX Transmission (AT/MT) & Driveline 23 08-06-2002 08:30 PM
Turbo warm up and cool down nyaconis Newbies & FAQs 15 04-19-2002 10:02 PM
