Old 07-28-2006, 06:48 PM   #1
Ultimate Collision Center
Vendor
Member#: 69072
Default Nitrous Questions and Answers...
I want to keep this running for anyone interested in the 'squeeze'. Just like many were afraid to run methanol for a while and now its becoming popular, nitrous should be right there with methanol. I personally run both and love both equally. If anyone has any questions or concerns please let me know...
Ultimate Collision Center is offline   Reply With Quote
Old 08-01-2006, 12:51 AM   #2
BoxerSpirt
Member#: 85726
Default to get started
I have a 2.0 with 80,000 miles, stock boost and stock EM. Is it possible to run spray from this point? Safe setups? Positives/negatives? Wey kit/dry kit?
thanks for your help.
BoxerSpirt is offline   Reply With Quote
Old 08-01-2006, 01:11 AM   #3
Vendor
Member#: 69072
You are up there in miles but certainly not beyond the point of using nitrous. I wouldn't suggest using anything bigger than a 50 shot though (normally the biggest shot I recommend unless you are getting the car tuned for nitrous and understand the possible consequences of it). I would suggest using a wet shot and start with a 35 shot and go from there. A 35 shot won't feel like a huge difference but its definitely a nice power gain and is very safe to run. I would only run a wet shot unless for some reason you were setting up the car for nitrous only and then there are some advantages to using a dry shot. The thing people have to remember is that you make power from the added fuel not the added air, the added air only allows you to burn more fuel...
Old 08-12-2006, 04:21 PM   #4
DragonSlayer
Member#: 77556
2004 WRX
World Rally Blue
So, with a 35-wet-shot, would I need to go with a larger fuel pump??
DragonSlayer is offline   Reply With Quote
Old 08-12-2006, 04:34 PM   #5
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
What about something like a Venom nitrous system where you can change the amount of nitrous by the TPS... 10% of a 35 shot at 10% TP, 20% of a 35 shot at 20% TP, 30% of a 35 shot at 30% TP, etc.....I would be interested in a system like that.
wrxdrvr is offline   Reply With Quote
Old 08-12-2006, 06:44 PM   #6
hippy
Member#: 36528
2002 Impreza Wrx
Originally Posted by ULTIMATE CC
.........The thing people have to remember is that you make power from the added fuel not the added air, the added air only allows you to burn more fuel...
But since our cars are usually tuned to run so rich, the fuel needed for more power is already there. If we had enough octane, we could possibly run a 35 shot pretty safely and gain power without adding fuel because there might be enough fuel there in the first place.
Running n2o at less then full throttle defeats the purpose of n2o. I mean, you're cutting off the flow of air with the throttle body, and then adding it back with n2o. This imo makes no sense.
peace
Old 08-12-2006, 09:02 PM   #7
Vendor
Member#: 69072
stock fuel pump for 35 shot as long as you are near stock will be fine...
Old 08-12-2006, 09:02 PM   #8
Vendor
Member#: 69072
They work great but are very expensive usually...
Old 08-12-2006, 09:04 PM   #9
Vendor
Member#: 69072
peace
I think you are talking about a dry shot, I typically suggest wet shots only...
Old 08-12-2006, 09:17 PM   #10
hippy
Member#: 36528
2002 Impreza Wrx
I was just responding to your statement about more fuel making more power. Yes, you need more fuel, but I was saying that there might already be enough fuel for a small shot if there was enough octane to run a leaner a/f ratio. It really had nothing to do with a wet or dry shot, even though the setup would technically be using a dry shot.
Most people recommend wet shots because people don't have the fuel system capacity or adjustability to account for the extra air at a given a/f ratio. If you could run the a/f ratio you want using a dry shot, there aren't as many reasons to use a wet shot. In fact the only advantage I could think of is that maybe the fuel would act as an injection system cooling the intake charge. Course, the n2o comes out cold anyways. On top of that, it's safer in a way to run a dry shot then a wet shot, since the fuel system can contol if fuel is being injected or not. Just some food for thought.
peace
Old 08-12-2006, 10:33 PM   #11
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Running big nitrous is easy, IF you tune for it AND your bottom block and clutch can take it.
Think of big nitrous (70 hp and above) as simply running WAY more boost. You wouldnt run 5-15 more psi without tuning would you? Same for nitrous. TUNE for it. Depending upon the motor, this could be as simple as road or dyno tuning the AFRs to make sure you are rich enough, to pulling serious timing (up to 20 degrees) for big power.
But with big/built motors you don't always have to pull timing, therefore more power for the same "shot" compared to other motors that would have to pull timing due to higher compression/detonation problems.
Another problem with big shots of nitrous is the way it "hits". American nitrous systems are typically ON/OFF. The best systems are computer controlled and you can regulate the time and power the system puts out. You can buy American systems that are computer controlled and there is an awesome European brand that actually has the solenoids to back up this style. Off the top of my head I don't remember either.
The problem with the On/Off type is the way the power hits. Its instantanious. And not just hp, but torque. And clutches, axles and trannies typically don't like instant boosts of 150 torque! If you can do dual stage, or even three stage, then the hit is easier on everything to handle. Similar to building boost along the rpm range.
Old 08-14-2006, 02:50 AM   #12
vipermodder
Member#: 122965
which is better nos or methanol? and is it possible to run both at once?
vipermodder is offline   Reply With Quote
Old 08-14-2006, 08:01 AM   #13
Vendor
Member#: 69072
Methanol is better for daily use and nitrous is better for making power, it all depends on what you want out of the car, and yes you can run both, I personally run both on my evo at the same time...
Old 08-22-2006, 02:25 AM   #14
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Lost another motor due to nitrous....
I had some great runs with the nitrous, no knock.
then I would have a knock or two.
Then I great run....
then I lost a ringland.....
Of course I am running ***** ass weak NA pistons, at high compression, so its kinda too be expected.....
But remember, extra power = extra risk!
Nitrous took me from 14.3 @ 94 to 13.5 @ 100......
New motor is actually going to hopefully be a nitrous eating beast! Cmon 12's!!!!!
Old 08-22-2006, 11:37 AM   #15
DoctorNick
Member#: 7022
2013 BRZ Limited
I run 12.1 @ 115 all day long. I know with good driving, there is more in it but my goal is to try to skip as much of the 11s as possible by hooking up a direct port nitrous system.
I wanna run about 20lbs of boost thru my SZ49 and maybe a 55shot.
Should I consider running a 80 shot? The car will be running a JDM ecutek tuned for C16 w/ a utec controling nitrous. Off spray the car should make near 380-400whp on a dynojet. W/ spray I would like to get at least 50 or so more whp. Help me overcome the 4th shift I have to do in the 1320.
Any opinions. Suggestions.
What fail safes should I look at?
I am pretty sure I will only be spraying from about 3500-6500. Shifting at 6500-7k. Redline 7500.
DoctorNick is offline   Reply With Quote
Old 08-22-2006, 03:51 PM   #16
hippy
Member#: 36528
2002 Impreza Wrx
Why direct port?
Old 08-22-2006, 10:58 PM   #17
Vendor
Member#: 69072
I would go with a 50-55 wet shot (nos, nitrous express, zex). Use the utec to hook it up and control it and you will really only need that for a failsafe, but a fuel safety switch can be added to the nos or NX kit if you desire for added safety. You will make atleast 50whp and like 80wtq...
Old 08-23-2006, 04:01 PM   #18
TheDocta
Member#: 109136
1979 Camaro
blue/black
Why direct port?
because he heard it in the fast and the furious
jk jk
just thought that was funny
TheDocta is offline   Reply With Quote
Old 08-23-2006, 05:58 PM   #19
DoctorNick
Member#: 7022
2013 BRZ Limited
Its a kit my friend was running on his RS.
Ran real well in his and I can get it for a good price.
Is there a problem with direct port?
Old 08-25-2006, 02:00 AM   #20
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
direct port is best, plain and simple, because it gives the most equal amount to each manifold runner. Its also the hardest to set up because you must remove the manifold to tap the foggers in.
And REMEMBER, if you go direct port, that means that the jets for each fogger MUST me 1/4 the size (hp wise) that a single jet. Which for a 50 shot is a pain in the ass! Thats a TINY ASS JET!!!!!
I plan on going direct port this year, but will be probably be spraying 100-150 shot, so each jet will be 25-37 hp each. much easier to do.
Old 08-25-2006, 11:57 AM   #21
gerald06sti
Member#: 115586
Can you use nitrous to spray your intercooler? I have heard of this being done before. Is this a myth or fact?
gerald06sti is offline   Reply With Quote
Old 08-25-2006, 12:04 PM   #22
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Yes, Nitrous Express makes a kit that will spray liquid NO2 onto the intercooler. You can also use Liquid CO2 if you wanted to.
http://www.nitrousexpress.com/Pages/Ntercooler.htm
Old 08-25-2006, 03:25 PM   #23
gerald06sti
Member#: 115586
NICE! I want one. I assume you would have to tune for this? Also it would seem to be pretty safe - what issues could arise if it failed altogether?
Old 08-25-2006, 03:43 PM   #24
hippy
Member#: 36528
2002 Impreza Wrx
You don't have to tune for it(or anything for that matter), but it might change the a/f ratio depending on the ems you're using, and that could be bad(so it would probably be good to tune for). I f it failed, the a/f ratio could change, and the charged air could get too hot if you're running higher boost because of the cooling capacity. This could also be bad. It could also weaken/break the intercooler from cooling/heating it so drasticly.
Imo using n2o to cool an intercooler is not nearly as efficient a way to get power as injecting it into the engine. It might get good results in certain situations, but it's at a cost of using a lot more n2o then you'd use while injecting, and getting less power. True, you could do both, and if you're looking for more power, that would obviously be an option. I just don't see it as being very cost efficient for the power ya get, especially in the long run.
peace
Old 08-25-2006, 04:28 PM   #25
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Question I’ve been thinking over; what’s a better choice for those will a fully configurable engine management system, a wet or dry nitrous system?
Theoretically a wet system isn’t necessary if your EM has the ability and is tuned to provide an adequate increase in fuel to compensate for the additional oxygen when nitrous is applied, right?
xcntrk75 is offline   Reply With Quote
Aquamist (Water injection) questions and answers here... Richard L Water/Methanol Injection, Nitrous & Intercooler Cooling 3712 05-20-2013 02:01 AM
Passing the NEW required OBDII Emissions test in PA Questions and Answers!! mrtrex Mid Atlantic Impreza Club -- MAIC 29 03-10-2013 07:23 PM
Motörhead Guidlines, questions and answers here: GO LEMMY!! El Camino Off-Topic 9 01-20-2006 02:39 PM
Roll Center, questions and answers Arnie Brakes, Steering & Suspension 5 12-21-2004 03:26 PM
Message Board Statistics All times are GMT -4. The time now is 06:30 AM.
