Old 10-23-2001, 10:19 AM   #1
Tom
Member#: 11500
2000 Honda Civic SI
blue
Default what model is best for turbocharging?
Hello,
Ok I am looking to buy an imprezza but im not sure which one I should look for.
I DEFINATELY want to turbo charge it and build up the suspension. I would be looking to make the car run high 13/low 14's reliable on pump gas. I was looking at getting a 98 2.5rs Some people have told me that If I want to go turbo than I should just pick up a slightly older 2.2 imprezza? Can you guys give me some info on why the 2.2 is better I heard the rod/stroke ratio and compression are two main factors.
How much hp can the 2.2 take without rebuilding internals? What about the 2.5rs?
Also is there any problems with the rest of the drivetrain when turboing the car.. ie the awd system.... is there a point where the differential can not handle the power (sorry old dsm owner).
I know this is a lot but I really want AWD again and some torque. I just dont want to "waste" money on the 2.5rs if the 2.2 would be just as good of an engine if not better.
Thank you very much for the help.
Tom
Tom is offline   Reply With Quote
Old 10-24-2001, 02:18 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
wellll lets see
98 use a MAF sensor ..(good) but are supposto have a weaker bottom end (bad) DOHC, don't know compression(probbaly in line with the 99 tho) ~1500 made
99 also use a MAF (but it is differnt model and extreamly fragile)
SOHC (supposot have mor torque than the 98), 9.7 to 1 compression ~4000 made
2000/2001 uses a 1 bar map sensor, the ECU will freak out at any thing over 3 psi..(can be fixed tho) SOHC, 10.0 to 1 compression >15000 made
if i were looking for a used RS to turbo i would probbaly go with a 98 .. has a sturdy maf, lower compression and cheeper (but has the OBS front bumper), my production numbers are not exact but close enough
Old 10-24-2001, 02:21 PM   #3
Tom
Member#: 11500
2000 Honda Civic SI
blue
thanks for the help..
right now i am looking for a 98 2.5RS
I will either sell my SI privately or trade it in at the dealer..
any dealers on this board by any chance?
Thanks again for all the help
What oil is best for 2.5rs's? Friscorice88 Newbies & FAQs 26 09-02-2004 07:38 PM
What BOV is best for both sound and performance? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 03-28-2003 04:19 PM
What day is best for the HCD meet? TypeC Texas Impreza Club Forum -- TXIC 32 05-29-2002 10:19 AM
JDM WRX STi family history? what MY is best for RS swap? wistful General Community 3 05-07-2002 04:44 PM
What tire is best for off-roading in an OBS? Geoff Technical Forum Archive 35 05-24-2000 08:25 AM
