Old 07-28-2006, 08:04 PM   #1
sekretskwirl
Member#: 112520
Default 1ST TIME AP GIRL..in CA
.JUST DID A 2.5 CONVERSION ON MY '02 X. THIS IS WHAT I HAVE TO PUT ON THE CAR: FULL TBE(NO CATS), VF39, STI TMIC, WALBRO, PINKS-STOCK AIRFILTER-COBB AP...IS THIS GONNA' WORK WITH STAGE 2 AND WHAT CAN I EXPECT. I LIVE AT 7400 FT. IN THE SIERRAS SO I NEED SOME TORQUE. THANKS DANIELLE in CA
sekretskwirl is offline   Reply With Quote
Old 07-28-2006, 08:08 PM   #2
Drink
Member#: 102682
... ripper's
sister.
should work with stage 3
Drink is offline   Reply With Quote
Old 07-28-2006, 10:00 PM   #3
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
I would not run that set-up with the OTS Stage 2 map, but you could create a good map using the StreetTuner software or getting a ProTune.
You may be able to get around on the VF-34 or VF-30 map.
boundy3 is offline   Reply With Quote
Old 07-29-2006, 05:22 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Ya NEED a protune
Old 07-29-2006, 12:28 PM   #5
hondaeater69
Member#: 60324
Stage 2? Unless you have a STi ECU and DBW, the STi AP with stage 2 map will NOT work. If you still have the wrx ECU you will need a wrx AP, and the closest map they have would be the vf34 map. With the added displacement i would not suggest this map though, that 2.5 will spool the turbo a big faster, risking getting into boost while still running closed loop fueling (that would be bad).
If you had to use the vf34 as a crutch, stay out of boost and go real real easy on the throttle to get it to the tooner.
ps, turn your caps lock off!!
Old 07-30-2006, 04:41 PM   #6
sekretskwirl
Member#: 112520
Wink Did'nt mention that..
...I also have an Invidia header(coated 2000) and Invidia UP, 3 port boost cylinoid, Perrin Inlet and maf to go with this. The tuner is about 2hours away and downhill all the way-just keep it outta' boost on the way there...Ok...stage 3 got it..any other input is appreciated, Danielle
Old 07-30-2006, 05:20 PM   #7
frankramo777
Member#: 15724
08 FXT sports
wrb
Default no cats??
thats not very green of you.
im no hippie, but why dump more schlitz into the air?
not dissen you either, just something to think about..
frankramo777 is offline   Reply With Quote
noobie subie girl in need of help... jackee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 56 06-13-2010 12:42 PM
1st Time Fluid changes in my WRX and a Impreza dhjester Transmission (AT/MT) & Driveline 2 06-22-2008 03:31 AM
1st time out here in Portland crashtest sonny North West Impreza Club Forum -- NWIC 3 06-04-2008 10:02 AM
RALLY GIRL needs rear greenstuff brake pads for '02 WRX in CA sekretskwirl Private 'Wanted' Classifieds 1 05-28-2006 05:17 PM
Dyno time at ESX in CA zinc99 Private 'For Sale' Classifieds 3 01-17-2005 11:36 PM
