Old 07-29-2006, 03:25 PM   #1
VermontMiata
Member#: 121488
Default 97 Ouback wagon - repair or get rid of?
I'm new here, so please bear with me. My wife has a 97 Outback (Legacy) wagon limited editionwith the 2.5 liter engine and manual transmission. The car has 101,000 miles and has been reliable to date. She has a new job and will be driving 110 miles daily on mostly highway roads. It's time for a timing belt, accessory belts, water pump, seals, spark plugs & wires, new coolant & hoses, thermostat, front pads & discs, and a clutch.
My mechanic only works on Subaru, and says it will be easier to work on it if we remove the engine, so I told him to replace the clutch since he is going this far. Now he tells me (and a search on this forum seems to confirm) that the 97 2.5 liters like to blow head gaskets. Ok, I told him to replace them.
I'd like to keep the car for another 100,000 miles if it will be reliable. I just replace both front half shafts this spring. What do you think? Are these cars likely to self destruct at 100,000+, or should the work described above put the car on track for another 100,000 mostly problem free miles?
Thanks!
VermontMiata is offline   Reply With Quote
Old 07-29-2006, 05:00 PM   #2
sketron13
Member#: 116158
2005 Legacy GT wagon
I believe the replacement headgaskets are a new design so once you replace them, they shouldn't leak ever again. The knock sensor is the only other problem item on newer Soob engines ($75 sensor + about 5 minute install), so the tune-up should do it for another 100,000 miles at least.
sketron13 is offline   Reply With Quote
Old 07-29-2006, 05:35 PM   #3
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
you must have small hands.
I tore the hell out of my knuckles on that one.
simple, though.
bl_easy is offline   Reply With Quote
Old 07-29-2006, 07:33 PM   #4
SenorSubie
Member#: 99256
1999 Subaru Forester
After you get the headgasket job done, the engine will be rock solid
SenorSubie is offline   Reply With Quote
To get rid of ABS or to not get rid of ABS? oldhat Brakes, Steering & Suspension 27 09-11-2008 12:01 AM
3 pics of my new cf hood, keep it or get rid of it?! 56k maybe sonic03rex Member's Car Gallery 52 06-14-2005 05:18 PM
Anyone got a set of RE92's they want to get rid of or maybe just one or two? Tuning Factory Inc. Mid West Subaru Owners Club Forum -- MWSOC 7 08-16-2004 04:43 PM
Need advice on getting rid of sedan for wagon JePereza WRX Tri-State Area Forum 9 09-13-2002 07:14 PM
anyone have, or is going to have a set of stock shocks/struts they want to get rid of jmott Texas Impreza Club Forum -- TXIC 2 12-02-2001 04:15 PM
