#1 |
Vendor Sales Rating: (9)
Member#: 38696
Vehicle:2002 WRX White |
PrecisionTuning Phone: (732)451-0200 Fax: (732)451-0110 945 Cedar Bridge Ave Brick, NJ 08723 www.precisiontuning.com sales@precisiontuning.com NEW!!!: SHOPCAM!!! CHECK OUT OUR WEEKEND SPECIALS IN THE POST BELOW!!!!!! Engine Specials!!!!! GReddy Informeter Designed with a compact plug and play color LCD display, the Informeter allows you to monitor, set warning points and datalog your vehicles performance though it's own OBD sensors. Select through important signals like Speed, Tach, Temps, Air Flow, Voltage, etc. (up to 25 channels), to monitor. The easy to use navigation menu allows you to select between various screens and displays: Digital, Analog or Bar Graph and 2ch, 3ch, or 6ch screens. You can also set warning points and pre-warning points, which will alert you with audible and visual highlights of important readings. Datalog up to 6 channels of data, and replay them. This is great for tuning. In addition to being functional the Informeter is also infinitely fashionable. Seamless changes in backlighting color, GReddy signature wall papers and colored backgrounds, along with a clear bezel to install colored face plates or even custom face plates, offer a endless options to match any vehicles interior. And to aid in mounting the unit can flip the display 180 degrees to free even more options. The GReddy Informeter is a key tool for all; beginners to pro tuners. Included:
Regularly $360.00, $275!!! Choice of White or Black Tial Sport 50 mm Blow Off Valve with Aluminium Weld On Flange The body and all internal components are CNC-machined from 6061 aluminum alloy. It features a large 1.98 in (50.5mm) valve; we believe this is the largest valve available with the highest flow capacity. The V-Band design aluminum mounting clamp gives a very clean and unique appearance. The clamp is anodized and uses Stainless Steel hardware for a long lasting, corrosion-free appearance. The valve seal utilizes a Viton O-ring that is clamped in place to prevent the possibility of sticking to the seat and pulling out. The valve stem and guide are Teflon-lubricated, hard anodize-coated for wear resistance. The Blow Off Valve also comes with our own machined aluminum banjo-type air fitting and bolt, with over sized 10mm hose barb for quick actuator response. The actuator has a high temp silicone Nomex-reinforced diaphragm for long life. Included:
Regularly $250.00, $225!!! Choice of Red, Silver, Blue or Purple Exhaust Specials!!!!! GReddy SP2 Catback Exhaust Features a 304 stainless steel muffler canister with extra strong 430 SS end caps that feature a deep, high polish. Large, high volume mufflers provide maximum flow with a deep, pleasing tone. Polished 304 stainless steel mandrel bent piping for better resonance and vibration control and enhanced corrosion resistance and durability. New lightweight, flared and stamped stainless steel flanges are also used to provide improved sealing characteristics. 2002-2005 WRX/ 2004-2005 STi- $568.65 Regularly $669.00 2005 Legacy GT Wagon- $737.15 Regularly- $899.00 GReddy EVO2 Catback Exhaust In addition to the GReddy straight-through technology, offset tip design and large piping diameters of the original EVO, the EVO2 is now offered in full stainless steel providing improved looks, durability and corrosion resistance while maintaining the best qualities of the original such as fitment, sound and performance. 2002-2005 WRX/ 2004-2005 STi- $589.58 Regularly $719.00 2005 Legacy GT Wagon- $893.80 Regularly- $1090.00 2005 Legacy GT Sedan- $820.00 Regularly- $1000.00 HKS Downpipe Increases turbo spool up and exhaust flow by deleting 2 rear catalytic converters. The down pipe is constructed from 75mm mandrel bent coated SUS304 stainless steel. This downpipe is a bolt on application that will mount to the stock turbo and any cat-back exhaust system with a 3" flange. Perfect for large external wastegate applications where space is an issue. 2002-2006 WRX/ 2004-2006 STi- $169.95 Regularly $175.00 HKS Hi-Power Catback Exhaust ![]() Inspired and designed from endurance and GT racing in Japan,. HKS has incorporated this new race inspired offset muffler and piping design into many street applications, which offers a greater flow and higher-PRM power gains due to the less restrictive design. This is achieved by eliminating unnecessary bends for the straightest exhaust path. For turbocharged applications, the large and smooth exhaust flow allows greater exhaust velocity for better mid-range boost response and high-RPM power. Hi-Power Exhaust systems are made from SUS304 stainless steel muffler and tip assemblies. Muffler tips are 120mm in diameter, piping diameter is 75mm. Will not clear vehicle equipped with rear diff. skid plate. 2002-2006 WRX / 2004-2006 STi- $550.00 Regularly $625.00 HKS Carbon-Ti Catback Exhaust Special Edition HKS Carbon / Titanium Hi-Power Exhaust. These exclusive versions of the Hi-Power Exhaust consist of a carbon fiber wrapped stainless muffler shell, a 120mm titanium tip, and polished stainless steel piping. Special Edition HKS Carbon Titanium Hi-Power Exhaust systems are exclusive versions of the Hi-Power Exhaust consist of a carbon fiber wrapped muffler shell, titanium tip, and polished SUS304 stainless steel piping. Will not clear vehicle equipped with rear diff. skid plate. 2002-2006 WRX/ 2004-2006 STi- $699.99. Regularly $895.00 Perrin Up-pipe The factory up-pipe hinders engine performance because the design includes a restrictive catalytic converter and a corrugated expansion joint. Replacing the factory up-pipe with a Perrin Performance up-pipe will increase exhaust flow rates and spool the turbo faster providing more horsepower at a lower RPM. Failures of the factory up-pipe are common on heavily modified Subaru's. Damage from pieces of the catalytic converter and the e.g.t. sensor probe being ingested into the turbo can occur. The Perrin Performance up-pipe is fully constructed of mandrel bent 321 stainless steel. . The up-pipe is one of the hottest components of the exhaust system and 321 stainless will ensure the extra longevity of your up-pipe, as well as decreasing chances of weld failure and warping. The Perrin 1/2" flange design prevents warping at high temperatures and insures a leak free seal. The proper inside diameter of 1.62 inches is critical. Pre-turbo exhaust velocity is critical to boost response. Improperly oversized header and up-pipe systems lower exhaust velocities slowing spool up for larger turbo's decreasing power and increasing boost lag. 2002-2006 WRX $349.95 INCLUDING INSTALLATION! Regularly $454.00 Including installation Perrin Rotated Up-pipe/Down-pipe Kit ![]() The Perrin rotated mount up pipe/down pipe kit includes a stainless steel up pipe and down pipe flanged for both a Garrett turbo (not included), and a Tial 44mm wastegate (not included). Using v-band flanges to mount a 44mm Tial wastegate the Perrin kit recirculates the spent wastegate gases back into the exhaust eliminating fire hazards, excess noise and under hood exhaust smell. The Perrin rotated mount down pipe will bolt to the stock or any aftermarket 3" exhaust system! 2002-2006 WRX/ 2004-2006 STi- $699.99 As always we will do our best to match prices!!! All in stock and ready to go. Email, PM, IM, or give us a call!!! If you would like something not in this post, for orders or information feel free to give us a call, e-mail, pm, or im! Thank You! Kyle Precision Tuning 945 Cedar Bridge Ave Brick, NJ 08723 http://www.precisiontuning.com sales@precisiontuning.com AIM: Precisiontuning1 Phone: (732)451-0200 Fax: (732)451-0110
#2 |
Member#: 38696
PrecisionTuning Phone: (732)451-0200 Fax: (732)451-0110 945 Cedar Bridge Ave Brick, NJ 08723 www.precisiontuning.com sales@precisiontuning.com NEW!!!: SHOPCAM!!! WEEKEND SPECIALS!!!!!: Cobb 2006 Legacy GT Automatic AccessPORTRegularly $649.00, THIS WEEKEND ONLY PM FOR AN ABSOLUTELY NUTTY PRICE!!!! ![]() Perrin Short Ram IntakeRegularly $189.99, THIS WEEKEND ONLY $175.00!!! Color: Blue Fits: WRX/STi/Legacy GT/Forrester XT TiAL 50 mm BOV Regularly $250.00, THIS WEEKEND ONLY $210 SHIPPED!!! Choice of Red, Silver, Blue or Purple Click Here to Order TiAL 52 mm BOV!!! Use Coupon Code: 090991106 As always we will do our best to match prices!!! All in stock and ready to go. Email, PM, IM, or give us a call!!! If you would like something not in this post, for orders or information feel free to give us a call, e-mail, pm, or im! Thank You! Kyle Precision Tuning 945 Cedar Bridge Ave Brick, NJ 08723 http://www.precisiontuning.com sales@precisiontuning.com AIM: Precisiontuning1 Phone: (732)451-0200 Fax: (732)451-0110 Last edited by Precision Tuning; 09-09-2006 at 10:32 AM. |
| Thread Tools | |
| Display Modes | |
| Insane Weekend Specials!!!! Tial BOV's, GReddy Exhausts & More!!! | Precision Tuning | Tri-State Area Vendor Classifieds | 26 | 10-06-2006 04:46 PM |
| VF39/VF34s in stock! Injectors/Fuel pumps! Exhausts & MORE! | Gruppe-S | Engine/Power/Exhaust | 10 | 10-21-2005 09:04 PM |
| Gruppe-S June Specials ! JDM Motors, Turbos, Exhausts and MORE ! | Gruppe-S | Engine/Power/Exhaust | 13 | 06-24-2005 02:10 PM |
| Rear lip, Helix exhaust, & more | skimmilk68 | Private 'For Sale' Classifieds | 31 | 09-09-2004 10:15 PM |
| Car going back to stock PE1820, Greddy Gauges, Apex'i exhaust & More | #1 Stunna | Private 'For Sale' Classifieds | 37 | 09-26-2003 02:00 AM |
