Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 10-23-2001, 01:17 PM   #1
moltibici
Member#: 7583
2002 WRX Wagon
Default ?WRX 16" rims fit on 1998 Outback Sport???
Will the stock WRX 16" rims fit on the 1997-2000 Outback sport?
Anyone know what the offsets are off hand?
moltibici is offline   Reply With Quote
Old 10-23-2001, 01:32 PM   #2
WagonMonster
Member#: 3781
2002 Legacy GT Wagon
2009 Forester X Limited
I don't see why not?
I'm pretty sure the WRX Rims are a 53mm offset with a 5x100 Bolt pattern, just perfect for your OBS.
WagonMonster is offline   Reply With Quote
Old 10-23-2001, 01:50 PM   #3
moltibici
Member#: 7583
2002 WRX Wagon
Default Thanks for any answers....
By the way - yes I did a search and yes I found some info ... the most confused threads imaginable.
What I found -
Subaru measures offset differently than some (all?) tire manufactures. They measure to outside of lip resulting in an offset that is about 8mm greater than what is typically published to bead measure.
Example - Enkei says wheel 40-45 offset while Subaru says 48-53 (for 16x7 wheel I THINK...again threads were a mess).
Stock WRX wheels is 53 OR 55mm (two different answers).
Stock Outback sport steel is 55mm (?)
So, I think that the OSB will handle a WRX 16" just fine. Anybody disagree?
Old 10-23-2001, 01:59 PM   #4
rkkwan
Member#: 5596
2010 Honda Fit Sport
1. Stock WRX wheels are ET55.
2. Offset is offset. It has nothing to do with the lip. It's the distance between the centerline of the wheel and the mounting plate. I don't know where you read about Subaru measures it differently, but I think it's BS.
-Ray
rkkwan is offline   Reply With Quote
Old 10-23-2001, 02:03 PM   #5
moltibici
Member#: 7583
2002 WRX Wagon
Thanks,
And I agree w/ the Offset is Offset deal - it should be a defined thing.
I read about the discrepancy multiple times in the I-club archives from 2001-200 where guys were running 42 Enkei, 48 Blah, etc which they measured to really be 50, etc. The search I used was
"Outback and Offset and Wheel" I think.
Old 10-23-2001, 02:35 PM   #6
Rodan
Member#: 10676
2002 Sold
Default Hers is the answer
My stock WRX wheels are stamped with 55mm offset on the inside of the wheel.
Rodan is offline   Reply With Quote
03 stock 16" rims fit on 07 wrx? pheonix991 Tire & Wheel 4 12-16-2009 12:13 AM
will 16" rims fit on an 09 wrx CletusTheDwarf Tire & Wheel 1 01-04-2009 01:32 PM
Do 2002 WRX 16" wheels fit on stock RS? chimchimm5 Tire & Wheel 1 12-16-2007 06:58 PM
Do 16" rims fit on STi?? (clear the brakes?) future_GDB Tire & Wheel 14 03-23-2006 03:58 PM
Will 16" WRX rims fit on 06 WRX Mike Burke Tire & Wheel 2 10-13-2005 10:42 PM
