Old 07-29-2006, 11:25 PM   #1
ninjaboy76
Member#: 33456
2006 Evo
GG
Default Water injector nozzle install with FMIC Question
I searched and couldn't find anything, but I was wonder how people were installing the injector nozzles with a FMIC. I just finished up my SMC kit and mounted my injector just before the bypass valve hose. I hope this will work. I wanted to mount it closer, but it wouldn't have been possible because my lower FMIC hose coming off of the turbo is to close to the upper hose connecting to the TB. So there isn't any room to mount the injector nozzle any closer than just after bend in the upper hose, but right before the bypass valve hose. Do any of you guys see and issue with this? I was concerned about the alky going into the bypass valve tract inbetween shifts.
ninjaboy76 is offline   Reply With Quote
Old 07-29-2006, 11:52 PM   #2
hippy
Member#: 36528
2002 Impreza Wrx
I'm not so sure as to what kinda wear injecting 50/50% back through the intake track would do. If you got a 100% bov, the problem would be solved(other then blowing it into your engine compartment. I have been running water(no alc) for a few years now(almost 3), and one of my nozzles is before my 50/50 bov. I haven't had any problems that I've noticed.
peace
<edited also>
Old 07-30-2006, 12:36 AM   #3
ninjaboy76
Member#: 33456
2006 Evo
GG
Originally Posted by hippy
It's usually customary to ask a question when it says question in the thread title. I'm pretty sure you'll be fine though(doesn't really matter where you mount it).
peace
Thanks, I was a bit scatter brained when I posted so I edited it.
Alky / Water injection Nozzle install on FMIC Bad Noodle Water/Methanol Injection, Nitrous & Intercooler Cooling 4 06-14-2008 04:46 PM
intake fitment with fmic question ender87i Factory 2.0L Turbo Powertrain 8 07-24-2007 02:18 PM
Will I/C prayer work on Splitter with 2 water sray nozzles? MrBlonde Factory 2.5L Turbo Powertrain 3 01-19-2006 02:16 PM
Intercooler Water Spray nozzle duckride Engine Management & Tuning 6 08-27-2003 03:40 AM
water spray nozzles Jonnathan Normally Aspirated with bolt-on Forced Induction Powertrain 13 09-18-2002 03:31 PM
Message Board Statistics All times are GMT -4. The time now is 01:30 PM.
