Old 07-30-2006, 03:25 AM   #1
xmystikx
Member#: 112253
14 wrx
revlis
Default Anybody else getting boost creep with the 06?
Currently i'm running a VF39, perrin downpipe, and hks cat-back. I flashed in the VF39 CA 91 OCT map and have been getting boost creep. Is there anything I can do before getting a protune?
xmystikx is offline   Reply With Quote
Old 07-30-2006, 03:36 AM   #2
sti-liger
Member#: 119689
2004 sti
O1G
yeah you can lay off the throttle number one especially in 4th through 5th and a protune will not cure boost creep it is a mechanical issue. even if your downpipe is catted you are still subject to boost creep. i have a cobb catted down pipe running stage 2 with a protune and got boost creep until i had my turbo ported end of boost creep some cars are more prone than others, yours and mine are one of them. if your gonna run a tbe then your only option is to port the wastegate end of story the vf39 wastegate cannot handle the extra flow so that is why it is mechanical not tuner related
sti-liger is offline   Reply With Quote
Old 07-30-2006, 12:39 PM   #3
Zumble
Member#: 34860
2005 Forester CGM
I think it's been proven again and again that the most effective way to get rid of creep is not EM... it's the port. It may be cheaper to do also.
Zumble is offline   Reply With Quote
Old 07-30-2006, 01:11 PM   #4
hippy
Member#: 36528
2002 Impreza Wrx
The best, least expensive, and laest time consuming way to get rid of boost creep is to raise the boost and remove the fuel cut. Do this at your own risk. Another good option is to get a new turbo. There are obviously other options like external wastegates.....
The less restrictive your exhaust is, and the lower you're holding the boost, the harder it will be to get rid of boost creep. Porting(a little) might work on certain cars and it might not. If you want to port the wastegate(and try to make sure it works), you might wanna look into getting deadbolts larger wastegate flapper so you can make the wastegate hole nice and big. Course this is just my opinion, and I'm no expert.
peace
Old 07-30-2006, 07:01 PM   #5
sti-liger
Member#: 119689
2004 sti
O1G
peace
not trying to flame so dont get me wrong but do the opposite of everything ^^^he said
Old 07-30-2006, 09:05 PM   #6
hippy
Member#: 36528
2002 Impreza Wrx
Do you think you're some kinda expert cause you ported your wastegate and got rid of boost creep(no offense)? Do you think you would have been so lucky if you didn't have a catted downpipe? Why do you think deadbolt created their larger wastegate flapper(rhetorical)? It's cause they ported a lot more turbos then you, and many people still had boost creep. Whatever though man....
hippy
Old 07-30-2006, 09:22 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...the thing about creep with the '06 and the td04 is that boost can't really get too high before the turbo runs outa flow and it(boost) peaks and drops off as rpm's increase.....
like hippy says....toon for it and enjoy what the td04 can give ya.....~240-250whp and ~300whtq.
My car is a real hoot up to ~90mph or so running ~19psi at(short lived) peak.....
Old 07-30-2006, 09:51 PM   #8
hippy
Member#: 36528
2002 Impreza Wrx
He's got a vf39. The best option might be to get water/alc injection and just run high boost(with the right tune). I have a diy water injection thread goin in that forum.......$190+tune.....
peace
Old 07-31-2006, 12:59 AM   #9
sti-liger
Member#: 119689
2004 sti
O1G
hippy
no your right man i was just playin i am no expert and yes i was lucky with curing my creep, i was just giving my point of view from the experience i have with boost creep from a personal expereince from my car and several other sti's with the vf39.
Do the 2005s get boost creep? If so, how to get rid of it? Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 09-09-2004 07:13 PM
anybody else get invited to Impreza focus group on the 7th? Newbaru New England Impreza Club Forum -- NESIC 13 05-27-2004 04:47 PM
Anybody else get the STi Replica cf front lip from MAShaw? DJWRX Interior & Exterior Modification 8 05-10-2002 03:18 AM
Anybody else get the latest Demon Tweeks catalog? beachbum General Forum Archive 5 12-12-2000 08:14 AM
