Old 07-30-2006, 10:17 AM   #1
Palmermc
Member#: 121471
2008 WRX Premium
Default WRX Borla exhaust on 99 rs?
Just wondring if a Borla catback exhaust will bolt right up to a 99 2.5rs. Ant ideas?
Thanks
Palmermc is offline   Reply With Quote
Old 07-30-2006, 11:50 AM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
No, it would have to be modified like the stock WRX cat-back would.
Old 07-30-2006, 12:27 PM   #3
SenorSubie
Member#: 99256
1999 Subaru Forester
X2..
It will fit, but you'll either have you use a WRX midpipe or have the flange rotated to fit yours
but its pretty easy for any muffler shop to do.. should cost about 40$
SenorSubie is offline   Reply With Quote
Old 07-30-2006, 04:47 PM   #4
Palmermc
Member#: 121471
2008 WRX Premium
well the catback includes the WRX midpipe, so it should bolt right up then? or do I still have to have the flange rotated?
thanks
Old 07-30-2006, 04:52 PM   #5
FalconRS
Member#: 92913
2005 2.5RS Wagon
Crystal Grey Metallic
Dunno about that particular one, but I have the Borla that's actually for the RS, and the mounting flange on the midpipe is actually not welded to the pipe itself, it's loose so it can be rotated however to fit. The axelback sectiond doesn't use a flange at all, it's a slide-on-clamp ordeal.
Are you getting the WRX borla used/cheap? Why would you not get the one for your car?
FalconRS is offline   Reply With Quote
Old 07-31-2006, 12:46 AM   #6
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Hmm. When I had my wrx cat-back modified for my car, they had to rotate the flange AND lengthen the midpipe by about 4 inches.
Old 07-31-2006, 10:43 PM   #7
Roly
Member#: 48450
1999 2.5RS
Silverthorn
unless he's getting the borla hush?
Roly is offline   Reply With Quote
Can we use a wrx/sti exhaust on a RS? jt0thevizzle Normally Aspirated Powertrain 19 03-15-2009 03:52 PM
borla exhaust on 2000 RS MY1STFLAT4 Normally Aspirated Powertrain 16 05-12-2005 11:06 PM
Anyone ever put a WRX stock exhaust on their RS/TS? poison Normally Aspirated Powertrain 19 02-22-2004 03:58 PM
Exhaust Mounting Question on 99 RS JohnP555 Normally Aspirated Powertrain 2 07-23-2002 09:23 PM
