Old 07-30-2006, 11:31 AM   #1
Assassin4457
Member#: 96773
04 WRX, RIP GC8
Default 18G Spool Characteristics...
Could the 18G users please give me some information about how fast the turbo spools ? Im on the fence between a 16G and an 18G because I learning the 18 can hit 300whp with relative ease and the 16 is being pushed at that point. I have searched about it, but as you can imagine there are hundreds of threads that are 18G related, and it would take me 19 years to find what im asking.
just 2 quick questions...
1. When does your turbo kick in ? (I know it has to do with proper tuning, but whats the best you know of ? )
2. Can the stock 2004 wrx motor take that kind of a turbo and still be streetable and reliable ? (with low boost map tuned for example? )
Any info related to this would be apreciated.
Assassin4457 is offline   Reply With Quote
Old 07-30-2006, 12:20 PM   #2
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
18g Do it!No questions about it.I was in the same boat as you.Had a VF34 for some time then I just wanted more.I was looking at the EvoIII16g or the 18g.I didn't want to much lag.Many people that I talked to said just get the 18g now and be done with it.So I got the 18g from http://www.blouchturbo.com/ Great price.I never looked back.Love it.
Boost kicks in around 3800.Between my VF34 with a COBB stg 2.5 OTS Map and my Protuned 18g I don't even feel the diffence in lag between the two.That's what a good tune will do.Right now the boost is set at 17psi.My turner said run it a month then come back if you want to raise it 19psi.I wouldn't go more than that.19psi is what most people run,to be safe.Your 2.0l will be fine with a good tune and not driving like an a$$hat.Do it right the first time.Go with the 18g.Good luck.
My setup is 18g with modded injectors,and aftermarket TMIC.
Needles is offline   Reply With Quote
Old 07-30-2006, 12:41 PM   #3
SubieStylez
Member#: 98709
2005 Impreza WRX 18g
EWG + Meth
I can't wait to go 18G too, I ordred my FMIC for the project yesterday (18G, Helix 820cc inj., Walborogh Fuel Pump, FMIC and Protune)
SubieStylez is offline   Reply With Quote
Old 07-30-2006, 12:48 PM   #4
WRX2FFU
Member#: 73872
EJ25 ,EJ22,EJ20,EA82
I've got a 20g from slowboy. It spools pretty well. It comes on at around 3200 and full boost 21psi(92 oct) 27(psi 110 octane). definately later than my vf30 but it is still fun to drive. I have modded stocks, txs topmount and other little stuff. Put down 347 whp and 320 tq on 110. stock engine and trans. Still going strong for over 6k miles. I have 37k on my car.
You definately have to be in the mood to drive fast and just stay in a lower gear. I still have not figured how to launch. I ran a 13.2 at 108 with a 2.5 sixty foot.
It's kinda funny a stage 2 pulls me from a dead stop but at 40 i run away!
WRX2FFU is offline   Reply With Quote
Old 07-30-2006, 03:10 PM   #5
McBain_TP
Member#: 43986
2002 WRX wagon RIP
2003 330ci black/tan
My 18G spooled the same as my VF30.
McBain_TP is offline   Reply With Quote
Old 07-30-2006, 03:28 PM   #6
Assassin4457
Member#: 96773
04 WRX, RIP GC8
How will my motor hold up to it? I understand that everything is in the hands of tuning, but for a daily driver still trying to be reliable, 16G or 18 ? I mean the 18 is alot of air going in, im curious how long my motor would work for me before needing a rebuild?
Also how does it compare to a deadbolt TD05H 16G with the monster P&P ?
Old 07-30-2006, 03:52 PM   #7
comradeboris
Member#: 33280
2005 STi
iirc ive seen that the ej205 is good to about ~400whp on stock internals. the biggest thing that will hold you back putting down that sort of power is not the engine but when will your tranny decide to go out...
comradeboris is offline   Reply With Quote
Old 07-30-2006, 04:03 PM   #8
SubieStylez
Member#: 98709
EWG + Meth
yeah we have to worry about the tranny over the engines even though the first thought is internals.. All I can say is save for some PPG gears so when the time does come that it does decide to give out your not left taking the train
Old 07-30-2006, 04:09 PM   #9
Assassin4457
Member#: 96773
04 WRX, RIP GC8
PPG gears ? I've never really ventured into tranny territory, althought I knew that I needed an upgraded clutch for sure.
PPG Gears what are they ? Syncro or Dog Cut ? (remember im trying to keep it streetable) Where can I find them / read about them ?
BTW Thanks for all the info, you guys are GREAT!
Never mind! i think I found it. its on www.ppggearbox.com.au right ?
Old 07-31-2006, 12:38 AM   #10
Blackpantherwrx
Member#: 70855
Air Spencer... Squash.
Get the 18g.The tranny is going to be fine as long as you dont bash it all the time. the motor will hold up just fine also. I have seen the greddy 18g and sti pinks on my friends car last over 100kmiles he is mostley on the freeway not to much drag racing. Just a nice street setup.
Blackpantherwrx is offline   Reply With Quote
Old 07-31-2006, 04:28 AM   #11
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
so should i go with an 18g or a big 16g?
99subi is offline   Reply With Quote
Old 07-31-2006, 09:01 AM   #12
Needles
Member#: 19075
06 OBS STi
MSPT Tuned Stg2
Hello have you been reading the posts, 18g JK
Old 07-31-2006, 09:50 AM   #13
VWGrk1
Member#: 57882
2004 WRX
My 18G'd '04 WRX hits max boost at about 3,750 rpm. Lag is a touch annoying at times, but definetely something you can live with. I'd highly recommend a GM BCS.
Not sure what the rest of your mods are, but if your goal is just 300whp, then I'd go for the EVOIII 16G. Same power level (though I do not know how well it holds power in the 6,000+ rpm range) and better spool. No reason to buy a laggier turbo to make the same power with a narrower power band.
Your motor will be just fine at that power level. The motors seem to be good for up to 400 whp. Reliability aside, the heads cannot flow enough to support over 400 whp.
VWGrk1 is offline   Reply With Quote
Old 07-31-2006, 11:10 AM   #14
amukaoen
Member#: 62595
04 WRX Cobb S2
World Rally Blue
Is lag better then a stock (pre-06) WRX or worse with the 18G + Protune...
what do you 18g'ed owners think?
amukaoen is offline   Reply With Quote
Old 07-31-2006, 12:57 PM   #15
dingobite
Member#: 82391
08 OBP Sti
dom 2.5xt-r 384hp 412tq
Dont know about you guys i might be coming into some extra cash (UPS foulup) was getting all hyped on the 18g becuase of the good tunes some of you are getting.
One thing to keep in mind a 18g will not hold its spool down like the 16g series im staying with a super16g or maybe a EVOIII if i have to buy another turbo.
>>To the guys with the slow spooling vf34s something is wrong with your tunes ive been looking over other peoples setups for over a year now. You should not have started spooling after 3400/3500 rpms anything else is just to damn high.
FTW super16/evo3 for lots of low end and a huge chunk of the 18g top end. < so ill get walked by a 18g.
dingobite is offline   Reply With Quote
Old 07-31-2006, 01:00 PM   #16
BlackSnake
Member#: 42850
WTB 04-07 STI
Roller/Blown Engine
Are you asking if lag is worse then the stock turbo?
Yes it is...
I get 17.5psi at 3700rpms
22psi at 4200rpms
This is all with a leak at the Intake manifold.... So spool should get a little better once I fix that.
BlackSnake is offline   Reply With Quote
Old 07-31-2006, 01:02 PM   #17
dingobite
Member#: 82391
08 OBP Sti
If these turbos where boxers mitsu turbos of course.
Small 16g Featherweight
Big 16g Lightweight
Evo3-Super16g Middleweight
18g Welter weight
Heavyweight -anything to big i guess.
Old 07-31-2006, 02:41 PM   #18
gcm05
Member#: 105948
2005 wrx w/sti block
Crystal Grey Metallic
An 18G basically makes any 16G or "BIG, Evo, ...etc" look extremely silly
They don't even compare and the 18G's spool up is the same as my vf34's....early and quick rising. Again, it's all about that tune
gcm05 is offline   Reply With Quote
Old 07-31-2006, 02:59 PM   #19
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
What is early?
So the vf34 should start at about 3400 so your 18g spools at about the same time?
Magnum626 is offline   Reply With Quote
Old 07-31-2006, 03:15 PM   #20
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
sigh, the naive who buy a evo 3 16g over a 18g due to "spool"
bren wrx is offline   Reply With Quote
Old 07-31-2006, 03:40 PM   #21
gcm05
Member#: 105948
Subaru Stars
Originally Posted by Magnum626
What is early?
yeah except it's actually closer to 3300
Old 07-31-2006, 03:41 PM   #22
dingobite
Member#: 82391
08 OBP Sti
A super 16g is very close to a 18g and the fact that it will stay boosting in short stop and go distances is a silly reason to compare.
AutoX for example cuase i dont autoX your going to have a heck of a time keeping in boost even with a 3500rpm boosted 18g i dont think anybody here can say its possible to stay boosted in tight stop and go situations.
Ive even read vf34s that have been used to autoX only thing holding them back was maybe a second or two they wanted to get back in boost.
Im not hating
i just want more of instant boost thats why theres so many choices and theres a huge i mean huge 18g bandwagon here or most other sites.
Even if some of those 18gs out there are only making 305hp or or so and a EVO3 can hit 300hp im not afraid to say id rather have some low end fun away from open roads they 18g shines its hardest.
Old 07-31-2006, 03:56 PM   #23
VWGrk1
Member#: 57882
2004 WRX
Not to argue (much ), but I do not see how an 18G spools as quickly as a VF34 if both are tuned properly. Boost response would not be the same, either, I'd suppose.
Do you mean that you start to see positive boost at the same rpm? We should be more concerned with the torque curve, anyway. Asking when something spools is not a good question as it is too vague and, ultimately, unimportant.
Old 07-31-2006, 04:06 PM   #24
gcm05
Member#: 105948
well see the vf34 was APed as where my 18G is dyno tuned with a meth kit
haha ....sorry that's my little secret I forgot to throw out there
Old 07-31-2006, 04:13 PM   #25
BlackSnake
Member#: 42850
WTB 04-07 STI
Roller/Blown Engine
So you are claiming to get fullboost at the same time on the 18g as you did on the vf34? Post a dyno plot/Logs cause I am ready to raise the BS flag.
vf23 spool characteristics/datalog ride5000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 76 10-20-2014 07:05 AM
Spooling Characteristics of the "20gs" tearitdown9 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 119 11-24-2007 01:19 PM
TD05 16/18/20 Spool Characteristics wagonmasta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 49 12-21-2006 06:36 AM
info on turbo spool characteristics eatus ravenous Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-07-2006 09:46 PM
To those who upgraded their TMIC:Earlier turbo spool? Different spool characteristic? garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-07-2005 01:57 AM
