Old 07-30-2006, 01:24 PM   #1
06BLUEREX
Member#: 120000
Default Question about water/meth with nearly maxed out injectors.
i currently have a FP18g protuned, my injectors are nearly maxed out. my question is if i were to run meth/water injection would you need to get bigger injectors? or would the water meth injection lower the IDC?would i gain anything at all? my current mods are
ebay tmic
fp18g oil cooled.
walbro fuel pump
colder plugs
Perrin EBCS
K&N intake panel Filter
Catless Turbo Back Exhaust
Cobb AP
19psi tampering to 16psi at redline.
when i go back i am getting tuned with a fmic and a water/meth kit
and then later just go back with a bigger turbo and injectors.
06BLUEREX is offline   Reply With Quote
Old 07-30-2006, 01:26 PM   #2
Amazake
Member#: 9889
when tuned the AI/MI will lower IDC.
Amazake is offline   Reply With Quote
Old 07-30-2006, 01:50 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
It depends on where your tune is now, and where you want it to be after water/alc injection. If you use water/alc injection to help lean out the a/f ratio of the normal fuel system, you can definately run lower idcs then now at the same boost. How big are the injectors in your car? Either way, with the propper tuning I think you would be very happy with an injection system.
peace
Old 07-30-2006, 02:41 PM   #4
06BLUEREX
Member#: 120000
right now i have stock 06 injectors, there supose to flow the same as sti pinks i dunno
i was hoping to also gain some power as well like maybe 30-40whp? or should i just go ahead and go with race gas?
here is my log.
more advice,tips, and information is greatly appreciated.
Old 07-30-2006, 02:46 PM   #5
hippy
Member#: 36528
2002 Impreza Wrx
Yes, if tuned correctly you should be able to gain a bunch of power with water/alc injection(without getting bigger injectors since I guess that's the question). I have an 18g running 22-24psi(maybe a little more) all the way up the rpm range(on a 2 liter block though), and I use sti pinks. A/f ratio about 12.5 to 1, max idc about 95%.
peace
Old 07-31-2006, 12:50 PM   #6
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
You run 12.5:1 with no water/alk injection?
BadTrip is offline   Reply With Quote
Old 07-31-2006, 01:14 PM   #7
hippy
Member#: 36528
2002 Impreza Wrx
With water......
Old 08-03-2006, 03:10 PM   #8
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
DIY kit? or did you buy one from one of the retailers?
Old 08-03-2006, 05:55 PM   #9
hippy
Member#: 36528
2002 Impreza Wrx
I put it together, but many of the parts I used are aquamist parts(like tubing, fittings, nozzles, and solenoid). Not that I don't like my setup, but it would be nice to start over knowing what I know now(or at least what I think I know ).
peace
Old 08-04-2006, 08:56 AM   #10
BadTrip
Member#: 62211
03 WRX
Sonic Yellow
peace
Very interesting. What you do differently and why?
Old 08-04-2006, 12:10 PM   #11
hippy
Member#: 36528
2002 Impreza Wrx
I'd make a staged system instead of an adjustable flow one. My system is fully mappable, but this feature makes it so my water injection system took a lot longer for me to tweek then if it was staged, it cost a lot more, and I'm not sure that it helps my car perform any better. Then there are the parts I picked. I mean they're nce and all, but now that I've done more research on the subject, I feel that I could have gotten the same quality parts for much less. My system also doesn't have a safety system which monitors flow(not that I've needed it). If I chose my parts more carefully, I probably coulda paid less, got about the same performance, and had the flow monitor with a safety switch that cuts my boost when there's no flow. Live and learn I guess.
peace
Thnking about water/meth/alc injection.. RoOoLeR Water/Methanol Injection, Nitrous & Intercooler Cooling 1 08-24-2009 05:55 PM
Question on water/meth injection.. Fab's STI Newbies & FAQs 11 02-11-2007 11:02 PM
UTEC Logs, Stage 2 Maxing Out Injectors lancelucas UTEC 12 11-13-2006 03:20 AM
wierd utec logs plus maxing out injectors on stage 1 base map NITROS Engine Management & Tuning 4 01-04-2005 09:04 PM
maxing out injectors on turbo xs stage 2? ilivas Engine Management & Tuning 6 03-19-2004 02:23 PM
