Old 07-30-2006, 06:26 PM   #1
chibearz
Member#: 121572
Unhappy Need help-engine stall and cooling fan issue
Hello, by no means am I a gearhead so keep it simple if you can- just like the ride and contorl of my WRX. However, my mechanic has had it on and off over the last 6 weeks and can't find the problem. Subaru can't diagnose either. Rebuilt alternator, new battery, hundreds of continuity and diagnostic checks, and no luck.Engine [/b] is fine until about 10-15minutes into trip when cooling fan kicks in. Then immediately the rpms's drop and flutter up and down until it flat out dies. Usually starts up again right away, but problem continues. Any direction is much, much appreciated.
chibearz is offline   Reply With Quote
Cooling Fan Issue Jpizzzle Built Motor Discussion 2 04-13-2010 06:49 PM
FS:OEM engine mounts and cooling hoses/fan/reservoir from 2.2L roofis Engine/Power/Exhaust 7 05-31-2009 01:38 AM
Need help- Engine stall, cooling fan issue chibearz Newbies & FAQs 1 07-30-2006 08:05 PM
need help.engine issue.p1092 and p1093 flyKen74 Mid West Subaru Owners Club Forum -- MWSOC 2 06-21-2006 12:59 AM
Need help: engine stalls (non-subaru) viodea Normally Aspirated Powertrain 4 07-21-2003 10:04 PM
