Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 07-30-2006, 09:22 PM   #1
Nemesis Digital
Member#: 119579
2004 WRX Wagon
San Remo Red
Default Almost hit 400 miles on one tank.
This past week I flashed to Cobb Stage II 93OCT.
My mods are as follows.
Mileage 58k
2004 Wagon.
Up Pipe/ and Full 3" Non catted TBE
Stock Airbox (removed Typhoon)
My first tank of gas that I had with the new Stage II map I drove the car hard, EXTREMELY hard, and still managed 302 miles per tank. My next tank I drove conservatively and hit 380 on one tank. My car boosts well, pulls hard, and loves the stock airbox.
Is this out of the normal for most? I see people only getting aroudn 230ish a tank!!!
Nemesis Digital is offline   Reply With Quote
Old 07-31-2006, 01:57 AM   #2
Bbasso
Member#: 66235
2005 WRX
I have been able to get 33mpg, But avg about 25-28.
How many gal is the tank? I forgot...
Bbasso is offline   Reply With Quote
Old 07-31-2006, 01:51 PM   #3
bolderer
Member#: 115633
06 protuned vf-34
wagon
15.9 in my 06. Think they're all the same.
bolderer is offline   Reply With Quote
Old 07-31-2006, 05:28 PM   #4
avriette
Member#: 115968
2006 Impreza WRX STI
We've been keeping records of every fillup. Interestingly, we're increasing in mileage steadily per tank (up to about 2,000 miles now), and we max out at about 270 per tank. We got about 300 on a long road trip from DC to philly (well, it's not *that* long).
I see the other posters are wrx's, mine's an STI, and I thought we were supposed to get worse mileage.
avriette is offline   Reply With Quote
Old 07-31-2006, 10:36 PM   #5
hondaeater69
Member#: 60324
Mileage 58k
2004 Wagon.
i've never hit 380, even on a full highway tank. of course i drive slightly above the speed limit too
and you got 300 when driving hard? i find that very hard to believe.
Old 08-01-2006, 07:31 AM   #6
Rally_WRX1
Member#: 109797
2004 WRX Sedan
All Wheel Driven
It's kind of odd but my car has a stock gutted up pipe, godspeed downpipe connected to a blitznurspec r catback, with the cobb stage 2 93OCT and my gas mileage is crappy. I have only driven 65 miles and over a quarter tank is GONE. This 65 miles is also conservatively driven, I can't drive any more conservative then this, I'm in vacuum the entire time almost. I just thought that my car would get better gas milage then that, but hey I guess you gotta pay to play...
Rally_WRX1 is offline   Reply With Quote
Old 08-03-2006, 05:44 PM   #7
Student Driver
Member#: 65161
2002 2.5RS, AW
I can taste teh suck
Well, it's not quite as easy to compare each other as you might think. Here are a few parameters:
1. Altitude has a strong effect. Less efficient engine so if you're a lead foot you suck down the gas, but easy drivers get better mileage. Typically, if you drive at WOT at sea level and high altitude, you will get better mileage but worse HP/torque numbers. So, if you want to get around at the same speed as you would at sea level, you use more throttle and therefore get less mileage.
2. Speed. If you have a 75mph speed limit (and drive at it or more ), your mileage will not be as good as one driving 55 or 65 (especially if tuned to build boost earlier). This hurts the 5 speed owners more than those with the 6 speed. I typically get 28 at 55-65, but 25 at 75mph. This is with varying altitude (1,500ft to 5,500ft).
3. Octane. If you run a higher octane number, you tend to get less mileage. If I run 91 octane around town, I can get about 22mpg. But, if I run a fair amount of E85 in it I can drop 2-3mpg. Now, the part that throws people off is if a car can't run well on a lower octane, it can have the same or even worse mileage than the higher octane due to timing being pulled and other dynamic ECU calculations.
Other things can come into play here, like the weight/drag of the vehicle, use of wider tires, tire pressures, and so on.
Student Driver is offline   Reply With Quote
Old 08-16-2006, 02:32 AM   #8
AllAWD
Member#: 17079
I agree, I think "driving hard" is relative. I get close to 300 per tank in normal driving and around 230 when driving hard.
AllAWD is online now   Reply With Quote
Old 08-18-2006, 02:37 PM   #9
ggta
Member#: 58421
2006 wrx stg3+??
gray
I'm getting just a little over 315 just with a turboback exhaust and an intake. Thats driving hard.
About 280-300 without the turboback,
No AP yet.
ggta is offline   Reply With Quote
Old 08-18-2006, 02:58 PM   #10
chuckdez
Member#: 120187
2005 STI Stage2.5
Obsidian Black Pearl
I always get power MPG with lower octane. Living in the hurricane state, sometimes I'm forced to get 87 octane when no other fuel is available. I drive easier on the vehicle with lower octane and still produce worste MPG. Results are the same for my SC Benz and turbo Subaru.
chuckdez is offline   Reply With Quote
Old 08-18-2006, 07:17 PM   #11
subywrx
Member#: 81858
There is no way a WRX or any turbo car with 16 gal. tank can last 280+ miles with heavy driving. There's got to be something wrong or different with the car.
subywrx is offline   Reply With Quote
Old 08-18-2006, 07:20 PM   #12
nate49509
Member#: 22452
'04 WRX
witty comment goes here
Your wrong. I've got 300 miles on a tank and thats with an auto-x included.
Nice numbers. On my next tank I'm going to see what I get with the STX map.
nate49509 is offline   Reply With Quote
Old 08-19-2006, 11:51 AM   #13
AllAWD
Member#: 17079
I wish I could say that. In my '02 I rarely get 300 miles (max 26mpg) with my normal driving in stock form.
After my stage II upgrade I was having fun and got <20mpg.
I'm due for my 60k soon, so maybe I'll see the better mileage after that. I'm feeling that a heavy foot with lots of stop and go driving uses more fuel that just 1 auto-x plus nearly 300 normal miles.
Old 08-19-2006, 06:09 PM   #14
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
My mileage has gotten consistently better the more mods I've done. I've logged about 80 tanks of gas so far...
Stock for 50,000km = 18-19mpg
Stage 2 for 30,000km = 19-20mpg
ProTuned for 4 tanks so far = 20+mpg
70% city
30% highway
2,000 feet
On highway trips I can get 29.5mpg
02WHITEDUB is offline   Reply With Quote
Old 08-20-2006, 12:11 AM   #15
steve3364
Member#: 122002
2006 WRX Wagon
Gray
Post
I always get about 300 miles per tank in my '06 WRX wagon, and have actually seen an improvement in MPG since going AP Stage 2 93oct, two weeks ago. The overall MPG is only 23-24 though since I tend to drive aggressively but mostly in the interstate (if that makes sense to some of you), "Straight stretches to air it out some".
steve3364 is offline   Reply With Quote
Old 08-31-2006, 01:22 AM   #16
some dude
Member#: 100300
06 WRX
CGM
I got 32 mpg on a highway trip going 65 mph on a stock 06' WRX. That is the highwater mark for my mpg.
some dude is offline   Reply With Quote
Hyundai Santa Fe diesel gets 50MPG and goes 1,100 miles on one tank of gas! MattDell Non-Subaru News & Rumors 18 12-15-2006 12:34 AM
The ability to go XXX miles on one tank of gas wyn525i Off-Topic 55 10-17-2006 01:57 AM
400 miles to a tank t.rod Normally Aspirated Powertrain 9 12-28-2001 10:38 AM
('93-'01) ohh yeeaaww 302 miles on one tank baby SubyRacer Impreza Forum 16 09-03-2001 06:00 PM
