Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 07-30-2006, 10:33 PM   #1
humbleRex
Member#: 118454
2006 WRX
WR Blue
Default strut/sway bar? under brace?
what is a more common setup? is it larger or smaller sway bar? Or strut bar? And under brace?
humbleRex is offline   Reply With Quote
Old 07-31-2006, 01:05 AM   #2
MidnightBlackPearl
Member#: 83751
2015 BRZ
Ice Silver Metallic
I'm not really positive of what you're asking, but it's pretty common to upgrade the rear sway bar to a 22 or 24mm adjustable and the same for the front. Strut bars and underbraces are rarely done since the body's already pretty rigid from the factory. Hope I was able to help.
MidnightBlackPearl is offline   Reply With Quote
Old 07-31-2006, 01:47 AM   #3
FromEvoToRS37
Member#: 91396
2015 BRZ Series.Blue
if you've got a wagon get a rear strut bar, if you're really into handling get a front and rear strut bar because although some people say it wont make a difference, more people and experts say it actually does. upgrading the swaybars you want larger than stock diameter bars. underbracing.... it all depends on how stiff you want your car in normal daily driving I dunno if you will notice an improvement because I haven't put an underbrace on my impreza although I've put one on a previous car and noticed a difference, but upgrade the front and rear swaybars and if you still want more stiffness or better handling then do front and rear strutbars, if that still isn't enough underbrace, but I wouldn't do strut bars and underbrace if you dont have springs/lowered your car, springs (and struts if you want or coilovers) and swaybars will make your car handle noticably better. if you only have swaybars and want better handling dont get any more body stiffeners til you get springs because you wont notice it as much.
FromEvoToRS37 is offline   Reply With Quote
Old 07-31-2006, 03:27 AM   #4
humbleRex
Member#: 118454
2006 WRX
WR Blue
maybe i didnt express myself clearly.. but u said what i needed to know and thanks
Old 07-31-2006, 03:33 AM   #5
humbleRex
Member#: 118454
2006 WRX
WR Blue
mine is a 06 wrx.
i can have sways and struts (front+rear) at the same time? i had a concept that they are doing the same function, hence i was thinking which is a more common for daily driving. maybe better when cornering i would definitely be upgrading/adding one of them (or both) after hearing the views of them.
if given a choice to choose in between them, which will u choose?
as for the springs, i have no doubt they are to improve the handling.. but i guess i will better be enjoying the stock comfort of my ride for now.
NJ: Sway bars, sturt braces, coils, alk, etc... KIDREX Suspension/Brakes/Handling 29 07-01-2008 08:55 AM
FS. Coilovers, Strut Bar, Under Brace (Socal) dash Suspension/Brakes/Handling 13 04-29-2008 03:03 PM
WTB: Cusco rear strut tower bar, v-brace and front lower a-arm bar paulw Private 'Wanted' Classifieds 1 05-27-2004 08:24 PM
Torque Settings Sway Bars, Tower Braces Mr.Tickles Brakes, Steering & Suspension 2 07-26-2003 03:08 AM
