Old 07-30-2006, 11:15 PM   #1
WagonMonster
Member#: 3781
2002 Legacy GT Wagon
2009 Forester X Limited
OMGHi2U Not too pleased with my Stage 2
Got my car dynoed at AMS in Carson, CA yesterday.
The dyno is a MAHA LPS-3000 which is supposed to be the official Dyno of Audi and Porsche.
It also estimates crank HP, based on deceleration drag.
My mods:
Invidia Catted DP
Prodrive Muffler
AccessPort, Stage 2 (91 octane, California map)
My numbers:
169 WHP
225 Estimated Crank HP
Now, I know there are a few factors coming into play here.
1. I was running the piss water we call California Premium.
2. The MAHA Dyno is a heartbreaker of a Dyno.
But still, LESS THAN STOCK?
Especially since a 2004 Wagon with Similar Mods did 188 WHP and a crap-ass, 1990 Camry did 270HP (estimated, granted, it had a Celica Turbo Motor in it )
But, I dunno, something seems fishy.
WagonMonster is offline   Reply With Quote
Old 07-31-2006, 12:57 AM   #2
Airboy
Member#: 72829
2006 WRX
2015 WRX
Can you post the dyno sheet? Didn't they test a '06 stock WRX and came out with 167 WHP and 220 est engine hp?
Airboy is online now   Reply With Quote
Old 07-31-2006, 01:13 AM   #3
hippy
Member#: 36528
2002 Impreza Wrx
Numbers imo are meaningless, course I've never been on a dyno. Does your car feel quicker then it did b4 the tune?
Old 07-31-2006, 02:52 AM   #4
Bbasso
Member#: 66235
2005 WRX
For Stg2 shouldn't there be a catless Uppipe?
Also what size piping on the Exhaust parts you installed?
What was the weather conditions while on the dyno?
Are you sure the dyno was in 4wd and not 2wd? (I've seen that mistake)
Which type of dyno, Mustang or Dynojet?
What gear did they test in?
Has the car been well maintained, such as new/clean fluids?
Do you have different size wheels, If so was that taken into consideration?
How about you give us more to work with
Bbasso is offline   Reply With Quote
Old 07-31-2006, 03:57 AM   #5
ghibli99
Member#: 90761
2003 S2000
Save the Manuals!
I also got dyno'd yesterday at AMS after WagonMonster. I posted this in the AMS thread... here's my plot to compare to his results above:
191.2 whp
240.1 estimated crank hp (corrected for ambient temperature, humidity, etc.)
401.4 Nm torque = ~296 lb/ft
Driveline loss looks like 20%, so if I take 20% off my torque numbers, I'm guessing my wheel torque is more like 236 lb/ft. I doubt that's accurate, so someone call me on it if I'm totally off.
I'm running on the following:
2006 WRX (2.5 block)
PDE catted downpipe
Stromung 2.5" intermediate pipe
STI Genome muffler
Cobb Stage 2 OTS map (standard non-CA 91 map, Citgo 91 fuel)
Everything else is stock, except for my Zero/Sports intake pipe, but I doubt that does a damn thing.
Subaru says stock hp is 230 for my 06... I got about 10 more at the crank w/ the Stage 2 map. Not much higher, but it's about what I was expecting, since I figure Subaru is highballing their number a bit. Torque, I was pretty happy with, though.
I'll be curious to check this thread later to get to the bottom of WagonMonster's results and to check out the plot.
-Mike
ghibli99 is offline   Reply With Quote
Old 07-31-2006, 11:32 AM   #6
WagonMonster
Member#: 3781
Did you even read my post?
Old 07-31-2006, 11:54 AM   #7
WagonMonster
Member#: 3781
But, to answer your questions...
No
2.5"
Warm, but the dyno accounts for that in it's estimated power
I'm not a retard, of course it was 4WD
MAHA
3rd
Yes
The rolling circumference is the same as stock.
Old 07-31-2006, 11:57 AM   #8
WagonMonster
Member#: 3781
My Dyno sheet
Old 07-31-2006, 12:29 PM   #9
AshyLarry
Member#: 94890
03 wrx
From what it looks like the problem lies in the gas as you know, the dyno which is a bitch, and if I remember stg2 is for catless? That could be part of the problem. I know after I reflashed with stg2 93 octance on my catless car it is much quicker so if the numbers dont say that, I still know and feel that its faster, although its become normal for me now, so I guess its time for a new turbo, you might want to consider the same.
AshyLarry is offline   Reply With Quote
Old 07-31-2006, 12:48 PM   #10
WagonMonster
Member#: 3781
Stage 2 isn't for catless.
According to Cobb, you can run a catted DP and get the same numbers as Catless.
Old 07-31-2006, 12:51 PM   #11
AshyLarry
Member#: 94890
03 wrx
From Cobb's website:
The Stage 2 was tuned on a car with a full turbo-back system. If you have pieced together a less than optimal combo of parts or those that were not designed to work together you may not get the full benefits of the Stage 2 AccessECU. Boost may not come on as quickly and the peak power may be down from those that have a well designed full turbo-back system. If you have replaced the first section (second cat or downpipe section) and nothing else, then the Stage 2 map is what we would recommend. Again the results will be far less than optimal, but it will control the boost better than the Stage 1. If you have replaced sections 2-4 (third cat, mid-pipe, and muffler section then you are still Stage 1. You managed to get all except the part that makes the most difference. Again, we want to reiterate that Stage 2 will only get the intended results with a well designed complete turbo-back.
Reading between the lines it says, to me atleast, catless for the most power.
Old 07-31-2006, 12:53 PM   #12
WagonMonster
Member#: 3781
Once again, you're WRONG.
I have a full turbo-back system, just one with a high-flow cat.
You can read between the lines all you want, but, the fact of the matter is that a high-flow catted DP is perfectly acceptable for Stage 2, and a LOT nicer to the air.
Old 07-31-2006, 12:55 PM   #13
AshyLarry
Member#: 94890
03 wrx
Ok then, atleast we agree that 91 octane is a big part of the problem....
Old 07-31-2006, 12:55 PM   #14
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
It was tuned on a 3 inch turbo back?
parker/slc/gc8fan is offline   Reply With Quote
Old 07-31-2006, 12:56 PM   #15
WagonMonster
Member#: 3781
Not only 91, but California 91, it's terrible stuff.
Old 07-31-2006, 01:06 PM   #16
salisburyv
Member#: 41863
2015 STI
Crystal Black Silica
Did you baseline the car? So you could see a difference before and after? That is another way of seeing imporovements.
salisburyv is offline   Reply With Quote
Old 07-31-2006, 01:34 PM   #17
WagonMonster
Member#: 3781
I did not, I should have, but *shrug*
Old 07-31-2006, 03:55 PM   #18
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
that dyno machine suck..
my friend's sti on stage 2 dyno at 295 crank..
mucho sucko..
Kenji815 is offline   Reply With Quote
Old 07-31-2006, 06:39 PM   #19
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Just cause a dyno reads low doesnt mean it sucks.
It just means it isnt the best for bragging rights.
Old 07-31-2006, 09:49 PM   #20
CynicX
Member#: 48199
06 WRX
its a maha...I'm surprised you got that much. The dyno doesnt suck but just like all dynos, they are for tuning purposes. Goto a dynopack and you'll probably put 50-75 more hp...
They read low in comparison to other dynos. They are good for tuning and comparing mods hp increases on THAT dyno. Thats true for all dynos....
CynicX is offline   Reply With Quote
Old 08-01-2006, 01:57 AM   #21
Bbasso
Member#: 66235
2005 WRX
I just wanted to make sure everything was covered...
Since you did not do a base line, You'll never know how much improvement was made, if any...
When I had mine dynoed I did a before and after on a low (aprox 30%) reading mustang dyno. If I didn't do the before I's be asking the same Qs as you. My after #s were not impressive, But when compared they are excatly what Cobb Advertised and I was pleased.
Old 08-01-2006, 02:23 AM   #22
Black-STi
Member#: 111165
2008 Legacy (Sedan)
2005 S2000 (Supercharged)
exactly..maha is a good dyno just dont expect big numbers....
Black-STi is offline   Reply With Quote
Old 08-01-2006, 08:08 PM   #23
bl0wnb0xerbabiE
Member#: 121722
2006 Impreza WRX tr
Obsidian Black
191.2 whp
PDE catted downpipe
STI Genome muffler
-Mike
Correct me If im wrong but I think your severely underestimating everything. First off, the 06 would be UNDERRATED from the factory, not overrated. I figure 10more whp then pre06's. Secondly, you shouldnt be getting only 10crank hp on stage 2, that's ridiculous. So your basically sayin u gained like 4 whp, and your satisfied with that??? That dyno is messed up. Stage 2 Ap puts down around sti numbers...
bl0wnb0xerbabiE is offline   Reply With Quote
Old 08-01-2006, 08:27 PM   #24
WagonMonster
Member#: 3781
I'm chalking it up to the MAHA being totally unreliable for measuring real power.
Old 08-01-2006, 08:40 PM   #25
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
kennyvb is offline   Reply With Quote
Not too happy with my ATP 35R Simes Built Motor Discussion 8 04-23-2010 06:20 PM
Not getting the power out of my stage 2! b.s. subie_nation General Community 25 05-01-2008 12:42 AM
not hitting boost with ap stage 2 deluxsti AccessPort 16 06-07-2006 05:18 PM
Anyone ran 1/4 mile with Cobb stage 2 and stage 2 HWG map? txl146 Engine Management & Tuning 2 05-15-2005 09:08 AM
04 STI -Weird NOISE with my stage 3 clutch. Can someone please explain. zigger Transmission (AT/MT) & Driveline 0 04-07-2005 11:37 PM
