Old 08-03-2006, 10:40 AM   #51
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i am wondeing if its not the uppipe cat i too am having simmilar stage 2 difficency proublms with the LGT
Old 08-03-2006, 12:57 PM   #52
Airboy
Member#: 72829
2006 WRX
2015 WRX
I see that dip in two '06 WRX and a STi here in Calgary.
The WRXs are running 91 (which supposed to be crap like California gas) with Cobb OTS stg2 maps
The STi is using 94 gas (with ethanol) with OTS Cobb stg map
For the STi, I logged (at least I think I did) the Advance Multiplier and did not see a change at the 'transition' area.
Originally Posted by drees
See that big dip in timing at 3.6k in your dyno chart? The ECU saw significant detonation there. Not good. At the very least, you should be running the CA-91 map, but I doubt that will totally fix it.
From what I've seen, Cobb seems to run the cars a bit too lean right when boost hits with their OTS maps for CA fuel. They seem to be able to get away with it in other states.
I had constant pinging problems with my Cobb Stg1 on full throttle which would only go away after multiple pulls to let the ECU learn. I gave up and went back to stock fearing for my engine's life. The AP is a good product, but the OTS maps suck for CA. Even the so-called CA91 maps are too much for a lot of cars here. I don't think I would have been able to hear the pinging with the Prodrive oval-tip I have on now, so if you have a non-stock muffler, you could be pinging and not hear it. Datalogs will readily show how happy your engine is.
Airboy is offline   Reply With Quote
Old 08-03-2006, 01:04 PM   #53
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
The AM usually stays fairly constant if the ECU hasn't been reset recently.
But KC (which AM limits) will drop if the ECU hears knock or heard knock at that RPM/load point before and it does in your bottom pic.
Now, you can't always be 100% sure that a small drop in KC means the ECU is pulling timing without seeing the KC maps, but in your case the KC drops 4 points (1 KC = 1* ignition timing) which definitely isn't normal. Especially when it drops off so sharply.
In your other chart you notice that even the stock WRX is pulling timing. Like AMS noted, even stock WRXs have a tendancy to ping on CA91 or equivalent gas.
drees is offline   Reply With Quote
Old 08-03-2006, 07:37 PM   #54
Umphreys448
Member#: 73519
2003 WRX
Find a friend with a stock wrx and drag him. If you win, blame it on the dyno. If he wins... well...
Umphreys448 is offline   Reply With Quote
Old 08-03-2006, 08:37 PM   #55
ghibli99
Member#: 90761
2003 S2000
Save the Manuals!
Thanks for the good info, and yes, I realized at the meet that I hadn't flashed the CA91 map yet. I'm running it now, and it might just be me, but I seem to have less pop and gurgle. I plan on getting the car tuned in the near future once the VF39 goes in, and then I'll hop back on the MAHA to see what's up.
-Mike
ghibli99 is offline   Reply With Quote
Old 08-04-2006, 06:30 PM   #56
WRXedUSA
Member#: 26833
'07 Bugatti Veyron
'03 Chevy Silverado
Get rid of the stock catted uppipe especially since you are running stage 2. That's a accident waiting to happen.
WRXedUSA is offline   Reply With Quote
Old 08-04-2006, 06:40 PM   #57
CynicX
Member#: 48199
06 WRX
I still think its the typical MAHA dyno reading....time and time again I see extremely low MAHA numbers. Like I said before, nothing WRONG with that. Just some dynos read higher...
You want something acturate that you can compare to stock then pull the motor and send it back to Subaru and let them test it on a crank dyno....or find a friend with a stock wrx to run on the MAHA (probably easier )...
You want inflated bragging numbers find a dynopack....
CynicX is offline   Reply With Quote
Not too happy with my ATP 35R Simes Built Motor Discussion 8 04-23-2010 06:20 PM
Not getting the power out of my stage 2! b.s. subie_nation General Community 25 05-01-2008 12:42 AM
not hitting boost with ap stage 2 deluxsti AccessPort 16 06-07-2006 05:18 PM
Anyone ran 1/4 mile with Cobb stage 2 and stage 2 HWG map? txl146 Engine Management & Tuning 2 05-15-2005 09:08 AM
04 STI -Weird NOISE with my stage 3 clutch. Can someone please explain. zigger Transmission (AT/MT) & Driveline 0 04-07-2005 11:37 PM
