Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 07-31-2006, 05:53 PM   #1
bondkiller
Member#: 121151
Default oil leak in 97 1.8L
ok guys oil is leaking under my engine and i can't figure out where its coming from i don't have money to go to a mecanic what can i do?
bondkiller is offline   Reply With Quote
Old 07-31-2006, 06:37 PM   #2
abosworth
Member#: 53856
2012 Speed3
Red Mica
Look underneath the timing belt cover. I would bet that it's your front main seal which is located under the t-belt cover. It also could be a cam seal that is leaking.
abosworth is offline   Reply With Quote
Old 07-31-2006, 07:20 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Gotta get more specific than "under the engine". It could be the itmes mentioned above. Could also be the rear main. Or it could be as simple as the valve cover gaskets. Regardless, on an Ej18, those things are bulletproof and if you just monitor your oil level and top up as needed it will run forever, leaks or not...
Old 07-31-2006, 07:40 PM   #4
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Can you post a picture?
-Charles-
ImprezaVA is offline   Reply With Quote
Old 08-01-2006, 02:27 PM   #5
DoinkMobb
Member#: 3787
2008 Gay
Car
It's not worth the money to fix, just keep enough oil in it and drive the car into the ground. All old Imprezas leak oil, so it's pretty much normal.
DoinkMobb is offline   Reply With Quote
Old 08-01-2006, 08:05 PM   #6
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
If he can do the work, it's definitely worth the cost of a crank seal. IIRC, it's $8.
-Charles-
Old 08-03-2006, 12:11 PM   #7
abosworth
Member#: 53856
2012 Speed3
Red Mica
Well, if he is going to replace the timing belt or water pump any time soon why not front main seal/cam seals???
Old 08-03-2006, 12:31 PM   #8
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Start by cleaning your engine top and bottom with a degreaser, brush and hose/low pressure washer. Clean the back of the motor and the transmission/axles too. Do it at a u-wash place to avoid making a mess of your property.
Drive it for a while and then look for the leak.
It is likely one or more of:
cam seals
front crank
oil pan drain especially if no/used crush washer used
Rear crank
rear separater plate
oil pump
axle seals
tranny tail seal
oil pan gasket
cracked oil pan
tranny plug
shifter linkage seal
oil pan drain especially if no crush washer used
cam cover bolt seals
cam cover gasket
they all can leak. (Ask me how I know.) Oil under under the timing cover could ruin your belt soon. Oil at the back can wreck your clutch. Oil elsewhere will find its way to the exhaust and burn and stink.
Also, after you are done cleaning. Park on a piece of clean paper or cardboard and look for the leak. The colour/smell of fluid can narrow it down too.
linsavy is offline   Reply With Quote
Sourcing an oil leak in 97 Outback GAMO Service & Maintenance 2 02-04-2007 12:14 PM
Oil Leak in Ludedpeed Stg 2 Kit Derk1127 Normally Aspirated with bolt-on Forced Induction Powertrain 30 07-25-2003 05:23 PM
Gear oil leak in older gen 5MT? (pics included) Kha0S Transmission (AT/MT) & Driveline 10 06-24-2003 08:37 PM
Oil leaking in the spark plug boot area. JamesNUTT Service & Maintenance 1 04-19-2003 01:53 AM
Anybody have problems with oil leaking in older subies? redobs Technical Forum Archive 14 09-15-2000 10:25 AM
