Old 07-31-2006, 10:55 PM   #1
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
Default read live boost vs boost gauge?
how accurate is the boost read live boost function vs mechanic boost gauge?
My mechanical reads about 1 bar but live boost only reads about 13.5 psi.
it's off by 0.5 -0.8 psi.
Kenji815 is offline   Reply With Quote
Old 07-31-2006, 11:04 PM   #2
Abetoy
Member#: 70819
96 Sexus ES300
im having the same prob...im some cases my mechnical gauge reads 1 psi higher than APs boost reader. From wat i've read on the boards most ppl say go by the APs boost prolly because it reads it directly from the ecu
someone correct me if i wrong pls
Abetoy is offline   Reply With Quote
Old 07-31-2006, 11:05 PM   #3
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
i would think mechanical is more accurate because boost = pressure
Old 07-31-2006, 11:13 PM   #4
hondaeater69
Member#: 60324
as long as your OEM map sensor is in proper working order, the AP's live boost reading will be more acurate than the mechanical gauge.
Old 08-01-2006, 06:42 AM   #5
RumblingREX
Member#: 41087
My electric boost gauge is accurate down low, but is way off once I get to 16psi or higher. Don't ask how I know. But if my gauge was right, I would have a hole in my engine. Stick with live boost as the more accurate measurement.
RumblingREX is offline   Reply With Quote
Old 08-01-2006, 12:25 PM   #6
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
In past threads akin to this one, members determined that it is more accurate to go off the AP live boost reading as opposed to whatever boost gauge you have.
Hank3 is offline   Reply With Quote
Old 08-01-2006, 12:37 PM   #7
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
interesting.. i'll have to try to do some datalogging.
because my mechanical boost gauge is reading 1.07 bar peak boost but the live boost only reading about 0.97 bar
Old 08-02-2006, 04:26 AM   #8
ryzies
Member#: 118548
sti shopping
my ap reads 19 but my gauge reads 20...who knows.....
ryzies is offline   Reply With Quote
Old 08-02-2006, 05:49 AM   #9
2005wrx
Member#: 91321
2006 STI
the ap only reads up to 18.3 do to the limitations of the ecu i read that on page27 of the 06sti ap userguide
2005wrx is offline   Reply With Quote
ECU vs Boost Gauge PSI Readings Studebaker83 Newbies & FAQs 3 01-23-2010 07:18 PM
AP read live boost limit? hettchen AccessPort 2 09-10-2007 08:30 AM
?? about reading live boost with AP pictureboy AccessPort 9 07-06-2006 06:05 PM
reading live boost with AP tech AccessPort 26 02-26-2006 11:19 PM
Accessport Live Boost Accuracy vs Boost Gauge? AKGC8 Engine Management & Tuning 28 12-06-2005 06:54 PM
